View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 05-11-2015, 11:19 AM   #365
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Originally Posted by FrX View Post
Here's mine. Running an AVO kit at 8psi at the track (TWS here in Texas). Best guess is that I over revved it or the valves floated a bit, and had valve to piston contact. Looks like the piston then shattered and the rod then bet the everliving crap out of what remained.
Holy fuck man!!!
texasbound972 is offline   Reply With Quote
Old 05-11-2015, 11:34 AM   #366
Basket Case
Drives: 2013 Raven fr-s
Damn...were you dataloging by chance? I am curious if it was indeed an over rev or if something blew as a result if the tune or somethig else.
Basket Case is offline   Reply With Quote
Old 05-11-2015, 11:34 AM   #367
Astroboy
Astroboy's Avatar
Drives: None
Is this the first ever failure on an avo charged engine? Who tuned it and what were your mods? Hp/tq and oil temp at the time of this failure? Oil grade?
Astroboy is offline   Reply With Quote
Old 05-11-2015, 12:42 PM   #368
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I really wish I was. This was on my third lap of the first session of the day and I was just starting to get myself, the brakes, and the tires warmed up, and was about to start the first real hot lap.
The car was tuned by James @ HRI. It was pretty conservative. None of the other three cylinders showed any sign of detonation or anything. Previous logging showed solid fueling and no knock. So I doubt it was tune related (except for increased rev limiter).
On the AVO base map (pre-James) it made 250whp at 8psi. Running 5w-30 Redline. Oil temps weren't logged. But as above I was only a few laps in, so they probably weren't very high. Pretty sure it wasn't a lubrication issue.
FrX is offline   Reply With Quote
Old 05-11-2015, 12:55 PM   #369
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Originally Posted by texasbound972 View Post
Just make sure you don't run e85 with that 300V
do u have hard proof of 300v incompatibility or forum speak saying so?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 05-11-2015, 01:04 PM   #370
Astroboy
Astroboy's Avatar
Drives: None
Anyone blown a stock boosted motor yet?
I'm at 250 on a conservative tune as well, but I'm on 5.5 psi. What was your tq power output? And mods if you don't mind me asking? I think you might be the first reported failure with an avo kit.
Old 05-11-2015, 02:51 PM   #371
xxscaxx
Drives: 2013 SWP BRZ
Bad tune and I wasn't even in boost when it blew. My boost was set at 8 psi on e85 which was completely safe from what my tuner told me.
Please list what kit you are running and what tuner.
Hope you get it running again soon.
xxscaxx is offline   Reply With Quote
Old 05-11-2015, 03:02 PM   #372
raven1231
Thought he already did? I thought he said delicious flash and go was the tune.
Old 05-11-2015, 03:12 PM   #373
xxscaxx
ah my bad. I saw King Tut's post and thought he hadn't posted it yet. Didn't realize it was a few pages back - thanks.
Edit - always puts your mind at ease when you read the same kit and tune you are about to put on your car blew up anothers motor
Going with JDL's gt2867r but will be on e85 and F'N'G tune from Delicious.
Old 05-11-2015, 03:31 PM   #374
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Not saying it was but the last photos looked like over rev ones I've seen before. Either the valves float, the rocker arm breaks or the wrist pin pull out of the pistons at high rpm since they are NOT boxed.
Old 05-12-2015, 08:17 AM   #375
Basket Case
From what he described that's my thoug as well. Sucks either which way, but hopefully it was just that and not the motor catastrophically failing because of the strain from boost...
Old 05-12-2015, 05:47 PM   #376
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Mr. Aaron Chambers,
At this time, we have gone above an beyond to support you, taking care of all your requests for updates to your tune and diagnosing idle issues for improperly installed components at no charge to you.
Now you are stating a "bad tune" caused your engine to fail, but you have failed to mention you worked on your own vehicle the day before your engine blew. Did you maybe forget to hook up a vacuum line? That would cause an over-boost condition. You did state that after working on your vehicle it was a LOT faster, which it should have not been any different then before you worked on the vehicle. This leads us to think there was an over-boost condition that you brought on by an installation error.
Also if you really had a problem with the tune, you would have not come back for another tune after your engine blew, correct? But yet you came back for another tune from us on your new engine.
I am sorry but purposely going out of your way to bad mouth us behind our backs, online, on forums, on Facebook is uncalled for. We have been more then generous and at this time we will no longer support your tune, or anything to do with with your vehicle.
Furthermore if you have a problem with your CA-Fi unit please contact the manufacturer directly.
Regards,
William Knose
Old 05-12-2015, 06:39 PM   #377
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by DeliciousTuning View Post
Son'd...
Don't you know, he's a marine! Of course it wasn't his fault. Hoo-rah!
Old 05-12-2015, 07:55 PM   #378
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can you explain to me how you guess that you over revved? You either did or you didn't. You had a rev limiter in the tune I am guessing. Did you do a money shift?
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
