Old 01-02-2013, 11:20 AM   #15
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Anyone with aluminum rings have issues with them corroding or sticking to the hub/rotor? Any tips or tricks to keep them from corroding and sticking?
Old 01-02-2013, 02:22 PM   #16
RavSpec
Drives: Rx7
Yeah they always stuck on the wheel after some heavy usage. No way around it. Not a big deal though. Just hammer it out.
RavSpec is offline   Reply With Quote
Old 05-06-2015, 02:53 PM   #17
klearfade
klearfade's Avatar
Drives: Scion FRS
I know this is an old thread, but what is the specific size I would need for the FRS. Specifically if im running XXR 527 18X8.75 +35 ?...Thanks
Just here to learn.......and laugh
klearfade is offline   Reply With Quote
Old 05-06-2015, 03:10 PM   #18
wparsons
wparsons's Avatar
You don't need them at all. I've got TONS of track miles, and even more street miles with RPF1's without rings.
If you want them to make putting the wheels on easier, just look up the center bore diameter of the wheels. You'll need them to fit the stock hub (56.15mm), and the wheel center bore.
flickr
klearfade (05-06-2015)
Old 05-06-2015, 03:21 PM   #19
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
from what I have been reading is dont use hub rings for track. I have a set of aluminum rings I was planning on using this weekend with the rpf1's I just got.
Some say using the rings puts less stress on the wheel studs. True or not?
ExxelDistributions is offline   Reply With Quote
Old 05-06-2015, 05:19 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is it really that hard to hold the wheel with one hand and put the lugs on with the other?
Old 05-06-2015, 05:24 PM   #21
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
metal hubcentric rings cost like less than 20 for a set of 4. well worth the positives they bring rather than the negatives that COULD bring without them.
do you really want to shortchange yourself in the long run for just $20 dollars?
DuMa is offline   Reply With Quote
Old 05-06-2015, 05:26 PM   #22
gramicci101
Off Topic
Our wheels are lug-centric, not hub-centric. The lugnuts are what locate the wheel on the hub, not a plastic or aluminum ring. Any vehicle with tapered lugnuts is the same. Vehicles with flag lugnuts or bolts are hub-centric and it's a much bigger issue that the wheel and hub match diameter.
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
BRZ68 (05-06-2015), Calum (05-06-2015), housecat (12-27-2016)
Old 05-06-2015, 05:30 PM   #23
GarStar
I don't have hub rings on my aftermarket wheels, and you don't need them if you star pattern.
1. Screw on lugs loosely, star pattern.
2. Weakly tighten in star pattern.
3. Repeat 2.
4. Torque in star pattern.
No vibrations noticed.
GarStar is offline   Reply With Quote
The Following User Says Thank You to GarStar For This Useful Post:
wparsons (05-07-2015)
Old 05-06-2015, 08:23 PM   #24
Calum
That Guy
There are no positives other than making it slightly easier to install the wheels.
Old 05-06-2015, 09:56 PM   #25
DuMa
DuMa's Avatar
it distributes stress and forces across the hub/studs and the wheel/lugs evenly on bumps and dips rather than just the lugs/studs
Old 05-06-2015, 10:02 PM   #26
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
The answer to the question is NO... they serve no real purpose other than as an installation guide tool, just like that plastic splined tool for doing clutch jobs - makes it easier to get the job done. The torque holding the wheel to the rotor hub (via stud and nut) is the mechanism which fastens and positions the wheels to the hub, which is why it is important to make sure the two surfaces are clean and free of debris/rust when mounting wheels. I have never used centering rings and never will.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
Calum (05-07-2015), wparsons (05-07-2015)
Old 05-06-2015, 10:29 PM   #27
GarStar
If this were the case, both the aluminum and plastic hub rings would wear out very quickly.. both are relatively soft. The studs take the majority of the force.
The Following 2 Users Say Thank You to GarStar For This Useful Post:
Old 05-07-2015, 11:07 AM   #28
wparsons
wparsons's Avatar
No they don't. If they were actually taking any force, the plastic would be smashed after the first bump you hit.
Have you ever looked at how tiny the lip on the hub is, and how far offset it is from the centerline of the wheel? If you were to set a car down without lug studs in place, but the wheel properly lined up against the hub with centering rings, it would very quickly pop the wheel off the hub long before the full weight of the car was resting on the wheel.
With conical seat lugs, the only way the ring takes any force is if the lugs aren't seated and torqued down enough, or if the studs are bending.
flickr
Hubcentric Rings Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 06-08-2016 01:42 PM
Aftermarket wheels in Calgary Davetherave CANADA 4 12-03-2012 10:30 PM
Which Hubcentric Rings do I need? RPF1 Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-20-2012 09:56 AM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 07:19 AM
