Old 05-07-2015, 11:14 PM   #267
Trphotomediadotcom
You open flash manager is rearly old
current ver is 1.19.x
best go to the http://www.openflashtablet.com/Autom...ads/index.html site and download the current version manually and install, you will also need to update the template file from same page and maybe your tune files as well
The version I am running is the one I just downloaded today from the website.
Webistes syas v1.10 - http://www.openflashtablet.com/produ...ads/index.html
Trphotomediadotcom is offline   Reply With Quote
Old 05-07-2015, 11:21 PM   #268
D_Thissen
D_Thissen's Avatar
This one says V1.19.0. http://www.openflashtablet.com/Autom...ads/index.html
Old 05-07-2015, 11:23 PM   #269
Trphotomediadotcom
Originally Posted by D_Thissen View Post
I will give it shot and report back. Thanks for link.
Old 05-07-2015, 11:31 PM   #270
D_Thissen
D_Thissen's Avatar
No problem
Old 05-07-2015, 11:40 PM   #271
Trphotomediadotcom
No problem
And it worked. Woot
Old 05-07-2015, 11:46 PM   #272
steve99
Drives: FT86
And it worked. Woot
update the template file as well other wise logging and display might be weird. flashing will be ok though
Old 05-07-2015, 11:47 PM   #273
Trphotomediadotcom
Will do. Thanks for the help guys.
Old 05-08-2015, 08:50 AM   #274
Wyattkb
Drives: 2014 Whiteout FRS
Originally Posted by Wyattkb View Post
Anyone having trouble loading saved Logs? When I try to open it in OFM it just freezes. It was a 20 minute run.
Bringing this back up because I am still having the same issue. Suggestions?
Wyattkb is offline   Reply With Quote
Old 05-08-2015, 09:09 AM   #275
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Either reinstall OFM and see if that helps or make smaller log files. It's incredibly annoying...
Old 05-08-2015, 09:52 AM   #276
steve99
Drives: FT86
Delete all prevoius logs created on older versions of OFM or oft firmware.
then take new logs as other guys said its now limited to 20 minute logs and you must hit save and name each log, even if you hit the 20 minute timeout it does not appear to autosave log.
Old 05-10-2015, 01:51 PM   #277
nexusatm
nexusatm's Avatar
Drives: GT86
Hello! Can i use OFT FFS like heel toe? If yes which parametrs i must to use? Thanks!
nexusatm is offline   Reply With Quote
Old 05-10-2015, 05:28 PM   #278
steve99
Drives: FT86
FFS is flat foot shift
ie hold throttle flat while shifting, still need to use clutch
see OFT TIPS link below for parameters.
Auto Blip on down shift is not implemented on OFT roms would require additional rom program code.
Old 05-16-2015, 07:04 PM   #279
drift86
Drives: GT86, 22 BRZ
Just got my OFT recently
Quick question.
What's the easiest/safest way to modify a BIN file from one series to another? eg. from A01I to A00G?
I'm wanting to apply this to my car. http://www.ft86club.com/forums/showthread.php?p=2190727
drift86 is offline   Reply With Quote
Old 05-16-2015, 08:48 PM   #280
steve99
Drives: FT86
Quick question.
copy and paste all the tables unfortunatly.
open both roms on romraider and work through the changed tables, you can usually copy and paste entire tabbles, just check the axis have not been changed if so change them manually.
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
