Old 05-14-2015, 02:47 AM   #1
starron
Drives: FRS 10 Series
clunking noise after LCA install
so I've been having the ST coils on the car for about 6k miles with no issue. 2 weeks ago I finally got to put on the voodoo 13 LCA and the noise started to come. at first I thought it would be the end links problem like people had before. so today i removed the end links and sway bar out of the way and the noise still going strong when i put weight/pressure on the car's body.
please take a look at the video i put together in different angles and hope somebody can give suggestion or even a solution. I really have no idea where the noise is coming from....
starron is offline   Reply With Quote
Old 05-17-2015, 01:51 PM   #2
Backinthegame
Drives: 2015 FR-S
Check the jam nuts for your adjusters
Backinthegame is offline   Reply With Quote
Old 05-17-2015, 04:02 PM   #3
cnk
Drives: '13 DGM BRZ Limited
I had a similar noise when I was beta testing the Figs Mega Arms. What I did was to bounce the car up and down while placing my hands in different locations until I could isolate where the noise was coming from. For me, it was the pillowballs. One pillowball seemed to have a tiny bit of play in it that would result in a clicking noise just like your video.
I decided to just go with SPC arms and haven't had any noises since. The SPC arms use urethane mounts just like the stock arms so there is a little bit of compliance. Would have preferred to stick with the Figs arms, but the clicking was just driving me nuts while driving.
Rear clunking noise when driving EvoXSwimmer Issues | Warranty | Recalls / TSB 4 07-24-2017 03:03 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 04:10 PM
Clunking noise after installing springs JACK 8URT0N Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-28-2015 03:37 PM
Whiteline LCA's light clunking noise FR-S Matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-20-2014 09:22 AM
Clunking noise when on and off throttle and bumps DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-23-2014 11:18 PM
