Old 05-11-2015, 10:51 AM   #1
gregdobs
Drives: 2013 FR-S Asphalt
Electric dies when trying to start, disconnect/reconnect battery starts fine
This weird issue popped up last night.
After visiting a friend's house I was walking up to my car. I unlocked it and the interior lights came on and everything worked as normal. But when I tried to turn the key to start the engine everything cut out. I thought I had left a door open or head lights on or something so I jumped it using my friends car and everything was fine for the drive home (30 minute drive).
This morning I walked out to my garage and unlocked the car. Just like last night everything was fine and working until I turned the key to start the car. Again everything died. The difference between last night and this morning was I didn't have anyone to jump me. So out of desperation I disconnected the battery cables and reconnected them (pop off, pop on. super simple). I had power back (locks, windows, radio, ac, lights, etc.) and when I tried to start the car it started perfectly. I drove to work (15 minute drive), and when I got to work this morning I turned the car off in the parking lot and tried starting it up again. Everything died.
I don't know what could be wrong. It sounds like a battery problem, but why would disconnecting/reconnecting solve it? Could it be fuses? I don't think it is alternator. Just looking for some expertise/creative thinking. Any help you can provide is appreciated!
gregdobs is offline   Reply With Quote
Old 05-11-2015, 11:01 AM   #2
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Could be a few things
My main guess would be bad battery. It has enough juice to keep lights on but not enough to crank the car over
second guess would be loose or bad connection at battery (Especially because you unhooked it and it worked when you hooked it back up) Dirty connection?
third would be the main fuse on the batter block itself, could be half popped, but unlikely.
First thing I would do is take it autozone or whatever where they do free battery tests takes a few minutes and its free
or change to a known working battery and rule that out
if its more of an electrical problem I would wait for somebody else to answer
BlueSky is offline   Reply With Quote
Old 05-11-2015, 11:04 AM   #3
gregdobs
Yeah, I'm planning to get the battery tested later today. Just feels weird to me that the unhooking/reconnecting it allows for the car to start. I feel that if battery was bad it wouldn't be strong enough to start the car on it's own.
Could be dirty connections, I haven't cleaned them in the ~2 years I've owned, I will do that later today as well.
Old 05-11-2015, 11:05 AM   #4
BlueSky
BlueSky's Avatar
Is there any bubbles on the sides of the battery?
Old 05-11-2015, 11:07 AM   #5
gregdobs
Didn't look hard this morning, but I didn't notice anything out of the ordinary. Will take another look after work when I have to unhook/rehook to get my car to start. Haha.
Old 05-11-2015, 11:17 AM   #6
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Autozone will test across the entire battery, but not the individual cells in a battery.
I had this same issue on a battery in my old Volvo R. It tested fine at autozone with the method they used. Dealership tested individual cells, and one was bad.
GotBRZ1691 is offline   Reply With Quote
Old 05-11-2015, 11:22 AM   #7
BlueSky
BlueSky's Avatar
It depends where you go then I guess
I'm in Canada and Partsource test the whole board too was a longer scan
Him being in the MI I know they have Autozone and Oriellys
Old 05-12-2015, 09:23 AM   #8
gregdobs
UPDATE: I cleaned the connections last night and have not had the problem since. So if anyone else is experiencing an issue like this, give your connections some scrub love.
Old 05-12-2015, 09:43 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I was going to say, t was a dirty or loose battery connection.
Old 05-12-2015, 10:00 AM   #10
BlueSky
BlueSky's Avatar
Right on man
Old 05-12-2015, 10:37 AM   #11
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i always "WTF" if i experience unexpected battery problem and realized it was simple/minor issue
battery, electric, ignition, starter
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
How to Disconnect battery?!?!?! aakash Cosmetic Modification (Interior/Exterior/Lighting) 2 01-29-2014 01:47 PM
Issue after battery disconnect Audio related. Mako Issues | Warranty | Recalls / TSB 4 07-10-2013 09:29 PM
Disconnect battery for all LED installation? husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-30-2013 03:25 PM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 12:28 AM
