Old 04-09-2015, 11:52 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by RJasonKlein View Post
One question I have for you is: How many miles are on your FR-S/BRZ? I ask because my car was far stiffer over sharp edged bumps when new, but after about 1,500 miles it became much more supple (although it still seems over-damped to me). If your car is still new, it will settle down shortly.
I can help answer this since I have very comparable scenarios of stock vs Ohlins:
Stock:
Drove up to around 11k miles, which included several long roadtrips up to SF, Mammoth, and LA > Jackson WY > LA in 3 days.
Ohlins:
Currently around 20k on them, which includes around 15 track days, 2 autocross, and a LA > SF > OR > Sac > LA roadtrip over 4 days.
There is one simple fact that you cannot dispute: with stiffer springs, you will feel like the initial ride quality is worse. Going over the same bumps at the same speeds will bounce you around more, all else being equal. But it's what happens after the bump that makes a difference.
Stock is great, but will "float" for a split second more. The Ohlins settles nicely after the initial bump much faster than stock shocks.
But... to see how any coilover can be uncomfortable, find a stretch of road with badly designed concrete expansion joints and you'll think you've made a horrible financial decision... a lot of people can't distinguish this.
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
donoman (04-09-2015), KoolBRZ (04-09-2015), Racecomp Engineering (04-09-2015), RJasonKlein (04-09-2015)
Old 04-09-2015, 03:26 PM   #16
donoman
donoman's Avatar
Drives: '13 FR-S
My FR-S has 22K or so miles.
I do agree that it handles great... regardless of the price. It handles better than any BMW I've ever owned... and that's a lot of them from E36, E46, E39, E85.
donoman is offline   Reply With Quote
The Following 2 Users Say Thank You to donoman For This Useful Post:
RJasonKlein (04-28-2015), Sleepless (04-09-2015)
Old 04-27-2015, 07:49 PM   #17
Raven240
Drives: 2015 Release Series 1.0 FRS
Stock:
Ohlins:
-alex
How much did you lower your car? I just picked up a set of Ohlins and I'm currently sitting at stock height.
075/1500 2015 Scion FRS Release Series 1.0 / Jackson Racing Supercharger + Oil Cooler / Tom's Red DOT LED lights / 18s staggered Enkei Raijin with RS3 / TRD Short Shifter / 328 Stoptech BBK Front / Velox Motorsports Diffuser / Whiteline bushings / Ohlins RT Coilovers / VIS Carbon Fiber Hood.
Raven240 is offline   Reply With Quote
Old 04-27-2015, 08:28 PM   #18
fatoni
Originally Posted by gramicci101 View Post
Are you still pushing that nonsense? Do you still firmly believe that you clearly know better than all the suspension engineers in Toyota and Subaru and all the aftermarket companies that build products for our cars?
he is probably just pulling that information because it is common in autox but i dont think he realizes that if you do that, it changes droop when loaded and that causes changes to camber gain and some other important things which cause problems for performance outside the realm of dodging cones.
Drive upgrades. Don't buy them.
Old 04-27-2015, 08:33 PM   #19
gramicci101
Off Topic
You should read some of his threads. He takes a shotgun approach to solving nonexistent problems and then blows off everyone who actually knows what they're doing.
Old 04-27-2015, 08:34 PM   #20
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
Curious and side note: how much did you pay for your set of Ohlins? Considering getting a set, but don't know where to buy for a good price.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 04-27-2015, 09:24 PM   #21
I'd recommend getting them from a shop that has run them before and has a good relationship with Ohlins USA. That way, you'd be able to call and talk to someone who has installed them on a BRZ, tracked them, found settings that work, etc. Pretty helpful.
(cough like us cough)
- Andy
gramicci101 (04-27-2015), wparsons (04-27-2015)
Old 04-27-2015, 09:43 PM   #22
mav1178
mav1178's Avatar
Rear was maxed out, about 30mm.
Front was around 35mm, but after installing the Raceseng upper mounts I ended up around 40mm lower than stock.
-alex
Old 04-28-2015, 01:09 AM   #23
fatoni
i probably shouldnt but i totally believe you.
Old 04-28-2015, 01:59 PM   #24
Raven240
I got mine used, $2200. I cofounded a local car club in SF bay Area. We have about 400 members.
The Following User Says Thank You to Raven240 For This Useful Post:
x1UP (04-28-2015)
Old 04-28-2015, 02:24 PM   #25
Raven240
- Andy
Lol. So what's the prescribed track setting? =)
Old 04-28-2015, 02:31 PM   #26
mav1178
mav1178's Avatar
What track?
Old 04-29-2015, 04:14 PM   #27
Raven240
What track?
Laguna Seca.
Side question. That might be too much for me if it's track specific. I'm just looking for a blanket setting to track with and dial in from there.
For example, 5 front 6 rear, 15 mm drop from stock.
I'll be lowering my car tomorrow. Do Ohlins naturally sit lower than stock? How much lower?
Old 04-29-2015, 05:11 PM   #28
mav1178
mav1178's Avatar
Laguna Seca.
Ohlins is disassembled when it is shipped, so the "natural" setting is whatever you set it at.
As for track use, it entirely depends on what your comfort range is. I start with 5/5 and go up or down depending on track surface conditions.
For Laguna Seca I end up with 3/3:
[ame="https://www.youtube.com/watch?v=TnEnPtpIUms"]Laguna Seca Raceway - 27 December 2014 Subaru BRZ - YouTube[/ame]
-alex
Raven240 (04-30-2015)
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
Evasive Street BRZ Breaks 1:59 Stock Motor and Street Tires Buttonwillow CW13 Video Evasive Motorsports Tracking / Autocross / HPDE / Drifting 31 07-02-2014 01:43 PM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
