Old 05-16-2015, 02:08 PM   #43
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by Stormalong View Post
So I installed the Procede yesterday, but it doesn't seem to be working.
When I've got the software running, the yellow cell at the bottom left never moves, which indicates that the throttle tap isn't working. So I re-did the throttle tap, but it still doesn't work. What is confusing me is that there is a cyan cell that DOES move when I rev the engine. Also the numbers for "Throttle" and "Raw Throttle" in the top right panel do change when I rev the engine, which would suggest that the throttle tap is working.
Anyone have any insight here?
At the top left there's an RPM and a load index. Are they reading anything? RPM should read your current RPM with the engine on and load should be the % of throttle you put on the gas. So if you tap it a little bit it should jump to like 15-20%.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 05-16-2015, 03:31 PM   #44
DAEMANO
Time Traveller
Originally Posted by Sojhinn View Post
So just switched back to 91 this week. The map fits 91 so much better. I think I need to modify the map for e85. @DAEMANO @WRB5titch what do you think?
We're both in need of harnesses. @WRB5titch tried adapters but no dice. We'll need some TLC from @Shiv@Openflash
Old 05-16-2015, 03:33 PM   #45
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Sounds like you need to resolder the female adapter.
Installed Mods:
Old 05-16-2015, 04:37 PM   #46
WRB5titch
Drives: WRBrz
yep, that's exactly what we need to do.
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 05-16-2015, 06:20 PM   #47
Stormalong
Drives: Firestorm FR-S AT
Success! The throttle tap was fine.
I have one of the very early kits, my throttle switch doesn't have a 3.5mm jack, its just a straight wire all the way to the controller. So I just cut the wire, cut the jack off the Procede harness and connected the wires. But the ESC wire actually has two conductors, the inner red wire (on mine anyways) and the outer shield wire. I had connected to the red wire, but it wanted to be connected to the shield wire.
What really threw me off was the first post in this thread explicitly says the yellow cell should move if the throttle is tapped correctly, but my yellow cell (still) never moves. There is a blue cell that moves around. @Shiv@Openflash you might want to update that.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
The Following 3 Users Say Thank You to Stormalong For This Useful Post:
DAEMANO (05-16-2015), raven1231 (05-17-2015), Sojhinn (05-16-2015)
Old 05-16-2015, 09:13 PM   #48
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
Success!
And? How is it with the PROcede?
Talus1 is offline   Reply With Quote
Old 05-17-2015, 05:50 PM   #49
WRB5titch
Drives: WRBrz
so got the procede working...sport map is pretty vicious...gonna give the standard map a swing, but i've got a feeling we're gonna need to find a middle ground between sport and standard for e85 users.
The Following 2 Users Say Thank You to WRB5titch For This Useful Post:
DAEMANO (05-17-2015), raven1231 (05-17-2015)
Old 05-17-2015, 05:58 PM   #50
Sojhinn
Sojhinn's Avatar
Yeah. I'm on 91 for a while. So you guys are going to have to tweak things.
Installed Mods:
Old 05-17-2015, 06:14 PM   #51
DAEMANO
Time Traveller
Not a tuner here, so if @Shiv@Openflash would like some feedback about the e85 tune/map, I'm sure @WRB5titch and I would be glad to give it. Going to take 5titch's approach on soldering the jack. If that doesn't work an email directly to Shiv on the harness will be next. In either case, I'm sure the e85 tune just needs some dialing in to accommodate for all that extra e85 power, I just don't feel comfortable doing it all by myself. Lot's of helping hands on deck for the man of the hour though.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 05-17-2015, 06:15 PM   #52
Sojhinn
Sojhinn's Avatar
I saw shiv working on it. I've got the gist of it but I can't test it.
Installed Mods:
Old 05-17-2015, 08:05 PM   #53
Sojhinn
Sojhinn's Avatar
Alright guys. I decided to modify the Procede map. This map tries to protect the engine at low rpms to not engage the phantom. It also ramps up slower than the standard map, but it is active across more of the RPM band.
Its a mix and match type of map. I do not take responsibility if you screw things up or my map screws something up. I drove this around on my car on 91 and it felt great, not sure about e85.
https://drive.google.com/file/d/0B1RAtTeA3nZfOGlpOVl1clRSUFE/view?usp=sharing
Give it a shot someone?
Edit:
Link for tapatalk: https://drive.google.com/file/d/0B1R...ew?usp=sharing
Installed Mods:
The Following 4 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (05-17-2015), Gums (05-30-2015), Shiv@Openflash (05-17-2015), WRB5titch (05-17-2015)
Old 05-17-2015, 08:48 PM   #54
WRB5titch
Drives: WRBrz
So I just did a quick run to town and back with this map. Definitely liking it. It's the middle ground between standard and sport i was looking for.
Boost comes on nice and smooth, feels pretty natural on e85 when you engage boost in 5-6 doing 70mph. But you still get that kick when esc engages at lower speeds. Boost doesn't feel as vicious as Sport map, but it's definitely noticeable, which I love. Comes on a bit later, at around 40% throttle instead of sport map's 35%.
Standard was a bit too tame for me. I love how strong sport kicked in, but it's difficult to drive smoothly and could be a handful in the rain. @Sojhinn's map is pretty damn close to the sweet spot for e85 imo. You still get the kick (to a lesser degree) of the sport map and control of the standard map.
win win in my book.
Edit:
DAEMANO (05-17-2015), Sojhinn (05-17-2015)
Old 05-17-2015, 08:49 PM   #55
DAEMANO
Time Traveller
Thanks @Sojhinn and @WRB5titch . You guys are a huge help.
Old 05-17-2015, 08:52 PM   #56
Sojhinn
Sojhinn's Avatar
PROcede ESC User Software!
win win in my book.
Thanks for the heads up @WRB5titch. If you want me to switch anything up let me know.
On a side not Let me know if the phantom engages at 2500 rpms with low load( 5th or 6th at around 60 mph) It shouldn't bog or really activate boost but it may activate prespooling.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (05-17-2015), WRB5titch (05-17-2015)
What does your user name mean? Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 355 05-01-2016 09:52 AM
OFT: New firmware and new user software Shiv@Openflash Software Tuning 9 10-15-2014 03:45 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 10:17 AM
user tags scottmcphee Site Announcements / Questions / Issues 3 04-11-2013 04:15 PM
User name trueno86power Site Announcements / Questions / Issues 7 11-28-2012 01:48 AM
