Old 05-06-2015, 07:30 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution
FT-86 SpeedFactory in conjunction with Velox Motorsports have released our rear diffuser to solve issues with rear downforce in the 2013+ Scion FRS and Subaru BRZ. Designed off OEM CAD data, it features a near OEM fit and finish. This item has been tested on track as well as refined through Computational Fluid Dynamics (CFD) to provide a significant increase in downforce while minimizing drag. CNC laser cut from 5052 aluminum sheetmetal, and then precision bent using CNC press brakes means each part comes out consistent. Designed, analysed, and manufactured in the United States using United States machines and materials.
The picture above includes the optional diff/suspension covers as well. These are an extra option to help further clean the flow of air.
ETA ON SHIPPING IS LATE JUNE. Manufacturing has already started.
Product Features:
Powder Coated Matte Black
Organic Shape
Flat head riveted strakes (No rivet heads visible, flat bottom)
Simple Bolt on installation
Reduces drag
Significantly reduces lift
Optional 2pc differential/suspension covers reduce drag even further and aid in feeding the diffuser clean air.
When combined with our front race splitter.
More pics of the rear diffuser are below as well as our center exit V3 race exhaust system which is currently being tested.
FT-86 SpeedFactory is offline
Old 05-06-2015, 08:46 PM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
website says wont fit type 80r but it looks pretty roomy. Is that a cautionary "wont fit" or does it really not fit?
Reaper is offline
Old 05-06-2015, 08:48 PM   #3
FT-86 SpeedFactory
Nope. The type 80 can is to massive and the way the pipe routes does not allow for a diffuser with proper airflow.
Old 05-06-2015, 08:49 PM   #4
bfsnail
bfsnail's Avatar
Looks great! Do you have any side views to see how far it sticks out behind the bumper?
bfsnail is offline
Old 05-06-2015, 09:24 PM   #5
CSG Mike
CSG Mike's Avatar
How does this affect cooling for the differential and rear brakes?
What wheels and tires were used in the CFD analysis to determine the numbers?
CSG Mike is offline
Old 05-06-2015, 09:34 PM   #6
kosoku
Drives: 2013 fr-s
I guess its free? No price listed sooooooo....
kosoku is offline
Old 05-06-2015, 09:50 PM   #7
Jonsey
Jonsey's Avatar
They can't list prices here... It's not too tough to go to their website and check it out.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline
Old 05-06-2015, 10:00 PM   #8
Reaper
Reaper's Avatar
Drives: violent
no type 80r no care...
Reaper is offline
Old 05-06-2015, 10:14 PM   #9
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Has the fit been refined for manufacturing from these (presumably prototype) images? I can't help but notice in the first installed image (direct shot of the rear) the line slants significantly down to the left instead of a clean, horizontal line that is parallel with the bumper. I guess it could just be the angle, but it otherwise looks like a pretty direct shot of the rear.
Ammunition is offline
Old 05-07-2015, 11:42 AM   #10
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
It is the angle of the shot. The trailing edge is horizontal.
VerusEric is offline
Old 05-07-2015, 03:11 PM   #11
IceFyre13th
IceFyre13th's Avatar
Drives: Mazdarati
Hope this is a typo......
"This item has been tested on track as well as refined through Computational Fluid Dynamics (CFD) to provide a significant reduction in downforce"
IceFyre13th is offline
Old 05-07-2015, 03:14 PM   #12
VerusEric
VerusEric's Avatar
Most certainly a typo. Thanks for pointing it out . Should be significant increase in downforce or significant decrease in lift. Sorry for any confusion.
Old 05-07-2015, 03:24 PM   #13
IceFyre13th
Drives: Mazdarati
Saving my pennies now, best design I have seen for a rear diffuser yet!!!!
Old 05-07-2015, 03:46 PM   #14
cslntuee
Drives: Subaru BRZ Limited
Is there any optional rear spat to further extend the width?
Thanks.
cslntuee is offline
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
Single-Exit Exhaust Diffuser/Hole Problem... Solution! Anthony Cosmetic Modification (Interior/Exterior/Lighting) 75 10-13-2016 07:40 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
DriveWay Labs Rear Diffuser - FT-86 SpeedFactory FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 435 01-15-2015 07:20 AM
