Old 04-15-2015, 01:31 PM   #1009
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by mikalem View Post
This true of the 8.83 release of the sprintex/innovate tune as well?
This is currently true for all of our Flash & Go tunes. Innovate and NA tunes are open loop on wide open throttle, and closed loop everywhere else.
Sincerely,
Old 04-15-2015, 02:25 PM   #1010
8686
8686's Avatar
Drives: 86
Sincerely,
Zach
It will be interesting to see if a full closed lope innovate tune will gain more hp and tq or not.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 04-16-2015, 12:21 PM   #1011
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Totally depends on the tuner. Most tuners run open loop at WOT, we just recently implemented closed loop correction at wot. I'm not aware of anyone else doing that right now for this platform, however. Our tunes are essentially running closed loop correction almost 100% of the time now.
Sincerely,
Zach
If running open loop then they don't use the 02's feedback(@wot) so the AFR readings could be different based on temp, humidity and so on regardless of the target AFR set? Now if running closed loop(as in your tunes) it will monitor the 02 and allow corrections at WOT and hit he target AFR most of the times.
Trying to see if I understand what's going on here. Thanks.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 04-16-2015, 12:48 PM   #1012
DeliciousTuning
That's correct. More than most of the time, unless something is seriously off, such as the front O2 failing, the AFR will always be correct and at target. In the event of the front O2 failing, the tune will resort to open loop again.
Sincerely,
Old 04-22-2015, 02:05 PM   #1013
DeliciousTuning
Here's a Greddy turbocharged car we just tuned with our Flash n Go, getting ready for even more power soon:
[ame="https://www.youtube.com/watch?v=mHHq_1a2gQE"]GREDDY TURBOCHARGED BRZ 400rwhp 349rwtq - YouTube[/ame]
Old 04-22-2015, 09:53 PM   #1014
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Sorry I'm a little confused. Is the v8.83 update apply to F&G tunes only?
And when you say that your tunes run CL correction almost 100% of the time, is this applicable to the Innovate tunes as well, or only on the F&G?
Fizz is offline   Reply With Quote
Old 04-22-2015, 10:33 PM   #1015
DeliciousTuning
8.83 is the latest version for Innovate tunes only. 14.65 is the latest version for Flash & Go. Closed loop correction is currently only applicable to Flash & Go tunes.
Sincerely,
Old 04-23-2015, 12:06 AM   #1016
Billion
Drives: 2013 Toyota 86
Thats correct. In post #1012 he explains it Innovate and Naturally Aspirated tunes still run Open Loop at WOT.
Billion is offline   Reply With Quote
Old 04-29-2015, 02:37 PM   #1017
DeliciousTuning
We are looking into implementing a closed loop fueling correction under WOT for the Innovate and possibly NA cars. Though I think this will be more of a safety precaution on these cars, more so than hitting target values since they are already so close.
So in the scenario where fueling is failing in some shape or form we are going to build in safety mechanisms, which can make the check engine light come on so you are aware there is a fueling issue.
Cheers,
William Knose
Old 04-29-2015, 02:48 PM   #1018
Billion
Nice to see you are always looking to improve your tunes!
Old 04-30-2015, 12:18 PM   #1019
enivid
enivid's Avatar
Drives: WRB JR BRZED
What's the average whp difference between your flash and go tune vs your custom dyno tune for a kit like the JRSC?
enivid is offline   Reply With Quote
Old 04-30-2015, 04:56 PM   #1020
DeliciousTuning
You'd be looking at a 5, maybe 10whp increase for a custom dyno tune at most. The Flash & Go has come quite a long way.
Sincerely,
Old 04-30-2015, 07:10 PM   #1021
enivid
enivid's Avatar
Sincerely,
Zach
I also saw you had higher octane maps. The JR map says it adjusts automatically with higher octane. How does yours work on higher octane?
Old 04-30-2015, 07:14 PM   #1022
DeliciousTuning
Our tunes will also account for higher octane, and add timing in accordingly.
Sincerely,
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
