Old 05-08-2015, 01:30 PM   #155
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by Jive Turkey View Post
oh i give up. i'l just check in once in a while to make people know i didn't die, yet.
Are you dead yet?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-08-2015, 01:51 PM   #156
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by Hyper4mance2k View Post
Are you dead yet?
BRING OUT YER DEAD!
I used to be an adventurer like you... but then I put mismatched Brembos on my 86.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
Jive Turkey (05-08-2015), King Tut (05-08-2015), rixter145 (05-06-2020)
Old 05-08-2015, 02:45 PM   #157
tennisfreak
Drives: 2018 BMW M240i
Everything I have read and found researching says for any type of racing/track application you should use slotted and not drilled rotors.
Old 05-08-2015, 03:26 PM   #158
BunnyRZed
BunnyRZed's Avatar
Drives: BRZ Limited [37J]
Except... you're overloading the fronts, so the increased heat capacity is overshadowed by the disproportionately larger amount of heat generated by the front calipers.
Still running stock Legacy GT rear calipers not STi Brembos rear.
BunnyRZed is offline   Reply With Quote
Old 05-08-2015, 04:18 PM   #159
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Shankenstein View Post
BRING OUT YER DEAD!
I wouldn't worry about @Jive Turkey dying. We need to get a list of everyone running the front and rear STI Brembos and probably check in on them weekly to see if any of them have died.
Old 05-08-2015, 04:20 PM   #160
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I'll be tracking Saturday and Sunday. Will post on Monday if I make it
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
CSG Mike (05-08-2015), Jive Turkey (05-08-2015)
Old 05-08-2015, 04:21 PM   #161
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I will contact the current owner of my BRZ and make sure he is alive and that he knows he is at risk.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
CSG Mike (05-08-2015), Jive Turkey (05-08-2015), xkalelx (05-10-2015)
Old 05-08-2015, 04:22 PM   #162
protpibe
protpibe's Avatar
Don't bother, he's probably already dead.
Old 05-08-2015, 11:55 PM   #163
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Are you dead yet?
Jive Turkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
cdrazic93 (05-29-2015), xkalelx (05-10-2015)
Old 05-09-2015, 05:14 PM   #164
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I have the full STI swap on my BRZ with flipped (correct for rotation) front calipers. (Still alive, btw)
Pedal travel did not increase noticeably, and is firm. Also there were no problems bleeding the front calipers.
Stopping is quick and predictable, not just in city driving, but also in spirited street driving and AutoX. Hard stops with ABS actuation is also predictable. I've experienced both front-first and rear-first ABS activation. Both times the car behaved predictably with no bad behavior. Additionally, rear stability control works exactly as with the stock rear calipers.
I've used both aggressive AutoX pads and performance street pads with no bad or unexpected results.
I would consider this swap perfectly safe for anything short of a serious track application. As for track use, I have no experience with this swap, but I would not expect any issues for the occasional track day with the appropriate pads.
Ultimately, the only people who really would be effected by the small issues of this swap are those that are probably looking at bigger more race-focused kits anyways. I would have no problems recommending this swap to someone who wasn't a track day enthusiast.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
Fizz (05-10-2015), xkalelx (05-10-2015)
Old 05-10-2015, 04:08 PM   #165
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
I died in a fireball from this upgrade. Just FYI.
What a bunch of utter nonsense in this thread. The article is biased because they are partnered with Brembo. Do I believe everything the FDA says when the controlling board is Monsanto? NO! Do I believe Brembo when they say that these are unsafe to use on the twins so you will buy an $8,000 BBK instead? HELL NO!
Any competent troglodyte can see through the smoke here.
-Were the STi brakes designed for the twins?
No, they were not.
-Well then they shouldn't be used then.
Not necessarily. All you have to do is swap bleeders to keep correct piston orientation.
-But the crossover is now at the highest point in the caliper. UNSAFE!
True, it is now at the high point of the caliper. Not ideal, but it can still be properly bled manually. Wanna know what else is at a high point? The brake line! My SS line is actually higher than where that crossover is in the caliper. Properly breed inner and outer bleeders with a friends help and you will virtually remove ALL air from the system.
But theres kits now designed to be used with the twins!
-Great, and there are tons of vendors to choose from if you wish to go that route.
BUT THE BIAS WILL NOW BE OFF!
-omg rly?
HEAT CAPACITY! APPLIED TORQUE! BRAKE FADE/FAILURE! MORE BUZZWORDS!
15k on fronts only. Hawk HPS 5.0 compound F/R. EXCELLENT brake feel and bias feels VERY close to stock. Junk OE front calipers were sticking and leaking at 25k. This is a very worthwhile upgrade for street and mild track use.
This thread is cancer.
xkalelx is offline   Reply With Quote
The Following 3 Users Say Thank You to xkalelx For This Useful Post:
2013GTRNate (02-15-2016), Jive Turkey (05-11-2015), Metabrz (05-31-2015)
Old 05-10-2015, 04:17 PM   #166
protpibe
protpibe's Avatar
Update: I didn't die, but one of my axles did
The Following User Says Thank You to protpibe For This Useful Post:
Old 05-10-2015, 07:03 PM   #167
Draco-REX
Corner Junkie
Draco-REX's Avatar
We don't have to get rowdy here. I think we just need to have a little perspective.
As enthusiasts, we concern ourselves with the final 20%. Power, handling, braking, we live in the final 20% that most other people never even see. How much does break-in or one oil over another TRULY effect our cars? But we argue amongst ourselves about things that, even in our world, are small differences.
So let's keep in mind, that for all but the most strenuous of uses, the idiosyncrasies of this swap represent the merest fraction of overall performance.
The Following 6 Users Say Thank You to Draco-REX For This Useful Post:
8R6 (05-11-2015), civicdrivr (05-11-2015), CSG Mike (05-11-2015), Jive Turkey (05-11-2015), lead82 (05-12-2015), Travisty75 (05-10-2015)
Old 05-11-2015, 02:44 AM   #168
CSG Mike
CSG Mike's Avatar
No, they were not.
-omg rly?
Come to the track, and I will demonstrate for you, IN PERSON, what exactly happens when you have STI brembos on a FRS.
This is gonna sound harsh, but quite frankly, if you can "get away" with Hawk HPS (a street pad), on a (race) track, even for "mild" track use, you're not qualified to be making statements on the useability or safety of a brake system at all. A novice with a single session of instruction on proper threshold braking will DESTROY HPS on a STI brembo setup, stock calipers, or even a AP Sprint or $8000 Brembo setup.
One session of instruction.
The Following 9 Users Say Thank You to CSG Mike For This Useful Post:
2013GTRNate (02-15-2016), acro (05-11-2015), DylanJZA (06-25-2022), Lawn_Mower (05-27-2015), lead82 (05-12-2015), Ruben_86_ (06-04-2025), Shark_Bait88 (05-11-2015), Takumi788 (05-18-2015), The Racers Line (05-11-2015)
The Truth Will Set You Free~ Kiske Off-Topic Lounge [WARNING: NO POLITICS] 8 01-06-2015 07:53 AM
Moment of truth. Humor is welcome! gt8613 Off-Topic Lounge [WARNING: NO POLITICS] 12 11-11-2014 02:08 PM
any truth to this? fluffy-reindeer-slayer Scion FR-S / Toyota 86 GT86 General Forum 17 06-11-2014 08:00 PM
An inconvenient Truth Maxim Scion FR-S / Toyota 86 GT86 General Forum 49 06-17-2011 10:35 PM
