Old 04-29-2015, 12:08 PM   #43
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Originally Posted by Shutter View Post
currently on ST coilovers dropped 1.25".
Looks a little different because the back tire is 245/45 vs 245/40 for the front. No reason for this other than these were some tires that I had.
When the time comes, I'll replace the back tires with matching 245/40 or replace all tires(if the fronts are worn) with 255/40/17.
I'm just a tad lower than you at about 1.4". I would stick with 245/40/17 squared. A lot of people suggest that tire spec for a street setup and the squared setup lets you rotate them which is always nice with expensive tires like the PSS. 245 also shouldn't be stretched on a 9" width. It's just slightly stretched on my 9.5" 18's. 255's would be more suited on 9.5 for sure, but you'd have to recalibrate the speedo a little bit to compensate.
2016 Camaro SS is offline   Reply With Quote
Old 04-29-2015, 12:16 PM   #44
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Very nice! I love the ride!
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
The Following User Says Thank You to x1UP For This Useful Post:
continuecrushing (04-29-2015)
Old 04-29-2015, 01:05 PM   #45
Timmy_Jones
Spun
Drives: 23' Supra
So the rear tire is taller? I think it contributes to the look, really looks awesome!
Which set of wheels does your speedo run from? Rear? Curious if it threw your speedo/odo off?
Timmy_Jones is offline   Reply With Quote
Old 04-29-2015, 02:28 PM   #46
cycleboy
Drives: 2013 Scion FR-S - Argento
I've had the 17X8.5 for a year and a few months and I love them. I got the textured gunmetal finish. I finally got around to dropping it a bit just recently.
cycleboy is offline   Reply With Quote
The Following 2 Users Say Thank You to cycleboy For This Useful Post:
DuMa (04-29-2015), trigger happy (10-11-2015)
Old 04-29-2015, 03:42 PM   #47
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Yeah, rear tire is bigger. I kinda like the look too haha. My co-worker was like "dude always run this setup!".
I think its the rear for speedo. Its off by a little bit (2mph at 60)...so I'm really going 62mph, but car says 60mph.
Not really a big deal for me, plus I'm not "stock" so the slight negative gearing change by running the wrong size tire isnt a huge deal to me.
Old 04-29-2015, 03:49 PM   #48
continuecrushing
Sweet! I looked at your thread about 10 thousand times while waiting for my wheels haha. What are you lowered on? Throw up some more pics!
So far, you and I are the only ones on this forum I've seen running 17" Forgestar F14 wheels. There's a couple on F14F Forgestars, and a bunch on 18's...I almost went with 18's too.
The Following User Says Thank You to continuecrushing For This Useful Post:
cycleboy (04-30-2015)
Old 04-29-2015, 03:53 PM   #49
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm not typically a fan of silver twins, but yours really looks fantastic. Perfect ride height and fantastic wheels. Very nice work.
The Following User Says Thank You to Pat For This Useful Post:
Old 04-29-2015, 04:06 PM   #50
continuecrushing
I'm normally not a fan of silver cars myself, but the twins in Silver actually look pretty good.
The ride height he's at is the perfect lowered-but-daily-friendly level.
Old 04-30-2015, 09:27 AM   #51
cycleboy
Thanks guys, I'm on RCE Yellows so about 3/4" lowered. It feels close to stock in most cases except one dip I hit on the commute is a tad harsh.
I'm usually not a silver car guy either, but on this car I really like how it shows the lines and nuances of the design.
I went with the 17" F14 because as you said the ability to customize as you wish, price is reasonable (especially for that level of customization), and wanted to keep the weight at or below stock even while adding width.
I'll try to get some more pics. I haven't had a lot of time lately to get out and drive to good spots to do so.
Old 04-30-2015, 10:22 AM   #52
x1UP
One & Done (AOZORA)
x1UP's Avatar
Are those with spacers? I'm thinking about getting 25mm wheel spacers for all four on 235/40/18 tires.
Wondering if the spacers are really needed or will the 235's be wide enough for that flush look.
Also note that for now, I'm on stock suspension.
Old 04-30-2015, 12:15 PM   #53
continuecrushing
Good choice on the springs.
Like you said, the triple threat of price, weight and customization options are killer with these wheels. If I was more brave, I would've gone for a crazy color haha.
Old 04-30-2015, 12:20 PM   #54
continuecrushing
nope, definitely no spacers...I'm about as flush/aggressive you can get without rubbing.
What wheels are you getting(well, more specifically what size/offset)? 25mm is a pretty big spacer, imo.
Done right, you can certainly have a flush look with 235 tires.
Old 04-30-2015, 01:42 PM   #55
x1UP
One & Done (AOZORA)
x1UP's Avatar
I'm getting wheels in the size of 18x8.5 + 42 offset. So I'm thinking 235/40 would be the best option on stock suspension.
What's the right way to go about this?
Old 04-30-2015, 02:13 PM   #56
continuecrushing
you could probably go more aggressive with the wheels, but not another 25mm.
I would ask around on the "will this fit" forum area or check out the threads/links here so you can see various wheel sizes and what it looks like. You might even find the wheels you're looking to pick up.
My post HERE has photos of my 18x9 +40 with 245/40/18 on stock suspension, which was fairly flush.
x1UP (05-01-2015)
17x9, f14, forgestar, mod bargains, modbargains
ModBargains.com | Customer Spotlight - Scion FRS on 18" Forgestar F14's! ModBargains.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-19-2015 12:22 PM
Any of you guys have a photo of the Forgestar F14 in the 17x9 with a 35/45 offset? exE36M3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-09-2014 12:22 PM
Wheel Directory: Forgestar F14F 17x9.5 +38 lp87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 07-02-2014 02:41 PM
WTB Forgestar F14 18" Staggered ngabdala Want-To-Buy Requests 0 06-22-2014 12:41 AM
Wheel Directory: Forgestar F14F 17x9.5 +38 Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-17-2014 02:14 PM
