go_a_way1
Old 05-13-2015, 06:31 PM   #8807
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by luckykevin View Post
Interesting. How to buy this kit?
Pm Fenton or Robftss. They handle production and distribution. However this is not their main job, so it takes up to a year to get a kit now, due to demand.
Originally Posted by Target70 View Post
I think you would need a bypass for the ESC, under it's own power you only get a max of 2psi at redline. If paired with a large turbo (= lots of flow at high rpm) It would become a restriction.
I forgot about that. Good point. So it would give you "some boost" until you could switch over to "full boost". Hmm.
Old 05-13-2015, 06:43 PM   #8808
killy
Drives: BRZ Limited
Originally Posted by Shutter View Post
lots of hope and prayers...you have to get on "the list"
speaking of the devil, any updated list will be very appriciated, I sent my order request on september 2014, almost 9 months have passed.
a lot of times i have seen the request, but only few times an answer
An ordered list will be the best.. at least everyone is going to get an idea of the remaining wait time ahead of him/her.
Someone has to have something like that i presume...
please?
killy is offline   Reply With Quote
Old 05-13-2015, 06:50 PM   #8809
LucidMomentum
please?
Rob doesn't like to send out ordered lists. People start complaining, trying to buy people's spots in line, etc.
Best hope to get one sooner is to buy one used. My friend did that.
Old 05-13-2015, 07:03 PM   #8810
killy
Drives: BRZ Limited
well I can sell mine for an outrageous price
right now I think the complaints are even worse, if i knew I have 5 people (or 25) ahead of me I will behave accordingly.
Old 05-13-2015, 07:44 PM   #8811
tyrantcf
Drives: '16 WRX, CBR1000RR
Funny thing, demand was super high when I got mine used. After all the people complaining about the wait, I got the kit like a week after the sale thread went up, and not even for the sellers full asking price.
Bottom line, everybody likes to speak like they'd buy one right now, but when it comes time to pony up...
But it was worth every penny
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
continuecrushing (05-13-2015)
Old 05-16-2015, 03:34 AM   #8812
luckykevin
luckykevin's Avatar
Drives: 2013 Subaru BRZ Automatic
Subaru BRZ Automatic, World Rally Blue , Innovate Supercharger, AVO Stage 1 Turbo kit, 4.556 FinalDrive, STI Big Break, DeliciousTuning
luckykevin is offline   Reply With Quote
Old 05-21-2015, 12:08 AM   #8813
Winjr
Drives: 2013 Subaru BRZ Premium
Installed a flex fuel kit, had ecutek reflashed accordingly.
ESC boost + e85 = Wheeeeeeeeee!
Winjr is offline   Reply With Quote
The Following 2 Users Say Thank You to Winjr For This Useful Post:
DAEMANO (05-21-2015), TM (05-21-2015)
Old 05-21-2015, 03:42 PM   #8814
stevo585
Drives: White 2014 BRZ
^ this makes me want it even more
So... any update on when the next batch is coming in? Seems like its been a few months...
stevo585 is offline   Reply With Quote
Old 05-27-2015, 12:27 AM   #8815
j_Zer0
Drives: Asphalt FRS 2014
It would indeed be nice if this thread could be updated every time a batch goes out. Since there are good reasons not to post an updated waiting list, could we instead do something like: last time a batch of kits went out, expected time frame for next batch, etc. This would give us a way to track progress and adjust our expectations as things play out. What do you think @fenton?
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
j_Zer0 is offline   Reply With Quote
Old 05-27-2015, 12:28 PM   #8816
fenton
I can do something like that. A batch hasn't went out for a while now as there was another shortage of parts. Plus i think Rob is waiting to see how Shiv's procede controller is working out, first people had some issues so that needs to be ironed out first.
I will update here once the next batch is ready to ship.
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
j_Zer0 (05-28-2015), stevo585 (05-27-2015)
Old 05-27-2015, 04:41 PM   #8817
TM
TM's Avatar
Drives: DGM BRZ 6MT
Those of you with the procede controller, would you recommend using the included taps or soldering the wires together? I feel like soldering is better, but I don't have much experience doing it.
TM is offline   Reply With Quote
Old 05-28-2015, 05:38 PM   #8818
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
My recommendation:
If you can solder do it.
If you can't or don't trust your skills... Use the tap.
You can make things worse if you screw up soldering.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
TM (05-28-2015), zc06_kisstherain (05-28-2015)
Old 05-28-2015, 09:11 PM   #8819
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by Shiv@Openflash View Post
Just talked with Rob. For v1 guys:
Using a voltmeter measure the voltage of both wires going into the microswitch. With the switch off (throttle not pressed):
One wire will read ~0v.
The other wire will read ~5v.
When the switch is ON (throttle pressed):
They will both read ~5v.
Cut/desolder the wire that carries the switching signal (i.e., reads 0v with switch OFF). Tap/solder this wire on to the black wire on the Procede harness. That's it. Everything else (12v, GND, Throttle and Crank sensor wiring) is the same as what we did on your car.
I only see one wire going into the wot switch. Am I looking at the wrong switch?
Old 05-28-2015, 09:36 PM   #8820
Sojhinn
Sojhinn's Avatar
He's talking about tapping the wires going into the controller in the engine bay. Someone else tapped the switch wire. Not sure who.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
