Old 05-17-2015, 05:02 PM   #1
WishIhad86
Drives: Argento 86
2015 side marker install
Hey folks, on my 2013 frs I had no problems installing the side markers (reflectors) but on the 2015 I seem to be having difficulties, does anyone know if they changed that particular area? thanks
WishIhad86 is offline   Reply With Quote
Old 05-17-2015, 05:36 PM   #2
Max FRS
Drives: 2015 Halo FRS Automatic
No change to 2015. Replaced both of mine. The driver's side popped right in. The passenger side did not want to lock-in. Lie down and look up and you can see where it connects. I used a small slot screwdriver to help the clip connect. Hope this helps.
Max FRS is offline   Reply With Quote
Old 05-17-2015, 07:03 PM   #3
WishIhad86
Drives: Argento 86
That's a good thing, the bad news is I can't seem to find the clip and I must have bend the black tab instead.
Old 05-17-2015, 07:44 PM   #4
WishIhad86
Drives: Argento 86
nvm! all good now thx
Old 05-19-2015, 04:57 AM   #5
LED86
LED86's Avatar
Drives: Black 86 GTS
Sounds like you already fixed the problem. I have a couple of videos i did on side marker installation that might help you or others in the future
Part 1: General removal/installation tips.
[ame="https://www.youtube.com/watch?v=_EOskL7XIw0"]86BRZ Side Marker Installation Guide - YouTube[/ame]
Part 2: Extended discussion on what causes them to not fit correctly and fall out
[ame="https://www.youtube.com/watch?v=MhkIEYecKsw"]86/BRZ Side Marker Installation (Extended Discussion) - YouTube[/ame]
LED86 is offline   Reply With Quote
The Following 6 Users Say Thank You to LED86 For This Useful Post:
Ammunition (05-19-2015), BRZ FTW (06-05-2015), kch (05-19-2015), Kimsey47 (05-19-2015), Pacific (05-19-2015), snow (05-19-2015), Travisty75 (03-18-2017)
Old 05-19-2015, 10:03 AM   #6
Max FRS
Great videos! These would have saved me a lot of time and frustration. If anyone is installing side markers, these videos will help make it a much smoother installation.
The Following User Says Thank You to Max FRS For This Useful Post:
LED86 (05-19-2015)
DIY JDM Clear Side Marker Install F1point4 DIY (Do-It-Yourself) Guides 96 11-24-2021 10:10 AM
WTB side marker jupillam Want-To-Buy Requests 4 07-26-2014 12:32 AM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
WTB: smoked side marker (driver side) vincent201089 Exterior Parts (Aero, Lighting, Etc.) 2 07-29-2013 05:29 AM
DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! MrGamer DIY (Do-It-Yourself) Guides 11 07-07-2013 11:19 PM
