Old 05-04-2015, 09:53 AM   #1499
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by ATL BRZ View Post
Got some really good laps in that I'll share very soon.
You get any lap times?
Old 05-04-2015, 10:39 AM   #1500
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Yes with my slow-gps Nexus 5 and Harry's Lap Timer. Did a few gps-inaccurate 1:37's before my tires started falling off badly. They were already heat cycled out and they're now past the wear bars approaching the cords. Time for RE-71R's!
Also had fuel starvation again at T14-15 up the hill around the carousel if I wound out 4th gear at 3/4 tank. Last weekend at AMS it happened around the banking below 1/2 tank. Never happened before at AMP but the car is making more grip and pulling more lateral G's with the extra aero now. I could avoid it by short shifting into 5th and not winding out 4th gear above 6k rpms up the hill which killed my top speed and lap times. After topping off the tank with E85 it didn't starve again until 3/4 tank.
Old 05-04-2015, 10:43 AM   #1501
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I fuel starved there as well. It really upsets the car when you are going that fast and suddenly have no throttle input. I worry about how many street miles those RE-71Rs are going to be good for. I want to see some reports on the new Kumhos as well. I am probably going to go for a stickier street rubber next time. My Michelin PSS have over 35 heat cycles on track and one 8 run AutoX, but they still feel good on track, but I am sure they have lost significant grip.
Old 05-05-2015, 12:12 PM   #1502
gramicci101
Off Topic
A surge tank might fix the starvation problem. I remember the tank pressurization system we used on F-16's, so I figured there must be something similar for cars that also experience high g forces. That led me to surge tanks, which led me to Ian @MAPerformance, who directed me to the above link. I don't know what kind of fuel flow these cars need in a track environment though, and I don't know if they'd work with a flex-fuel system, although E85-specific tanks were listed.
Old 05-05-2015, 02:20 PM   #1503
sw20kosh
Drives: 2013 Black FR-S
Friend recently did hpde weekend on his new re71r..... The outsides are more than 50% done after one weekend. He is adjusting his camber accordingly. Swapping fronts to backs he figures it will last one more weekend and then done. He is switching to NT-01 next. This is strictly a track car. Not daily driven. LOL. For comparison his Rivals lasted 5 weekends and still had tread when he took them off. Re-71 is sooooffftttt.
@ATL BRZ
Old 05-05-2015, 02:47 PM   #1504
ATL BRZ
ATL BRZ's Avatar
I've been reading that they wear VERY quickly but I don't understand how they get a 200 treadwear rating?!?
Old 05-05-2015, 04:02 PM   #1505
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
R compounds with tread? I think the RE71R will wear a lot better with proper camber, but it's still soft compared to the older spec Rivals or the RE11.
Old 05-05-2015, 04:53 PM   #1506
gramicci101
Off Topic
It's in their interest to be a 200tw tire so autocrossers can buy them, so I'm sure they padded the stats a little. Treadwear is such a subjective number anyways that they can get away with it.
Old 05-05-2015, 05:11 PM   #1507
Jonsey
Jonsey's Avatar
Since I added aero and switched to ZII star specs, I also start fuel starving below 3/4 of a tank. I switched back to 93 for the last track day as I was no longer able to complete a full session without starving happening. A buddy owns an evo shop that does a lot of surge tanks and is trying to convince me to put one on the car.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 05-06-2015, 10:55 AM   #1508
King Tut
NASA SpecE30 Racer
King Tut's Avatar
A surge tank is definitely the correct way to fix the problem. I will be adding one in the future. Radium, Full Blown, and SoS all make a kit specific to the S2000. I would be surprised if someone isn't making one for the BRZ/FR-S.
Old 05-06-2015, 11:33 AM   #1509
gramicci101
Off Topic
I ended up talking to Ian from MAPerformance because he sells them. He strongly recommends Radium tanks. Most of the tanks he sells are designed to mount inside an actual racing fuel cell instead of an OEM tank, but the link he sent me in my previous post goes to Radium's list of universal tanks mounted outside the OEM fuel tank. He recommended using the OEM fuel pump to feed the surge tank, and then use the surge tank's pump to feed the engine. That seems easier than trying to find the one surge tank that would mount inside the OEM fuel tank.
Old 05-06-2015, 11:35 AM   #1510
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep. That is the way the S2000 guys do it.
Old 05-06-2015, 11:38 AM   #1511
gramicci101
Off Topic
Not having any experience with modifying fuel systems on cars, it seems like it would be least difficult to mount the thing in the engine bay and access the inbound fuel line there.
Old 05-06-2015, 11:47 AM   #1512
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Never seen that. Generally it is mounted inside the car or near the fuel tank under the car. For the BRZ, I would ditch the rear cushion and build a nice mount for it in the driver/rear seat area.
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
