Old 05-05-2014, 06:31 PM   #99
mike the snake
If the clutch is adjusted too tight, then the TOB is being spun ALL the time, and it'll die quickly. It's only meant to spin momentarily while you push the clutch in.
You want some dead band, maybe 1/2 inch of pedal push before you feel anything happen in the clutch.
Our cars have another extra spring that makes it feel different, but you can feel when the clutch starts to engage if you slowly push the pedal.
Old 05-15-2014, 03:10 AM   #100
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
I got the chatter too but works fine
Just wish car didn't sound like a diesel truck at idle
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-21-2014, 10:45 AM   #101
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
I wanted to show everyone the latest Stage 2 Clutch Design from Exedy, which is different from their website.
Here's a few pictures I took today, in stock
spdbydesign is offline   Reply With Quote
Old 06-23-2014, 04:12 PM   #102
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Dude did you seriously have to bump every single thread in this subforum with Exedy in the title?
Old 06-23-2014, 04:29 PM   #103
spdbydesign
Tut, there is confusion regarding what is to be expected product wise, as Exedy shows a different clutch on their website.
For the sake of future documenting, until they update their website, I'm simply updating the Stage 2 referenced threads.
Old 06-23-2014, 05:10 PM   #104
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Well at least he didnt put a sbd hat in there.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 05-16-2015, 02:49 AM   #105
zERoTu
Drives: 1st RBv2 10 Series FRS
Omg. I have the same problem with the ACT clutch. It's driving me insane while trying to park. Any update with act with their warranty? Because I almost don't feeling like driving my car anymore because of this problem.
zERoTu is offline   Reply With Quote
Old 05-16-2015, 03:24 PM   #106
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Just contact ACT. Every single aftermarket clutch seems to be having this issue on this platform. Even Exedy, the OEM, had to redesign their upgraded clutches.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-17-2015, 01:30 PM   #107
zERoTu
yah i have, they told me to take it off take pictures and if need send it back for testing. but then my car will be out of commission for the duration, which sucks cause its my daily might just order a exedy updated one for the time being.
Old 05-17-2015, 02:58 PM   #108
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I've got the lateset Exedy 2 clutch (the 3-puck style) which isn't what SBD posted above. So far it seems good. No lockout issues ever. I only have 2 complaints.
1. I installed the lightweight flywheel when I installed the clutch. Chatter is a bit annoying. No problem with clutch in or in neutral though. It is most annoying in 5th gear it seems. Particularly when it is anywhere below 3000rpms and your foot isn't on the gas. Exedy nolonger offers their LW flywheel with their S2 clutches now IIRC.
2. When I installed the clutch I had problems with it slipping during launches (4k drops.) I lowered the clutch pedal and this issue 90% disappeared. I think I may need to lower the clutch pedal a bit more to fully cure it. IMO the clutch wasn't fully releasing/engaging at stock pedal height. Nobody I've talked to has had this problem. I have had my installation double checked by a few other techs and they don't see anything wrong. OEM throwout, pilot bearings and heavily greased.
Old 05-17-2015, 07:31 PM   #109
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
This seems contradictory. If you had to lower the pedal, you would be limiting the overall travel. If it wasn't releasing earlier, it should definitely not be releasing after lowering it.
What process did you follow to adjust the pedal height? Did you change fluids?
JDKane527 is offline   Reply With Quote
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Lets talk about clutches charged86 Engine, Exhaust, Transmission 26 08-30-2013 04:13 PM
Clutches... Synack Engine, Exhaust, Transmission 19 12-16-2012 04:15 PM
Exedy BRZ specs sheet ayau BRZ Photos, Videos, Wallpapers, Gallery Forum 2 11-07-2012 09:56 PM
