Old 04-28-2015, 04:56 PM   #15
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Well if you're not gonna stance your car, then what's the point of BC coils? They're shitty and they'll make your car handle worse than stock.
I'd recommend a basic set of KW V1's or Tein Flex. They're both under $1500 and are decent coil systems.
sittinSideways is offline   Reply With Quote
Old 04-29-2015, 04:05 PM   #16
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
RCE tarmac zero, upgraded swift springs. best budget suspension out IMO.
Jive Turkey is offline   Reply With Quote
Old 04-30-2015, 02:37 PM   #17
AlexWood
Drives:
Size:  347.5 KBkind of a bad picture but you get the idea. This is running BC non-extreme lows with 18x9.5+34 wheels with 235/40's all around. It rubbed on hard bumps and only slightly at full lock but other than that I had no issues and had plenty lower to go. The ride was firmer but no harsher than stock.
AlexWood is offline   Reply With Quote
Old 04-30-2015, 02:49 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by adamg View Post
unless he wants a few degrees of camber then he's fine the way it is
Not quite. Theres natural camber, and the stock LCA's werent built to handle that much moar low. Aftermarket LCAs definitely help to adjust the camber safely. Not to mention Toe will be effected, and your alignment will be off. Try to allign it and you wont be able to adjust it without adjustable LCA's.
http://www.ft86club.com/forums/showthread.php?t=49046
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
FREE Shipping: ISC N1 Coilovers: ST Coilovers in stock at B2autodesigns b2autodesigns Brakes, Suspension, Chassis 177 02-09-2015 11:34 AM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
FS: (IL) KW Variant 3 coilovers and Stance Super Sport Coilovers ill roller Brakes, Suspension, Chassis 5 12-14-2013 03:02 PM
