#15 | |
Drives: 2005 Toyota Camry
Stock: Drove up to around 11k miles, which included several long roadtrips up to SF, Mammoth, and LA > Jackson WY > LA in 3 days. Ohlins: Currently around 20k on them, which includes around 15 track days, 2 autocross, and a LA > SF > OR > Sac > LA roadtrip over 4 days. There is one simple fact that you cannot dispute: with stiffer springs, you will feel like the initial ride quality is worse. Going over the same bumps at the same speeds will bounce you around more, all else being equal. But it's what happens after the bump that makes a difference. Stock is great, but will "float" for a split second more. The Ohlins settles nicely after the initial bump much faster than stock shocks. But... to see how any coilover can be uncomfortable, find a stretch of road with badly designed concrete expansion joints and you'll think you've made a horrible financial decision... a lot of people can't distinguish this. -alex |
| The Following 4 Users Say Thank You to mav1178 For This Useful Post: | donoman (04-09-2015), KoolBRZ (04-09-2015), Racecomp Engineering (04-09-2015), RJasonKlein (04-09-2015) |
#16 |
Drives: '13 FR-S
My FR-S has 22K or so miles.
I do agree that it handles great... regardless of the price. It handles better than any BMW I've ever owned... and that's a lot of them from E36, E46, E39, E85. |
| The Following 2 Users Say Thank You to donoman For This Useful Post: | RJasonKlein (04-28-2015), Sleepless (04-09-2015) |
#17 | |
Drives: 2015 Release Series 1.0 FRS
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
#18 |
he is probably just pulling that information because it is common in autox but i dont think he realizes that if you do that, it changes droop when loaded and that causes changes to camber gain and some other important things which cause problems for performance outside the realm of dodging cones.
Drive upgrades. Don't buy them.
#19 | |
Off Topic
#20 |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
Curious and side note: how much did you pay for your set of Ohlins? Considering getting a set, but don't know where to buy for a good price.
"I have the need....the need for speed! - Maverick (Top Gun)
#21 |
I'd recommend getting them from a shop that has run them before and has a good relationship with Ohlins USA. That way, you'd be able to call and talk to someone who has installed them on a BRZ, tracked them, found settings that work, etc. Pretty helpful.
(cough like us cough) - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | gramicci101 (04-27-2015), wparsons (04-27-2015) |
#22 |
#23 |
i probably shouldnt but i totally believe you.
#24 |
I got mine used, $2200. I cofounded a local car club in SF bay Area. We have about 400 members.
| The Following User Says Thank You to Raven240 For This Useful Post: | x1UP (04-28-2015) |
#25 | |
#26 |
#27 |
Laguna Seca.
Side question. That might be too much for me if it's track specific. I'm just looking for a blanket setting to track with and dial in from there. For example, 5 front 6 rear, 15 mm drop from stock. I'll be lowering my car tomorrow. Do Ohlins naturally sit lower than stock? How much lower?
#28 | |
As for track use, it entirely depends on what your comfort range is. I start with 5/5 and go up or down depending on track surface conditions. For Laguna Seca I end up with 3/3: [ame="https://www.youtube.com/watch?v=TnEnPtpIUms"]Laguna Seca Raceway - 27 December 2014 Subaru BRZ - YouTube[/ame] -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Raven240 (04-30-2015) |
| Ohlins Road & Track - settings (clicks) for street/track/ax | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 06-27-2016 10:36 PM |
| Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped | GuerillaRacing | Brakes, Suspension, Chassis | 149 | 05-12-2015 06:53 PM |
| Evasive Street BRZ Breaks 1:59 Stock Motor and Street Tires Buttonwillow CW13 Video | Evasive Motorsports | Tracking / Autocross / HPDE / Drifting | 31 | 07-02-2014 02:43 PM |
| Trailer | Ohlins Install | Interviews With Essex & Ohlins | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 12-24-2013 04:01 PM |
| Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship | Enjuku Racing | Brakes, Suspension, Chassis | 0 | 09-12-2012 06:12 PM |
