Old 05-01-2015, 11:06 AM   #8751
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Has anyone here with an ESC ever ran any of the short final drives. Such as Cusco or Mfactor 4.55, 4.88, etc?
I know I would like the 4.55 while I run the car NA, but I am curious as to the drivability of the car with the ESC installed. If anyone has any experience please let me know.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 05-01-2015, 02:38 PM   #8752
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I know someone did, but then ended up selling the ESC, I think it was shif7i7down.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
brzaapi (05-01-2015)
Old 05-01-2015, 03:28 PM   #8753
PantsDants
Drives: Scion FR-S A/T, Whiteout
I've got 4.88 on my auto with the Phantom and everything works just fine. I wouldn't recommend that combination on the stock tires though.
Let me know if you have any specific questions.
PantsDants is offline   Reply With Quote
Old 05-01-2015, 03:38 PM   #8754
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I wouldn't either. The primacy's were off my car the day I bought it. This is my second BRZ, and I already had an order in with Tirerack before I took delivery on my current BRZ.
I run 245 square (probably try 255 next) and I usually run RS3, rivals, or equivalent tires. Do you believe the FD helps wake the BRZ up or do you believe with the ESC it is not needed.
I primarily AX and track this car. It is not my DD, although I do cruise around in it on weekends.
In hindsight would you do the FD again.
Daily: Audi TT RS
Old 05-01-2015, 04:16 PM   #8755
fenton
He has a auto so his 4.88 will be a massive improvement over the standard gear ratio.
Im pretty sure a FD change in a manual would result in very nice results especially for your application of AX.
With my current setup i fight for traction in 1st when flooring it from a roll on stock tires
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
brzaapi (05-01-2015), Fareast auto part (05-03-2015)
Old 05-01-2015, 04:31 PM   #8756
PantsDants
For a daily driver, it absolutely makes the car way more fun to drive out of boost, and has the added bonus getting you >2000 rpm that much quicker from a dead stop if you're looking to haul ass. You won't really notice much of a difference (other than having to shift quicker) while in boost just because the contribution the Phantom provides far outshines the final drive's benefits.
When all is said and done, I'd probably do it again. Definitely would if I hadn't gotten the Phantom.
On a track however, and even AutoX if you're competing, it makes sense to do the math and figure out what gearing you need for where you're racing. It's impossible to recommend an effective "across the board" final gear ratio.
The Following User Says Thank You to PantsDants For This Useful Post:
Old 05-01-2015, 05:01 PM   #8757
brzaapi
CAR-AHOLIC
brzaapi's Avatar
That is true. I actually AX( primarily) on a Sheriffs training course. It is much larger than your typical AX course and I see speeds of 70 or 80+mph out there quite often. My wife in the Cayman sees 80 to 90 quite often. So I am in 3rd gear a lot more than the average AXer.
I will never get the gearing just right since our AX location allows for all kinds course layouts.
I have no doubt that it could induce more wheel spin, since I can do that now even if the ESC is not installed......but as long as the FD does not make the car twitchy (bad manners) I can be judicial with the accelerator.
Decisions, Decisions........Well I am definitely doing the OS Giken LSD, but I would love to complete both projects at the same time.
Daily: Audi TT RS
The Following User Says Thank You to brzaapi For This Useful Post:
DAEMANO (05-02-2015)
Old 05-02-2015, 03:51 AM   #8758
TM
TM's Avatar
Drives: DGM BRZ 6MT
Does the Procede controller come with the necessary accessories to tap into the vehicle wires or do I need to make a trip to Home Depot or something?
TM is offline   Reply With Quote
Old 05-02-2015, 11:04 AM   #8759
Stormalong
Drives: Firestorm FR-S AT
Got a tracking number from Shiv for the Procede yesterday.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
Stormalong is offline   Reply With Quote
Old 05-03-2015, 01:17 AM   #8760
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Should come with everything you need if you are on v2.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (05-03-2015)
Old 05-04-2015, 11:54 AM   #8761
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
It's happening!!!
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
The Following 3 Users Say Thank You to l0aded For This Useful Post:
brzaapi (05-04-2015), DAEMANO (05-04-2015), LucidMomentum (05-04-2015)
Old 05-04-2015, 04:49 PM   #8762
Sojhinn
Sojhinn's Avatar
Originally Posted by l0aded View Post
It's happening!!!
Just in case you need the link... heres the install video for the procede.
[ame="https://www.youtube.com/watch?v=5FpB5U2GJdo"]Procede Install for FT86 - YouTube[/ame]
Installed Mods:
The Following 4 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (05-04-2015), Gums (05-04-2015), WRB5titch (05-04-2015), zc06_kisstherain (05-05-2015)
Old 05-04-2015, 06:33 PM   #8763
l0aded
Addicted
l0aded's Avatar
Thanks! Luckily it's easy to find on YouTube as well. "Procede ft86" done. Any other advice not in the video or areas to be extra careful?
Old 05-04-2015, 06:34 PM   #8764
Sojhinn
Sojhinn's Avatar
V2 or v1? V2 is a super easy install.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
