Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 04-30-2015, 05:23 AM   #1
jarnoh
Drives: Satin White Toyota 86 hi-spec
Popping / misfire when changing 2nd - 3rd
Hi guys....been experiencing a a popping / misfire when changing from 2nd to 3rd at low rpms (3000rpm). This usually happens when car has been standing overnight / for a few hours. I have 17000km, and its a 2013 model....i know there have been some software issues for 2012 models.....just would like to know if you have experienced the same thing?
jarnoh is offline   Reply With Quote
Old 04-30-2015, 02:34 PM   #2
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Where is the popping coming from? If you start the car when cold do you hear a popping sound? No engine light?
What mods do you have? 17000km is relatively low- I've heard of other cars quite happily breaking 100k without major issues. I have 57k+ and no engine hassles.
The software hasn't changed from the 2012 model's upgrade I do believe.
Vic_RSA is offline   Reply With Quote
Old 04-30-2015, 06:00 PM   #3
steve99
Drives: FT86
That sounds a bit suspect.
Possible DI seal failure or coil pack failure
Is the popping from engine bay (intake) or exhaust
Occasionally you can get popping sound on startup in cold weather that seems normal especially on E85 fuel :-)
use an obd tool to check for engine codes not all codes will light up the CEL light on dash.
If its stock and under warantee take it to dealer.
Check your ECU software revision you should be on ZA1Ja01G manual (Za1Ja01I auto) if its earlier rev like 700G/900G/A00G then that firmware did not have transient ignition retard enabled and coupled with your crappy fuel and hard driving ie shifting at redline can cause DI seal failure due knock
see here
http://www.ft86club.com/forums/showthread.php?t=36008
Vic_RSA (05-01-2015)
Old 05-04-2015, 07:02 AM   #4
Dammod
Dammod's Avatar
Drives: .
Hi jarnoh,
You are welcome to bring the car past my place and I'll hook the laptop up + go for a drive and check the car out for you.
Dammod is offline   Reply With Quote
Old 05-04-2015, 07:23 AM   #5
jarnoh
Car booked for ECU software upgrade on Thursday.....just find it strange that they did not upgrade it on the 15000 km service.....still under warranty so hoping issue not big.....dealer said that a number of 2012-2013 models have had ecu upgrades done alrdy and toyota are aware of prblm......
Old 05-04-2015, 10:29 AM   #6
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Get them to replace your injector seals.
Ryan86 is offline   Reply With Quote
Old 05-04-2015, 10:33 AM   #7
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 05-04-2015, 10:53 AM   #8
jarnoh
Ja will do thanks Ryan
Misfire when cold Lawnik Engine, Exhaust, Transmission 5 10-05-2014 09:40 PM
Idle Misfire/Stumble Nightbringer Issues | Warranty | Recalls / TSB 20 09-19-2013 12:27 AM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 10:02 PM
Misfire Jono AFRICA 49 12-12-2012 07:01 AM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
