Raceseng | AC Delete Product Release and Introductory Offer
We are proud to introduce the Raceseng AC Delete for the Scion FR-S, Subaru BRZ and Toyota GT86. The AC Delete is for the tuner and racer that is looking to get the most power out of their FA20 engine. Not only is the AC compressor very heavy, it robs precious horsepower from your engine. This high quality kit helps you regain lost horsepower by eliminating the stock AC compressor and condenser. The AC Delete is a direct bolt-on solution comprised of a lightweight billet aluminum base and bracket that features a bearing mounted pulley.
AC Delete - Toyota GT86 / Scion FR-S / Subaru BRZ | 2013+ $355.50 (Introductory Sale) For a limited time only... We are offering a 10% off limited time only introductory sale. Use PURERACECAR as a coupon code during checkout. AC Delete product page - http://www.raceseng.com/ac-delete-to...baru-brz-2013# ![]() MORE POWER - LESS WEIGHT The Raceseng AC Delete helps you regain lost horsepower by eliminating the stock AC compressor + condenser and replacing it with a lightweight direct bolt-on solution. ![]() NO SPECIAL BELT The AC Delete pulley is the same diameter as the OEM pulley and allows you to use the OEM belt. No special belts needed, bolt on and go! ![]() LIGHTWEIGHT To keep weight as low as possible, the AC Delete base, bracket and pulley are precisely cnc machined from 6061 T6 aluminum. ![]() HARDWARE Zinc plated grade 12.9 socket head cap screws are used to fasten the AC Delete to the engine block. The pulley features a high temperature, low friction NSK bearing. ![]() Jarrett Seng | Owner Raceseng.com 610.336.0206 |
| The Following 9 Users Say Thank You to Raceseng For This Useful Post: | ATL BRZ (05-05-2015), buddy32 (05-05-2015), Captain Snooze (05-05-2015), JohnJuan (05-05-2015), Mil_Gates (05-15-2015), mrk1 (05-05-2015), swift996 (05-05-2015), Turdinator (05-05-2015), whataboutbob (05-05-2015) |
#2 |
Drives: 2013 BRZ DGM
Cool product! This might be an obvious question, but I'm not looking at my accessories belt now... Why should someone choose this versus trying to find a belt that just fits with no a/c? Also have you done any dyno testing to show the increase in power to the wheels?
| The Following User Says Thank You to Chad_W For This Useful Post: | fika84 (05-05-2015) |
#3 |
Another question, how does this affect all the electrical items in the car? I know the defroster uses the AC to get the moisture out of the air, will any check engine lights come out of not having the AC wired up anymore?
#4 |
Drives: 2013 Black FR-S
Is it true the A/C de-clutches when it is not in use and when ON but WOT? So the AC doesn't rob power in both those scenarios?
I see this as a weight savings mod and a way to make room for future dry sump!
| The Following User Says Thank You to sw20kosh For This Useful Post: | kiichiro (05-11-2015) |
#5 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Another beautifully engineered Raceseng product.
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | sw20kosh (05-05-2015), whataboutbob (05-05-2015) |
#6 |
Drives: 2015 BRZ Series.Blue
| The Following 2 Users Say Thank You to s30series For This Useful Post: | ATL BRZ (05-05-2015), continuecrushing (05-05-2015) |
#7 |
Drives: 2013 Firestorm FRS
nice! Love Raceseng products!
#8 |
Indeed. It's not even my DD and I use the AC too often to give it up. Even if I put my car on a 300 pound diet the AC will be the last thing to go!
| The Following User Says Thank You to ATL BRZ For This Useful Post: | kiichiro (05-11-2015) |
#9 |
Drives: Four wheels, two seats, etc
What does the A/C delete weigh compared to the compressor? Im certain a lot less but just curious.
#10 |
Wanted to add my feedback to this thread. We have been using the prototype Raceseng AC delete bracket on our race car since about November of last year and have had zero issues. The Raceseng bracket is much lighter than the JDM bracket we were using (see photos). Especially the pulley itself. I can say we have had zero issues to date with our Raceseng bracket and we have done over 10 full races on it, in addition to a full 2 hour endurance race. Totally proven product.
Here's some shots from comparing it to our JDM piece: ![]() ![]()
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
#11 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
| The Following User Says Thank You to Anthony For This Useful Post: | swift996 (05-19-2015) |
#12 | |
I believe the belt routing needs to wrap under the top idler pulley and up around the AC pulley, then down to the water pump. Your post got me thinking at first!
We did not do dyno testing because this product spawned from the one-off prototype we made for Speedhunters Scion Tuner Challenge build. I know this will be a low volume product so I need to be careful about how much upfront time we put into it. ![]() ![]() ![]() ![]() Quote:
#13 |
The AC compressor has one electrical connection running to it. We have not experienced a CEL light since we've had this installed.
#14 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
sweet cnc work
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
| The Following User Says Thank You to kiichiro For This Useful Post: | Raceseng (05-14-2015) |
| Raceseng | Revo Engine Pulley Product Release | Raceseng | Engine, Exhaust, Transmission | 50 | 01-09-2015 02:24 PM |
| NonStopTuning Pulleys - Introductory Group Buy Offer - 35% off! | NonStopTuning | Groupbuys | 171 | 10-08-2014 06:29 PM |
| Raceseng | Ashiko Shift Knob - Introductory Forum Price | Raceseng | Groupbuys | 65 | 06-01-2014 04:41 AM |
| Raceseng | Slammer Shift Knob Introductory Price | Raceseng | Groupbuys | 156 | 04-04-2014 09:55 AM |
| DSG Performance Introductory Offer....ARK Exhaust and AEM Intake /// Free-Shipping!! | Jason@DSG | Engine, Exhaust, Bolt-Ons | 2 | 10-02-2013 11:13 AM |
