View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 05-03-2015, 03:39 AM   #351
mkivsoopra
Originally Posted by Astroboy View Post
What oil weight and brand are you using? Do you regulate the oil temps? Glad to read some good news on this page
I have a rather large/effective oil cooler, so in 85F weather, I only see a max of about 215F oil temps on the track. For now, I'm using Motul 300V 0w20, and my oil pressure is staying in the 50-60 psi range on track. For the summer months, I'll be switching to 5w30.
mkivsoopra is offline   Reply With Quote
The Following 3 Users Say Thank You to mkivsoopra For This Useful Post:
Astroboy (05-05-2015), rb6freak (05-11-2015), sw20kosh (05-03-2015)
Old 05-07-2015, 04:19 PM   #352
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
texasbound972 is offline   Reply With Quote
Old 05-07-2015, 04:20 PM   #353
texasbound972
USMC
Just make sure you don't run e85 with that 300V
Old 05-07-2015, 04:33 PM   #354
sw20kosh
Drives: 2013 Black FR-S
Lol!!!!!! Wut?!
@CSG Mike @CSG David
Old 05-07-2015, 04:34 PM   #355
mkivsoopra
Why not?
Old 05-07-2015, 04:36 PM   #356
texasbound972
USMC
The Motul rep said why not. It is blended differently I guess. You are fine with regular Motul just not the V series.
Old 05-07-2015, 06:59 PM   #357
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
We're going to need some elaboration, because 300v is marketed specifically as a fuel to use with E85 applications by their vendors.
E85 will contaminate oil much faster than pump gas and reduce the effectiveness of detergents. Regardless of the oil you choose, you should be prepared to drop your intervals to 2k miles.
http://bobistheoilguy.com/forums/ubb...Number=2053308
http://forums.nasioc.com/forums/show....php?t=2611261
http://www.gtrlife.com/forums/topic/...n/page__st__80
http://www.bobistheoilguy.com/forums...Number=2107073
Whatabouteggs is offline   Reply With Quote
Old 05-07-2015, 07:30 PM   #358
CSG Mike
CSG Mike's Avatar
There is no definite "yes" or "no" from Motul.
From my personal observations, 300V on E85 with a daily driven car is okay, as long as pump gas is reguarly also used (detergents), and the oil gets hot enough (to evaporate off the fuel/ethanol).
If E85 is in the engine oil, and the car is allowed to sit for an extended period of time, the alcohol attacks the esters of 300V, causing the oil to get "milky", but, to my knowledge at this time, does not compromise the oil's ability to lubricate the engine.
That being said, anyone running E85 should be on a shorter oil change interval anyways.
Old 05-08-2015, 10:57 AM   #359
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
http://s1058.photobucket.com/user/Aaron_Chambers/media/20141218_083305_zpsfoakgg4y.jpg.html
Nice windows. You want to share the details when it happened:
- Turbo Kit
- Tuner and fuel used
- Details surrounding when it blew up
Old 05-08-2015, 03:10 PM   #360
Astroboy
Astroboy's Avatar
Drives: None
What was the cause? How much boost were you running and which turbo kit?
Astroboy is offline   Reply With Quote
Old 05-10-2015, 05:08 PM   #361
texasbound972
USMC
Bad tune and I wasn't even in boost when it blew. My boost was set at 8 psi on e85 which was completely safe from what my tuner told me.
The Following User Says Thank You to texasbound972 For This Useful Post:
Astroboy (05-11-2015)
Old 05-11-2015, 01:34 AM   #362
Astroboy
Astroboy's Avatar
Drives: None
ok, so I've been reading your posts because i am quite interested in what happened. if it isn't to much to ask, may you post a timeline of when everything happened? the oil in the coolant, the shot block, the engine swap, and everything else that happened to your car? in order preferably. thanks
Old 05-11-2015, 11:13 AM   #363
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Here's mine. Running an AVO kit at 8psi at the track (TWS here in Texas). Best guess is that I over revved it or the valves floated a bit, and had valve to piston contact. Looks like the piston then shattered and the rod then bet the everliving crap out of what remained.
FrX is offline   Reply With Quote
Old 05-11-2015, 11:14 AM   #364
texasbound972
USMC
No problem. It'll take me a minute so I can go through everything.
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
