Old 05-08-2015, 02:14 AM   #85
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by churchx View Post
These seemed interesting if used with Tein EDFC system. As in reasonably priced and only ones that had good review by CSG guys from tein ones, except RS-R of course. Which are out of my budget and one of those many coilovers, that have that mentioned minimum 20mm drop. Using them with lift spacers without getting back full shocks travel height imho is unwise. And if you meant shocks height adjustability, these are .. i just didn't know the range. Stock ground clearance is marginally what was still somewhat usable on daily driver from my experience. I don't wish to make it worse in pursuit of something usable on rare trackdays/limited very good roads only or to get look which actually looks worse to me. Never could see what so good with wheel visually touching arc, and sights of hellaflush lowering with form dominating function seems silly.
I was thinking more of stock springs with dampening adjustable shocks (which can cost as much as some coilovers). That way you retain factory height, but can adjust how firm or soft you want the dampers to be.
And two different camps for car modifications. Different strokes for different folks.
Old 05-08-2015, 06:27 AM   #86
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just went though the thread, this looks really good. Really interested in Both Flex Z & A now. Might be just what I'm looking for.
Old 05-08-2015, 08:38 AM   #87
congiiee
Drives: WRB Subaru BRZ
I know this is mainly the Z Thread but does anyone have more information on the A version? Anyone got there hands on a set and can comment on them?
congiiee is offline   Reply With Quote
Old 05-08-2015, 09:47 AM   #88
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
huh????
but you think that almost 3" of wheel gap isn't silly???
Looks like you're going to go 4 bying to me....
Jaden
Jaden is offline   Reply With Quote
Old 05-08-2015, 10:55 AM   #89
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, i do NOT think that gap is silly and never could understand why some might rise fuss about or from where that fashion started to appear and on what arguments it's based. "Less insane compromise hellaflush version"? I even like looks of proportional even gap all around the tire with same gap on top as on sides. To eliminate those gaps as-well one needs to up tire radius by those inches, adding in process of doing so lot of weight, killing acceleration (unless accompanied by different ratio final drive install) and tire rubbing on arc insides. Should come with sticker "i paid a lot to make slower and uglier then stock".
Old 05-08-2015, 11:13 AM   #90
Jaden
Road-hole
It's than, not then...
yeah, umm no... one, it's than, not then and yes I understand your first language probably isn't english, that's why I'm informing you of that. Than is a comparison, then is related to time difference.
Second, there are many larger wheels that weigh the same or less than the smaller oem stock wheels and lowering the car an inch or so actually can improve driving feel and performance which many are trying to do.
I agree that the hella flush crap with crazy camber is ridiculous and degrades performance, but saying the stock ride height and wheel fitment is perfect is insane to me.
To each his own I guess, but NOT when it comes to performance and a little lower IS better in that regard...
Jaden
Old 05-08-2015, 11:25 AM   #91
kbye
kbye's Avatar
Drives: 2014 FR-S
Originally Posted by SilverFRS View Post
Did you ever get them installed? Review & settings?
Will provide pics and impressions soon. My rear bumper is getting repainted due to a hit-and-run so I haven't taken the FRS out much.
kbye is offline   Reply With Quote
Old 05-09-2015, 02:53 AM   #92
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
They show good stock but they aren't listed on anything i found yet here. Trying to decide between the ST, Bilstein B14 and these for a daily driver that won't be slammed. My last springs were H techs and had almost enough drop for me.
Old 05-18-2015, 12:40 PM   #93
brz604
brz604's Avatar
Drives: 2013 BRZ WRB
Received my coils on Friday, got them installed yesterday.
Here's my initial review,
I installed the coilovers with the preloaded ride height and set each corner to full stiffness.
Things I've noticed:
- At full stiffness, the ride felt similar to stock maybe even less bumpy and rough.
- When accelerating, the car feels really stable, less body weight shift from front to rear, turning in on corners felt sharper and car felt pretty level.
Overall, pretty happy with them, will take it out for some cruising later and take some more pics.
Here's a couple shots I took on my phone right after installation and driving around the block. Will be waiting a couple weeks to see if they settle lower some more, before adjusting the ride height.
brz604 is offline   Reply With Quote
The Following 6 Users Say Thank You to brz604 For This Useful Post:
hmong337 (05-18-2015), Kris86 (09-13-2016), MightyMeeple (05-20-2015), shellslinger (05-21-2015), Teseo (06-13-2015), tracerit (05-18-2015)
Old 05-21-2015, 12:04 AM   #94
RacerX
Drives: Subaru BRZ
Any word on what these will cost when they get to the states? Will the price remain the same, low $700s?
RacerX is offline   Reply With Quote
Old 05-21-2015, 12:56 AM   #95
shellslinger
Drives: Whiteout FRS
Looks awesome @brz604. I just installed progress auto sway bars with my flex z coil overs and it just feels awesome through the corners.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
brz604 (05-24-2015)
Old 05-21-2015, 07:00 PM   #96
SilverFRS
Drives: Silver FRS
Are these available in ca already or did you order from Japan? Price?
SilverFRS is offline   Reply With Quote
Old 05-21-2015, 07:09 PM   #97
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, at stiffest level similar to stock. Not sure i'd like that. Then other end of spectrum is not sportier but rather lexus/boat mode. Would rather prefer stock suspension matching some middle level or 1/3rd from softest coilover settings, so that if wished one can dial in both stiffer for track days or slightly softer for daily driving.
Old 05-21-2015, 07:23 PM   #98
shellslinger
I wouldn't really agree with that statement. At full stiff it's very stiff and definitely noticeably stiffer than stock.
CSG Mike (05-21-2015)
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
