Old 05-23-2012, 11:40 AM   #1
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
HKS SEQUENTIAL TRANSMISSION for the 86
I know this has been touched on in the HKS posts but i figured if should have its own thread. Many of us are interested in upgraded auto trans in the stock and aftermarket form and im sure if anyone has seen the HKS videos they know that the setup they are running is amazing! If anyone has any additional information about this setup for the 86 please post. thanks!
Generic info here: http://www.hks-power.co.jp/en/produc...ion/index.html
Video on the system its self: [ame="http://www.youtube.com/watch?v=QCLCR93RXvs"]HKS SEQUENTIAL TRANSMISSION - YouTube[/ame]
Sights and sounds on the 86 performer : [ame="http://www.youtube.com/watch?v=g83C15ZkHpY"]€HKS 86€‘Supercharger spec test run/‚ƒƒ‘ƒƒƒƒ‚ƒƒ•˜‹‹• - YouTube[/ame]
Through our many years of motor sport activities, have felt the need for the development of a transmission that can be used to accurately transfer engine torque at even the highest levels such as drag racing. Development from years of experience in the drag, drift, time attack and circuit racing, helped us design and develop fine transmission. We have done enormous testing and the production now take place "in house" to ensure the feedback from racing to directly into the production team.
Dog Engagement System For Strength And Reliability
A dog engagement system offers more power transfer capacity compared to synchronic systems giving added strength and reliability and with correct driver operation, fast shifting is possible.
Helical Gears Used To Reduce Gear Noise While Maintaining Strength.
High strength materials are used for the gears combine with a helical gear design which slants the teeth at an angle. This allows more gear area to mesh which improves strength and also significantly reduces noise that is associated with spur gear type transmissions.
High Strength And Durability from a Specially Designed Case.
High Strength/Durability
High strength and durability can be achieved over kits which include specially designed case. This case was redesigned to give maximum strength and efficiency as for each part is well-managed.
Efficient & Easy Installation
Efficient and easy installation is possible as the whole unit is assembled designed with minimal modification to the body or chassis necessary for installation.
Original Design Sequential Transmission
Using a barrel cam which converts the vertical shift pattern to that of an H pattern has allowed HKS to create a sequential transmission based on a reliable manual transmission base. Quick and accurate gear changes are now possible with particular attention paid to the weight and stroke of each gear change to give a racing feel to your car.
6th gear of H pattern transmission has sequential system which creates the 5-speed sequential transmission with direct gear ratio of 5th gear. This type of transmission is very practical for drag races and drift driving; however, shifting to a final gear is usually a problem to achieve the maximum speed. Low gear ratio type HKS Sequential Transmission is available to solve this problem.
Overhaul Service is Available
For the optimal performance of HKS Transmission series, regular maintenance is required. HKS provides professional maintenances using in-house transmission bench and other necessary overhaul equipment. Maintenances and overhauls are implemented after detailed examination of a transmission's condition.
* It is recommended to maintain (or overhaul) HKS Transmission every 1,000 to 3,000km. If neglected, gears and/or dog parts may be damaged.
* HKS GEAR OIL G-1200 must be used.
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-23-2012, 02:24 PM   #2
ttknf
Drives: 350z Nismo, CBR1000RR
Looks like either a Hollinger produced box or an OS Giken box. HKS likes OS Giken and they've used them for their transmission offerings in the past (and with good reason - OS boxes are fantastic).
ttknf is offline   Reply With Quote
The Following User Says Thank You to ttknf For This Useful Post:
ESBjiujitsu (05-23-2012)
Old 05-23-2012, 03:14 PM   #3
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Originally Posted by ESBjiujitsu View Post
Many of us are interested in upgraded auto trans in the stock and aftermarket form...
