| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
I think I'm going to end up getting these.
http://www.tirerack.com/tires/tires....omCompare1=yes Sent from my iPhone using Tapatalk
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#30 |
Drives: 2013 Scion FRS "Raven"
Honda challange guys have been running on 7inch rims. They run anything from a235/40-245/40. We currently run a 235/40/17 R1R on the stock rim. It's a touch smaller then stock and we have no problems.
#31 |
Drives: 2013 BRZ Premium
Tirerack is showing a 215/45 F 255/40R stagger option for stock wheels. Anybody have any experience in that combo?
#32 |
Drives: 2013 BRZ Sport Tech White Pearl
Bumping this?
#33 |
Drives: 2013 Asphalt
Just got Michelin Pilot SS 225/45/17.....in love, super smooth, extra grippy!
#34 |
Power Ranger Elite
Drives: '13 WRB Sport-tech
Do you happen to have a picture of them on the stocks?
#35 |
Drives: FR-S,GTI
I've always run 235/45/17 on the FR-S and my VW (has the same size rims). Been using them on the VW for over 10 years. I don't like the "look" of the stock size. It just doesn't look right to me.
Actually as soon as I got the FR-S I swapped tires with the VW. It has the stock Scion tires on it now. And it looks really wrong. They'll probably be the last tires it ever sees because I pretty much don't drive it anymore. The FR-S is much more fun to drive. |
#36 |
Only users lose drugs.
Drives: All the time
I'm running 225/50 on 16x7 with zero issues, including autocross. Car has better feedback than the OEM setup, and I don't need to run crazy pressures get good feel. 7" is perfectly fine for a 225, unless you just like the extra weight.
#37 |
Dismember
Drives: 2013 Red Scion FR-S
Every manufacturer specs out acceptable wheel sizes for each of their tires and sizes. Some 225 width tires will fit. Others will not. It's dangerous to run tires out of their specs, unless you're just hard parking.
#38 |
Drives: 2015 FRS
| The Following 2 Users Say Thank You to Lorico For This Useful Post: | N234 (11-18-2019), Spankopotomous (04-14-2021) |
#39 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
This thread let me know that I can order my PSS tires in 225/45/17. Thanks a bunch, heading to Costco's website.
#40 |
Drives: frs
Bump
I will buy tires soon, will stock rims can hold 225? Or can go more width without rubbing issues? |
#41 |
I autocrossed last year on 245 RS3's on the stock wheels at the oem ride height. Never felt unsafe but had some sidewall flex. Had the first tire shop refuse to install them and basically had to beg the second shop to do the install.
#42 | |
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
If you're going for the most amount of contact patch...look into Yokohama AD08's. PSS's are pretty good...but if you live where there's light snow/cold-near freezing temps...look into the AS3's. |
| The Following 2 Users Say Thank You to SHWNBRZ For This Useful Post: | soulreapersteve (12-17-2015), Teseo (12-17-2015) |
| Best Tire Size for Stock Rims | djliquidsteele | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 58 | 09-03-2017 02:10 AM |
| optimal tire size for stock wheels | brillo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 12-05-2015 12:01 PM |
| Maintaining stock tire size what to upgrade to... | tuckdaddy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-03-2013 11:28 AM |
| largest tire for 19x8.5 et45 | garfull | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-24-2013 11:44 PM |
| Optimal Tire Size For Stock Rims | Raven604 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-05-2013 08:41 PM |
