Old 05-08-2015, 08:51 PM   #155
koteman
koteman's Avatar
Drives: Scion frs
Originally Posted by dj2020 View Post
Thanks for the pictures. I didn't know that plumbing the PCV and CCV into one can was possible. I thought the two systems see different pressures per @Mishimoto and that this type of routing was not possible. Your check valves and vent to atmosphere at boost allows for this?
Not really sure about different pressures but I know stock the ccv pulls a vacuum to the intake and pcv to manifold but I would think they would both need a vacuum at the same time so it shouldn't matter. Most vent to atmosphere cans for boost have both going to the same can
koteman is offline   Reply With Quote
Old 05-16-2015, 12:40 PM   #156
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Mad1723 View Post
Thanks @Sojhinn ! Can't wait to receive mine to see how good it looks Report back when you have a bit of oil in there
So 4 months later and....Name:  ImageUploadedByTapatalk1431794421.180963.jpg
Installed Mods:
Old 05-16-2015, 02:51 PM   #157
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
I need to check mine when I'm home, I had a pretty intense HPDE the other day, pretty sure there must be quite a bit in there after all that
Mad1723 is offline   Reply With Quote
Old 05-18-2015, 06:53 AM   #158
TCR
Drives: 2013 Toyota 86 GT
So, any updates on the kits to suit RHD cars?
TCR is offline   Reply With Quote
Old 05-18-2015, 12:23 PM   #159
Mishimoto
Drives: 2013 Subaru BRZ
Originally Posted by Sojhinn View Post
So 4 months later and....Attachment 109754
Not bad, thanks for reporting back! What kind of actual road mileage do you estimate in the 4 months?
Looking forward to your results as well!
Not at the moment. As soon as we have an update we will let you know!
Thanks
-John
Mishimoto is offline   Reply With Quote
Old 05-18-2015, 12:31 PM   #160
Sojhinn
Sojhinn's Avatar
Thanks
-John
About 200 miles per week.
Installed Mods:
Old 05-25-2015, 09:02 AM   #161
Gr0ts86
Drives: GTS86
Thanks
-John
Thanks John, add me to the RHD list. Let us know, cheers.
Gr0ts86 is offline   Reply With Quote
Old 05-25-2015, 09:31 AM   #162
tnle
Drives: Toyota 86 13'
Interested in a RHD version.
Of all the designs currently available, the Mishimoto is a walk in the park to flush.
*please make it happen lol
tnle is offline   Reply With Quote
Old 05-28-2015, 01:27 PM   #163
Mishimoto
Got it! Thanks for chiming in.
Old 06-05-2015, 04:43 PM   #164
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Installed this catch can at the end of April with some assistance from @King Tut as I'm still learning my way around an engine.
I can echo the comments above about an auto install being somewhat difficult due to the clearance and getting the clamp tightened. Doing the install while the car was still hot didn't help that either.
Emptied the can last night after one month of daily driving, an autocross event and a track day and there was definitely some accumulation at the bottom
the new guy is offline   Reply With Quote
Old 06-08-2015, 09:34 AM   #165
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That looks like the amount I would expect to see.
Old 06-08-2015, 01:43 PM   #166
Mishimoto
Very nice! Thanks for posting up your feedback.
-John
Old 08-04-2015, 04:01 PM   #167
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Do your catch cans use check valves for turbo applications? I've been told by several people that I need check valves between the intake manifold and the catch can.
Sent from my SAMSUNG-SM-N900A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 08-19-2015, 02:46 PM   #168
Mishimoto
Our catch can system is designed to function with the stock PCV valve. Many folks running boosted FA20's prefer to add a check-valve to the system to reduce the chance of boost entering the crankcase. A check valve can certainly be added to our system, spliced in the silicone lines we include with our kit. The inner diameter of our included silicone line is 12mm, in the case that you are searching for the correctly sized valve.
Thanks for the inquiry!
-John
Mishimoto Compact Baffled Oil Catch Can Build Thread! Mishimoto Engine, Exhaust, Transmission 81 08-21-2019 08:05 PM
Mishimoto Build Thread: BRZ/FR-S Silicone Induction Hose Mishimoto Engine, Exhaust, Transmission 23 11-29-2018 11:35 AM
Mishimoto Build Thread: BRZ/FR-S Performance Cold-Air Intake Mishimoto Engine, Exhaust, Transmission 90 12-03-2016 06:22 PM
FS:WA- ADD W1 REd Baffled Universal Aluminum Catch can glamcem Engine, Exhaust, Bolt-Ons 0 07-05-2014 07:15 PM
Win a Mishimoto Oil Catch Can! Mishimoto Announcements, Contests, Giveaways 68 10-23-2013 05:27 PM
