Southern California SoCal
Old 05-13-2015, 03:44 AM   #1
iarefluffy
iarefluffy's Avatar
Drives: CWP series blue brz
Socal dealers on aftermarket headers?
has anyone had a problem with dealers denying maintenance or warranty claims on their cars for aftermarket headers that were installed.
about to get a catted UEL header.
Also, on a slightly related sidenote. my car has been a little iffy on the shifting. I usually drive my car out of the driveway after 2-5 minutes of warming up. When i drive up the street and it comes time to shift into second, most of the time i get resistance. like a bit of fight, a very audible clunk and i can feel the shifter trying to click into the gears. but if i shift a little faster, i feel like im forcing it in. Almost always happens when i shift at 2k RPMs in second.
The sound isnt quite like the grinding you hear if you were to just move your shifter towards neutral without pushing in the clutch when youre cruising.
i read here here about it being shifter rattle while in gear that causes the problem of the gear grinding but i am uncertain.
I have a crank pulley kit (water pump, crank pulley, and alternator) but the issue has been happening for roughly over two weeks and i had my crank pulley installed during the first week of april
iarefluffy is offline   Reply With Quote
Old 05-13-2015, 04:22 AM   #2
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
have you change you trans fluid everyone seems to like motoul 300
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
Old 05-13-2015, 03:09 PM   #3
iarefluffy
iarefluffy's Avatar
No I haven't yet but I'm considering it!
Sent from brick
Old 05-13-2015, 03:42 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Sent from brick
yeah, swap out the fluid for Motul...you'll be happy you did
And if you're local, you can pick up or get it installed too.
Old 05-13-2015, 04:59 PM   #5
swarb
And open saturdays!
Remember while your coolant is somewhat warm, your oil is barely above ambient and your transmission fluid is completely cold.
I reverse out of my driveway and then go into first, and stay in it for an additional 3-5 seconds(before going into 2nd) so the oil circulates in the transmission and when I shift into second it goes in much easier than not giving it those extra few seconds. It is a little stiff the first shift of the day, but after that, it is all good.
I have a 2015 also, and when I swapped fluids to motul at 5600(currently at ~10k) it helped quite a bit.
The Following 2 Users Say Thank You to swarb For This Useful Post:
continuecrushing (05-13-2015), qijian (05-14-2015)
Old 05-17-2015, 01:36 PM   #6
BobbyDee
BobbyDee's Avatar
Drives: 2013 FRS 6MT
Originally Posted by swarb View Post
And open saturdays!
when you say quite a bit, is it drastically noticed?
BobbyDee is offline   Reply With Quote
OIL change in SoCal Dealers Khánh Southern California 9 06-13-2014 06:23 PM
Socal Scion Dealers....any with NO markups? luscious Southern California 56 12-03-2012 02:58 AM
SoCal FRS/BRZ dealers to Avoid and buy from Giccin Southern California 116 10-16-2012 03:21 AM
SoCal (San Diego, LA, Riverside, etc) best dealers? streetwaves Southern California 11 07-16-2012 01:24 AM
dealers in SoCal that have the BRZ? helloimgil Southern California 1 05-12-2012 02:09 PM
