Old 04-06-2015, 04:22 AM   #155
joe strummer
Can someone tell me what I'm missing? I replaced the cylinder, and the clutch engagement is more abrupt. It was harder to feather the clutch, like when accelerating from stopped on a steep incline. My son drove the car after the install and before we spoke about it, said the same thing.
I've since gone back to the stock cylinder, and am pretty happy with it.
What positive difference(s) am I supposed to be noticing?
joe strummer is offline   Reply With Quote
Old 04-06-2015, 10:51 AM   #156
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Did you adjust the height/engagement point as well?
Old 04-06-2015, 03:50 PM   #157
joe strummer
No, I didn't, but I don't see how that would affect the abruptness of the engagement.
I see the OP and others complained about the amount of travel between the touch point and full engagement being too much. The mod certainly fixed that, but too much for me.
I also see I should have done a bit of research before posting.
Old 04-06-2015, 04:59 PM   #158
That was it. More abrupt engagement means more precise and repeatable modulation/feathering of the clutch.
Question: I was under the impression that my description of the difference is pretty clear in the OP. The initial thread I referenced contained quite a bit of debate and explanation. Do you feel the objective isn't clear? I don't want people wasting their time and money.
edit: oh, duh. I see your follow-up. Ah, well. Sorry it didn't work out for you.
Old 04-10-2015, 04:43 PM   #159
brianhj
Drives: 2017 Camaro 1SS
Can I do this mod if I am FI? I thought I saw this mentioned in the thread
brianhj is offline   Reply With Quote
Old 04-10-2015, 06:37 PM   #160
It will increase the pedal force about 17%. That's significant.
It's not a matter of FI specifically, it's whether or not you are running a heavier aftermarket pressure plate.
What's your clutch setup now?
edit: saw your post in the Sprintex thread and put it together. Again, as long as you're running the stock clutch and you don't mind the heavier pedal, you're fine.
Read the OP carefully. This will make your clutch engagement sharper; more sudden. Be sure this is your goal.
brianhj (04-11-2015)
Old 04-30-2015, 11:31 AM   #161
acetothermus
Drives: Flying in a Blue Dream
You should <ahem> Czech it out!
edit: subscribing so I can do this mod once i get my car. I've read way too much about the clutch engagement being vague and that's the last thing I want on a dd.
acetothermus is offline   Reply With Quote
The Following User Says Thank You to acetothermus For This Useful Post:
Ultramaroon (05-14-2015)
Old 05-08-2015, 04:31 AM   #162
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Finished. Go for it.
Hey, i just wrote up my experience following your guide plus how to replace the clutch line. Want to combine? I'll get everything up with pics tomorrow.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 05-08-2015, 11:17 AM   #163
SamS
Drives: '13 BRZ, '99 Forester,'06 Duc S2R1k
I'm just reading through this thread and would like to do this mod, but I'm confused with all of the part numbers thrown around on the first page and the 2 different castings. People are saying that we want AutoZone Part# 900061 with the angled banjo retainer, but the pic in the instructions doesn't look angled?
EDIT: Looking at the photos next to each other like that, I can see how the angled mount would be preferred to avoid stressing the hose, was the photo in the instructions actually the stock slave or the "incorrect" replacement?
SamS is offline   Reply With Quote
Old 05-08-2015, 12:42 PM   #164
ck-GT86
ck-GT86's Avatar
That looks stock to me. I used the Subaru replacement, banjo wasnt stressed when i put on a new clutch line.
. ck
|| My Build Thread ||
Old 05-08-2015, 02:05 PM   #165
. ck
I'm sorry, guys. The photos show the wrong part. I've been meaning to go back and update the photos but got lazy. The Autozone 900061 and equivalents are the correct part with the angled guide. They look and fit exactly like the factory unit.
SamS (05-08-2015)
Old 05-08-2015, 02:09 PM   #166
. ck
I'm open to anything that helps the peeps. What do you have in mind?
Old 05-14-2015, 01:16 AM   #167
ck-GT86
ck-GT86's Avatar
See my next post.
|| My Build Thread ||
The Following User Says Thank You to ck-GT86 For This Useful Post:
Old 05-14-2015, 01:45 AM   #168
@ck-GT86, that's great! Mind if I quote you at the end of the OP to get it all up front?
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
