#561 |
Drives: GTS86
I'm twisting the rod but the pedal isnt lowering itself. The nut I unscrewed is 17mm. I can't find a 12 or 14mm nut on a rod coming from the firewall. Am I loosening the wrong nut ?
How many time did you guys twist the rod in a full circle ? I've tried about (5) 40% spins and gave up after seeing no movements on the clutch pedal. When holding on to the sensor, does it automatically close up the gap where the pin is or do I have to hold the sensor while lifting the pedals to close the gap if you know what I mean? I suck at this & to scared to try anything until I fully understand...
#562 |
Drives: Taking the bus
I did the adjustment, it took < 10min, the clutch pedal is now 1mm below the brake pedal. The clutch feels much better. Thanks for the writeup!!
#563 |
Hit the road and I'm gone
I did this adjustment five months ago. The worst part was standing on my head. No problems, everything works great and I did not have to adjust the cruise control switch. I suspect that I got lucky, but I would not move the position of the switch until sure that it was necessary.
To emphasize, I have had zero problems with slippage or anything else, despite no adjustment to the CC switch.
Slip, slidin' away.
#564 | |
Drives: '22 BRZ
#565 | |
Drives: Neptune GR86
I'm not sure if that's how it's supposed to be either.
#566 | |
I realized this a while back but let it go. It would require manufacturing a custom lever and maybe a longer pushrod for the master cylinder. And remember, it's not the same as adjusting the clevis because we would end up with that clutch pedal way up off of the floor again. Uggh.
#567 |
Drives: 2015 FRS 6MT
"Pedal height? How much can that possibly help this clutch situation..."
Silly me, apparently the answer is "Holy Crap, This is way better!" I had already taken the factory assist spring off of the pedal, so I don't know what adjusting pedal height feels like on its own. However I can assure anyone reading this that removing that spring and adjusting the pedal height will improve the clutch action dramatically. Why did the car not come like this from the factory?! |
#568 |
Alexandrino_Auto
Drives: series.Blue
I removed my clutch spring, and I love the improved pedal feel, but I can't stand the slop at the top of the pedal stroke. Will this adjustment remove the slop, or simply lower the entire assembly? As it stands my clutch pedal is dead even with the brake pedal.
The Shadetree Project: I turn wrenches
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | shiro (05-12-2015) |
#569 | |
#570 |
Drives: 2013 Scion FR-S, 2014 Lexus IS350
FT86'rs,
I've been following this forum for a year now. Though, I would like to know what fellow peers have done with a high performance clutch (stage 4 and up). Do people also make the adjustment for heavy pressure plates like the Exedy Hyper Single, Clutch Masters FX400, etc.? Input on high performance (heavy pressure plate) clutch adjustments would be nice. Most of this thread seems to be focused on stock or lower stage clutches and not 400whp+ cars. Anyone with this experience would be a great help. Thanks!
#571 | |
Alexandrino_Auto
Drives: series.Blue
#572 | |
Drives: 2014 BRZ Limited (DGM)
I think *any* spring is going to introduce an artificial, non-linear feel to the clutch. A softer spring might serve the function of removing the "slop" at the top of the pedal, but at the expense of that unnatural feel, albeit not as severe as the stock spring. Personally, the pedal slop does not bug me nearly enough for me to want to go back to having a spring on there. |
#573 |
Drives: Asphalt FR-S MT
My advice is to give it a few weeks with no spring before you make any decisions. I tried to put the stock spring back in after 2 days because of this but lost patients as it's even harder to put back in. Glad I didn't put it back cuz it's been 2 weeks and I love it now
#574 | |
Alexandrino_Auto
Drives: series.Blue
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