Honestly, unless you plan on building a full race car, the HKS sequential transmission is not you're looking for. It's definitely not an "upgrade" for the auto as they are two different types of transmissions; in order install a sequential in an auto it would require a manual conversion (race sequential transmission still require a clutch), and the ECU would need to be reprogrammed to allow the proper unshift throttle cut and downshift blip. And then there is the fact that even with helical gears, it will still have a noticeable whine... not a big deal with a helmet on, but not cool when tooling around town.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
The Following User Says Thank You to 2fast4you For This Useful Post:
Old 05-23-2012, 03:28 PM   #4
ESBjiujitsu
I myself will be getting a manual but im obsessed with after market sequential transmissions. I understand this is not an upgrade but merely a replacement transmission for a race car type circumstance but that still does not prevent me from being fascinated by the setup in this car Im also curious if there will be hardcore AT upgrades for those wanting more sport but less on the whine from a aftermarket sequential. But to be honest i wouldnt mind the whine one bit i have DD driven a few "race cars" lol. I like the punishment!
The Following User Says Thank You to ESBjiujitsu For This Useful Post:
2fast4you (05-23-2012)
Old 05-23-2012, 03:37 PM   #5
ESBjiujitsu
[ame="http://www.youtube.com/watch?v=HmDmEDgwUzk"]HKS Sequential Transmission in FD RX7 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=YQjt-Z3e0SM"]go4it skyrocker shifting OS Giken Sequential Gearbox - YouTube[/ame]
BADASS MUCH!!!!!!
Old 05-23-2012, 04:29 PM   #6
wcbjr
Drives: 2006 Subaru LGT
Yeah, not gonna happen on any street car.
wcbjr is offline   Reply With Quote
Old 05-23-2012, 04:48 PM   #7
ESBjiujitsu
pair it up with your oil changes LOL!!!
Old 05-24-2012, 07:33 AM   #8
arghx7
Drives: car
this is a dogbox. It has no relation to an automatic transmission in any way. Oversimplifying it a bit: it's for people who have a manual transmission and want skip pushing the clutch pedal in when they shift.
It's not a planetary gearset based transmission. It's not a single-clutch automated manual transmission (like the old BMW SMG). It's not a wet or dry dual clutch transmission either. Even though they can be driven on the street, it doesn't make financial sense for anything but a race car.
Old 05-24-2012, 10:21 AM   #9
Jayde
Jayde's Avatar
This might have been stated already, but I thought with sequential gearboxes, you only use the clutch to get the car going, like a normal manual, but after that you don't need it.
Jayde is offline   Reply With Quote
Old 05-24-2012, 10:59 AM   #10
catharsis
Drives: honda civic si 08
That's true, but you still have to manual shift all the gears with a sequential. It's more like an manual than anything, just don't have to use the clutch.
catharsis is offline   Reply With Quote
Old 05-24-2012, 03:14 PM   #11
Turbowned
Turbowned's Avatar
Do you have $10-15,000 to buy the gearbox alone? If not, /thread.
Old 05-24-2012, 03:30 PM   #12
Dimman
Kuruma Otaku
Dimman's Avatar
Talk to these guys. http://www.xtrac.com/
And bring cash.
Lots of it.
Because racecar.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
ESBjiujitsu (05-24-2012)
Old 05-24-2012, 03:43 PM   #13
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
Might as well go all out and use straight-cut gears...
Then again I doubt these cars will ever be pushing the type of figures that would warrant straight cut gears. BUT IF THEY DID! I'm sure you would want to cut some of the weight you'd incur from having a fat T-case due to Helical cut gears.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 05-24-2012, 04:58 PM   #14
ESBjiujitsu
Im just simply discussing it so why would that = thread.... people discuss cars they cant afford all the time why not a transmission setup.
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) General Topics 51 05-04-2012 07:54 PM
Toyota's Automatic sequential shift davey90 Engine, Exhaust, Transmission 11 12-23-2011 12:18 AM
Transmission Speculation. Dimman Engine, Exhaust, Transmission 70 11-21-2011 10:52 AM
Toyota FT-86 transmission is this it? 4agze Engine, Exhaust, Transmission 65 03-24-2011 08:08 PM
Which Transmission ? gatchaman Engine, Exhaust, Transmission 15 10-29-2009 12:48 PM
