Old 05-04-2015, 07:19 PM   #8765
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
@Shiv@Openflash is there any way we can use our OFT Dollars towards the purchase of the Procede Controller?
yamsta is offline   Reply With Quote
Old 05-04-2015, 10:07 PM   #8766
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
@Shiv@Openflash
Does anyone who received their PROcede have an issue with the female 3.5mm aux cable? Mine is way too small for some reason and the pedal button cable will not go in.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 05-04-2015, 10:26 PM   #8767
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by l0aded View Post
@Shiv@Openflash
There's a joke in here... But I'm holding back.
Installed Mods:
Old 05-04-2015, 10:59 PM   #8768
l0aded
Addicted
l0aded's Avatar
Lol. I had the same thought writing that post.
The Following User Says Thank You to l0aded For This Useful Post:
Sojhinn (05-04-2015)
Old 05-04-2015, 11:06 PM   #8769
Sojhinn
Sojhinn's Avatar
Did my suggestion work?
Installed Mods:
Old 05-04-2015, 11:17 PM   #8770
WRB5titch
Drives: WRBrz
@Shiv@Openflash
I'm running into the same issue...was thinking about taking a drill bit to it, but iono if that's a good idea..
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 05-04-2015, 11:19 PM   #8771
Sojhinn
Sojhinn's Avatar
Ok sounds like the wrong size was bought. Quick solution: run to RadioShack and buy an adapter 1/8" female to 3/32" male. Mino or stereo should be fine
Installed Mods:
Old 05-04-2015, 11:44 PM   #8772
WRB5titch
Drives: WRBrz
Just my luck... Radioshack near my house closed down lol
Old 05-04-2015, 11:51 PM   #8773
Sojhinn
Sojhinn's Avatar
Best buy?
Installed Mods:
Old 05-04-2015, 11:53 PM   #8774
WRB5titch
Drives: WRBrz
won't make it in time, i'll give it another go tomorrow.
Old 05-05-2015, 12:15 AM   #8775
l0aded
Addicted
l0aded's Avatar
Per Sojhinn's instructions, go to Fry's/Radioshack/Bestbuy etc and get a 2.5mm (male) to 3.5mm (female) adapter. Fits like a glove after. Hopefully nothing else goes wrong.
Also the 10mm screws with the thing attached in the beginning... yeah I don't have those for some reason. Luckily I have spare screws but kinda weird. Am I missing something important? What is the black box in the video? I do not have one in my car.
Update: T-Tapped green/black to the 1st of the 4 connectors. T-tapped green/yellow to the 3rd of the 4 connectors. Grounded the hook wire. T-tapped the power fuse slot.
When I start my car the ESC digital display turns on (28.5) but when I drive the ESC never activates (stays ~28.5) and it feels like there are dead spots similar to when you first flash a new tune. I'm assuming that either one of the two ECU taps went wrong or something is up with the activation 3.5mm plug. When I remove the plug from the PROcede harness the ESC activates so it works as it should as far as I know (plugging it back into the foot switch still works as well). Any ideas on what is going on? Is it possible Shiv forgot to load the map or the map is wrong? I double checked all my connections and they seem fine. Is there possibly an issue with the activation switch since it came with a 2.5mm connector and I used an adapter?
Old 05-05-2015, 03:49 AM   #8776
PantsDants
Drives: Scion FR-S A/T, Whiteout
One thing to check is that the adapter you bought matches the number of rings used on either end. The footswitch cabling has three points of contact (two plastic rings between the metal sections). If the adapter only has two contacts, it's not going to work right.
PantsDants is offline   Reply With Quote
Old 05-05-2015, 10:36 AM   #8777
Sojhinn
Sojhinn's Avatar
Actually you only need the tip. That is the point that sends the voltage to the controller. The other connection is just used for the foot controller.
Installed Mods:
Old 05-05-2015, 10:38 AM   #8778
Sojhinn
Sojhinn's Avatar
Make sure your adapter isn't stereo to mono, and is just stereo to stereo. (Mono to mono should work too but just in case)
Second theres a possibility that the map wasn't loaded. Snag the software and tune from shiv's site.
Also what black box? Can you tell me what time in the video?
For anyone that needs help. Either PM me or quote me so I see the notification pop up on my phone. Work is slow today since my students are taking AP tests all day.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
