#1009 | |
PhoneFlash by EcuTeK
Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:19 PM. |
#1010 | |
Drives: 86
It will be interesting to see if a full closed lope innovate tune will gain more hp and tq or not. Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#1011 | |
Drives: 2013 FRS Whiteout
If running open loop then they don't use the 02's feedback(@wot) so the AFR readings could be different based on temp, humidity and so on regardless of the target AFR set? Now if running closed loop(as in your tunes) it will monitor the 02 and allow corrections at WOT and hit he target AFR most of the times. Trying to see if I understand what's going on here. Thanks.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#1012 | |
More than most of the time, unless something is seriously off, such as the front O2 failing, the AFR will always be correct and at target. In the event of the front O2 failing, the tune will resort to open loop again.Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:19 PM. |
#1013 |
Here's a Greddy turbocharged car we just tuned with our Flash n Go, getting ready for even more power soon:
[ame="https://www.youtube.com/watch?v=mHHq_1a2gQE"]GREDDY TURBOCHARGED BRZ 400rwhp 349rwtq - YouTube[/ame] |
#1014 | ||
Senior Addict
Drives: 86 GT
And when you say that your tunes run CL correction almost 100% of the time, is this applicable to the Innovate tunes as well, or only on the F&G? |
#1015 | |
![]() Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:19 PM. |
#1016 |
Drives: 2013 Toyota 86
Thats correct. In post #1012 he explains it
Innovate and Naturally Aspirated tunes still run Open Loop at WOT.
#1017 | |
So in the scenario where fueling is failing in some shape or form we are going to build in safety mechanisms, which can make the check engine light come on so you are aware there is a fueling issue. Cheers, William Knose Delicious Tuning |
#1018 |
Nice to see you are always looking to improve your tunes!
#1019 |
Drives: WRB JR BRZED
What's the average whp difference between your flash and go tune vs your custom dyno tune for a kit like the JRSC?
#1020 | |
![]() Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:20 PM. |
#1021 |
I also saw you had higher octane maps. The JR map says it adjusts automatically with higher octane. How does yours work on higher octane?
#1022 | |
| Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
| Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 02:33 PM |
