Old 04-29-2015, 04:18 PM   #1
dar3d3vil
dar3d3vil's Avatar
Drives: 2015 BRZ Limited
BRZ tow hook cut template
I know this might be a long shot, as I've doing a fair few searches and haven't come up with anything but does anyone happen to have the templates for drilling the towhook covers specifically for the BRZ? I know there are threads here with the templates for the FRS, but the towhook, at least on the 2015 BRZ if not earlier, is nothing like those shown in the templates.
Thanks for any help anyone can give.
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS
dar3d3vil is offline   Reply With Quote
Old 04-29-2015, 08:20 PM   #2
Poodles
Drives: 2015 Series.Blue
I think it's because that area is angled more on the BRZ and you have to cut more of an ellipse than a round hole. I removed the cap, installed the shaft of the tow hook, and then used masking tape around it to make my own template. You'll still have to do some fine tuning after that to get it to fit perfect.
Old 04-29-2015, 09:01 PM   #3
GTSRolla34
Drives: 2014 BRZ Limited - 1986 AE86
I cut mine and was able to get an extremely tight fit. I removed the tow hook cover and installed the tow hook by itself. Then used painters tape aligned on the edges of the portion of the hook that passes through the cover. I left enough painters tape on the various body panels so I could easily follow the lines.
I cut the tape along the covers edges, removed the tow hook, and reinstalled the cover.
I then placed tape over the portions left on the body until it formed an outline on the cover. I cut the hex shape out and test fit.
Due to the angle of the tow hook vs the body lines I had to trim a bit extra for clearance, but ended up with a cut that was nearly flush with the surface of the tow hook.
For reference I was using the Raceseng tow hook.
Of course, when I had a co-worker back into me the repair shop cut the new cover themselves (forgot to ask them not to) and it looks like the typical circlular/oval template cuts. Bugs me a bit.
2014 Subaru BRZ LTD - Dark Gray Metalic
1986 Toyota Corolla GTS - CA18DE Powered
http://club4ag.com/forums/viewtopic.php?f=7&t=1247
http://www.86garage.com/forums/viewt...hp?f=40&t=1459
GTSRolla34 is offline   Reply With Quote
The Following User Says Thank You to GTSRolla34 For This Useful Post:
Pwolf (04-29-2015)
Old 04-29-2015, 09:50 PM   #4
GTSRolla34
Here is an image of the cover I cut:
I used a razor blade and some small drill bits.
Old 04-30-2015, 08:59 AM   #5
dar3d3vil
dar3d3vil's Avatar
Thanks everyone.
I'll definitely give this a shot. I'm going to try using a paddle bit to drill it out and then use a gasket to seal it. Will see how it turns out.
Template for OEM Armrest? liajet24 Cosmetic Modification (Interior/Exterior/Lighting) 2 05-23-2022 05:58 PM
Template for tow hook cover DGM.BRZ BRZ First-Gen (2012+) — General Topics 6 04-14-2015 07:18 PM
Clear Bra Template Fit? Techfl3x Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-10-2013 02:00 PM
Tow-hook license-plate template? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 5 06-24-2012 12:51 PM
