#3025 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
#3026 |
Drives: 2013 Red 6MT Scion FR-S
No not confirmed. I'll need to check.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street http://yawmomentracing.blogspot.com/ YouTube Channel |
#3027 |
C-Street AutoX
so I had a local last week in the rain, on a very bumpy lot with a lot of tight turns, sealed asphalt. The TRD suspension was NOT very good at this site, in the rain on 235/45/17 stones. I ran in the same heat as an SSM C5 Z06 on the same tires, who I figured I'd be able to straight time in the slippery wet conditions, but he was about a full second faster than me, in the same heat an STR NC Miata with a very good driver was about 2+ seconds faster than me on Dunlops on a 65 second course. I still beat these cars on index, but I figured the raw time in the rain would be a lot better. I did beat the local CS cars by 3.5 seconds+. Index was won by an STS CRX that ran about 2 seconds faster than me in a slightly dryer third heat, but I thought the FR-S would do a bit better in these conditions. Wavy bumpy lot probably didn't help the TRD springs any,and tight turns with tall tires were probably no help either. I ran 24F/25R Psi on my fastest run.
I'll likely be on the polar opposite at the Toledo express airport this weekend, with very high speeds, dry weather, and salt-flat smooth concrete. I'm hoping for better results.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
#3028 | |
Senior Citizen
Drives: Scion FR-S
#3029 |
The Stig's German cousin
Those are some awfully low pressures, says the guy who likes 45psi. But really, higher rear pressure than front? Seems odd.
Rain events can be weird, and the SSM/STR drivers could be secret aces in the wet. Brush that dirt off your shoulder and do the next event. |
#3030 |
Drives: 2013 Ultramarine FR-S
Quick question, is the fiveaxis spoiler legal in CS? I've found one mention of it being a port option in the STX thread. Just want to be sure.
Running my '13 FR-S with the Red Deer Sports Car Club in Alberta, my first season of autocross. This thread has been a gold mine, so thanks to everyone. |
#3031 |
C-Street AutoX
Remember, this was in the WET. Sealer on the lot, very bumpy, no traction. Lower pressures should be beneficial. What are you running the RE71's at in the dry? I'm at like 30-31 hot. Slightly lower than what I ran in the rivals. The sidewalls are far to stiff to need 45 PSI in the dry, that seems crazy.
I ran the Koni yellow shocks at 1/4 from full soft in the rear, and maybe 1/8 turn stiffer than that in the front. Low grip/rain should call for softer everything from my experience, but I was surprised the car wasn't faster this day.... http://furrin.org/Results/tabid/56/a...--5102014.aspx 6th of 84 on PAX, guess it's not too bad, but I had higher hopes in the rain. I would have tried running with sport mode stability control if I had another shot at it....
#3032 | |
Senior Citizen
Drives: Scion FR-S
#3033 |
http://www.ft86club.com/forums/showp...postcount=1303
This is the post about the 5ad spoiler in the STX thread. Just wonder my if anyone knows for sure. |
#3034 | |
You aren't likely to get protested for it, but if you get protested you will lose. It's up to you if you're ok with that. |
#3035 |
Custom User Title
Sick downforce yo!
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#3036 |
#3037 |
Drives: GBS Limited 6MT
Those of you running a more aggressive brake pad, are you running the same compound front and rear?
#3038 | |
Drives: Yes
I ran on the Bridgestones for the first time this weekend on sealed asphalt. I'm so used to the Hankooks that I need to make some adjustments to get the RE71R to suit my driving style better. Compared to the Hankooks, they seem very quiet on course. There was a well driven two-driver RX8 on Rival S and another on Z2* that put down times very close to mine, so it should give me some insight on all the new tires.Also... I know it's early, but does anyone have a seat in a BRZ/FR-S available for Nationals this year? I have a car to drive in another class, but I'd really prefer to stick with my same car and platform I know. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
