go_a_way1
Old 05-15-2015, 10:58 PM   #2255
Infamous Performance
Infamous Performance's Avatar
Drives: 02 WRX, 05 LGT, 08 LGT, 08 SpecB
We have seen as low as 135whp and as high as 150whp for stock BRZ/FRS. Mustang AWD-150-SE.
In general (and this is a MAJOR generalization), Mustangs measure the amount of load the car can put on the rollers, a Dynojet measures the amount of power required to move a known weight (the rollers), and a Dynapack measures the amount of load on the axles.
Dyanpacks are the easiest to manipulate. The fact that a chart shows "flywheel" leads me to believe the operator was "fudging" the numbers. It is far too easy when using the FW measurement on a Dynapack.
We have tested the same car on the same day on my Mustang, the Dynojet used by DSPORT magazine and Churchs Dynapack.
On the Dynojet comparison we used Bills BRZ. The car makes 17-20% more power consistently on the Dynojet compared to our Mustang.
On the Dynapack comparison we used a customers 07 STi. The car made 485whp on Churchs Dynapack and 385whp on our Mustang.
Infamous Performance is offline   Reply With Quote
The Following 2 Users Say Thank You to Infamous Performance For This Useful Post:
Bonburner (05-16-2015), SPCorBUST (05-16-2015)
Old 05-16-2015, 12:56 AM   #2256
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Originally Posted by Germanjap View Post
Ordered JRSC on May 4. Was told today another 2-3 weeks. So about a month for shipment.
Ordered 4/27 was giving a will ship week on 5/25, also have the cooler in the same order
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
CSG Mike (05-16-2015)
Old 05-19-2015, 10:41 PM   #2257
dj2020
I ran into a little snag trying to incorporate the Mishimoto PCV catch can into my JRSC set up. The intake manifold check valve that came with the JRSC obviously fits perfect with the OEM tubing. The Mishimoto silicone tubing is 1/2" diameter which naturally fits perfect for the catch can and the intake manifold. But both ends of JRSC check valve are too small for the 1/2" diameter of the Mishimoto silicone hose. I don't think it will work even with the clamps. What's the best way to approach this problem? Are there PCV hoses that are 1/2" on one end and small enough on the other end for the JRSC intake manifold check valve? I apologize for being automotive stupid here.
dj2020 is offline   Reply With Quote
Old 05-19-2015, 11:12 PM   #2258
350z
Drives: 350z
How much boost are you guys seeing on the gauge?
350z is offline   Reply With Quote
Old 05-20-2015, 01:11 AM   #2259
dj2020
We saw 9.2 lbs on the stock pulley. Shawn Church t'ed into the bypass valve vacuum line for the measurement.
Old 05-20-2015, 02:27 AM   #2260
dj2020
Found the answer to my above question:
Thank you @zoth for the link to the 12mm check valve used on your supercharger set up.
http://www.boombaracing.com/check-valve-12-mm-1-2/
The Following User Says Thank You to dj2020 For This Useful Post:
dp1 (05-20-2015)
Old 05-20-2015, 05:44 AM   #2261
CSG Mike
CSG Mike's Avatar
I'd recommend replacing your tubing with smaller diameter tubing that fits the check valve. YOu can always stretch it to fit the manifold and the catch can.
dj2020 (05-20-2015), dp1 (05-20-2015)
Old 05-20-2015, 05:44 AM   #2262
CSG Mike
CSG Mike's Avatar
That depends on where you're located, your ambient conditions, and where you're reading the boost. If you're using a P3 gauge, you will not see all the boost you're actually pushing.
Old 05-20-2015, 11:48 AM   #2263
Massimopirrone
Drives: 2014 frs
Any news on a smaller pulley?
Massimopirrone is offline   Reply With Quote
Old 05-20-2015, 12:10 PM   #2264
dj2020
Is there a tube/product you recommend that is small enough for the JRSC check valve but stretchy enough to fit the catch can fitting and intake manifold? Would you say that I need a 1/4" ID diameter tube for the check valve?
Old 05-22-2015, 02:05 AM   #2265
Jmonty
So my kit should ship next week?
How many are running a header with this kit?
Old 05-22-2015, 02:09 AM   #2266
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The Following 6 Users Say Thank You to Andrew025 For This Useful Post:
*LongFella (05-22-2015), autograph (05-22-2015), CSG Mike (05-22-2015), JDsThatGuy (05-22-2015), Jmonty (05-22-2015), JonAvalon (05-23-2015)
Old 05-22-2015, 02:24 AM   #2267
CSG Mike
CSG Mike's Avatar
I believe a 1/4" will fit, but make sure you use clamps. 3/16" may be safer.
dj2020 (05-22-2015)
Old 05-22-2015, 11:25 PM   #2268
Jmonty
So with a header and this kit should I get a bigger MAF sensor? My tuner just maxed out one on a stock + JRSC at 7000 RPM?
IF so which one and where do I get it?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
