Old 05-12-2015, 04:16 PM   #43
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Originally Posted by wootwoot View Post
I got under the car and checked every single bolt and found nothing amiss. Still having this issue. My tech stream cable is inbound from overseas. As soon as it arrives I will do a re set and report back with any change. If that doesn't work I may just go back to stock suspension, or a spring strut combo.
Originally Posted by ZHoward View Post
The same question, really confused me, today I just drive on canyon road with new suspension, almost every turn the traction will come, but I'm not driving too fast...
Originally Posted by JS + BRZ View Post
My VSC has been kicking in like crazy after installing Tein Street Flex only during hard canyon runs. It was pretty bad in the beginning but seems like it has settled down a little bit. Not too sure but when I first got the coilovers, I had set it on the softest damping set up both front and back. With that setting, my VSC was kicking in almost whenever I took the turns fast. Switched my damping set up to 6 clicks from the full stiff, the VSC kicks in less.
I have -2 camber on all four corners.
It shouldn't be an issue at the track though since we all just do the pedal dance.
This is my ride height:
It sounds like we've all gotten alignments and we are still experiencing this issue. And we can't all have bad ball joints and other suspension (I know for a fact I don't, as I just replaced mine with the Whiteline roll center kit and had @Ishii Motors do the install).
I'm chalking this up to VSC just not knowing how to deal with lowered ride height (I still have a 2 finger gap between my tires and fender). I don't see any other explanation, except that maybe the way increased grip from our tires is messing with VSC.
So on that note, what tires and sizes are you guys running? I'm 255/35/18 Dunlop Direzza ZII (super sticky)
sittinSideways is offline   Reply With Quote
Old 05-12-2015, 04:35 PM   #44
ZHoward
ZHoward's Avatar
Drives: 2013 brz limited
I'm chalking this up to VSC just not knowing how to deal with lowered ride height and(I still have a 2 finger gap between my tires and fender). I don't see any other explanation, except that maybe the way increased grip from our tires is messing with VSC.
255/40/17 federal 595 rsr
ZHoward is offline   Reply With Quote
Old 05-12-2015, 05:04 PM   #45
ZHoward
ZHoward's Avatar
[ame="http://youtu.be/PBkGQoqJ20U"]http://youtu.be/PBkGQoqJ20U[/ame]
this is short video to show i drive on canyon road with my friends, the sounds of VSC , and my speed is really slow when i turn in
Old 05-12-2015, 05:41 PM   #46
JS + BRZ
Drives: 2010 MS3
245/4017 Hankook RS3
17x9 +35 RPF1
Old 05-12-2015, 05:42 PM   #47
JS + BRZ
Drives: 2010 MS3
You can go faster and fight through VSC. haha
Old 05-12-2015, 05:44 PM   #48
ZHoward
ZHoward's Avatar
Traction brake and slow my car😭
Old 05-12-2015, 05:45 PM   #49
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Amazingly we have no issues with any of the cars we've setup on coils. Probably setup 50-100 cars so far.
Our Wheel to Wheel Spec86 Cup race car runs Continental Slicks and uses Bilstein B14 coils. Our Project BRZ runs KW V3 with either Continentals Slicks or Toyo RA1 for the street. No VSC issues on either of those either on track or off.
-mike
AZP Installs is offline   Reply With Quote
Old 05-12-2015, 05:47 PM   #50
JS + BRZ
Drives: 2010 MS3
I know. I was just kidding. I do ACH->Mt. Wison run every Thursday night. It's annoying but it's all good. I usually turn in at the speed that wouldn't kick in VSC and get on the throttle earlier.
Old 05-12-2015, 05:50 PM   #51
JS + BRZ
Drives: 2010 MS3
-mike
They are using VSC at the track!?
Old 05-12-2015, 07:06 PM   #52
cjd
cjd's Avatar
Drives: 2017 BRZ
I had about -2.3° on the steering angle sensor to correct after installing coilovers and getting an alignment. It was included in the alignment, but I wonder if that's true for everyone?
Old 05-13-2015, 12:27 AM   #53
redlined600
redlined600's Avatar
Drives: Fr-s
So wasn't your steering wheel crooked then?
redlined600 is offline   Reply With Quote
Old 05-13-2015, 01:03 AM   #54
wootwoot
Drives: FRS
Please tell us more about this. Can your wheel be straight but the steering angle sensor still be off?
Old 05-13-2015, 07:31 AM   #55
AZP Installs
On track we turn off the VSC via the buttons, no pedal dance.
On the street we leave the VSC engaged. No issues on the street at all. Along with the 50+ other BRZ/FRSs that we've setup for street use.
Perhaps one needs to look at the height and setup to see why the VSC is acting erratically. It could also have to do with the driving style as well, although I would doubt that highly.
Generally if the car is setup properly and you have a grippy tire setup you will be less likely to trigger the VSC actually.
-mike
Old 05-13-2015, 08:24 AM   #56
cjd
cjd's Avatar
Drives: 2017 BRZ
It seems so?
For all I know it was after the alignment, and they corrected it with this. It was tracking straight with the wheel straight when it went in despite bad toe issues on the left side (right was fine? Go figure) This info was in the stack of paperwork they gave me. If there is a physical connection to the rack, this seems separate from the wheel being centered. Unfortunately, I'm at as much of a loss as you are.
C
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
