Old 04-28-2015, 11:53 AM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by regandr View Post
I have 50 track days on a '13 BRZ. totally stock car. also 30 yrs. SCCA and PCA race experience. I have done many oil analyses on my cars.
I run exclusively 0W-40 Mobil 1 because it has a synthetic base stock. Most synthetic oils today do NOT come from a synthetic base stock. (check with your oil mfg. if you dont believe me) Change your oil and filter after every other track weekend and you will be fine. High oil temps on the track break down the additives and base stock so do not stretch oil change interval. Most importantly, check oil level after every on track session. FRS and BRZ motors use oil at sustained high RPM.
Hey Don, good to see you on here. @wheelhaus and I have been talking about this recently. He's seeing oil temps on the track no more than 262F, which is quite a bit less that some of the other people here that live at elevations lower than 6,000 feet. We think our oil temps are lower because we're not making the same amount of power up here that others are near sea level. Therefore, our oil analysis might not be quite the same as what others see. Just some food for thought. It's probably not going to make a huge difference, but I think it's something to consider.
When will you be at HPR or Pueblo next?
The Following User Says Thank You to Pat For This Useful Post:
wheelhaus (04-28-2015)
Old 04-28-2015, 12:13 PM   #16
wheelhaus
wheelhaus's Avatar
FYI I'm using a Scangauge II that reads oil temps from the factory sensor location, which IIRC is under the oil filter.
Oil Change Interval Change (Subaru recommended) Flow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 09-10-2014 08:27 PM
First oil change before track day? MrMista Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 09-07-2013 08:25 PM
Change oil before/after/both track day? THEmailman Tracking / Autocross / HPDE / Drifting 6 03-25-2013 03:08 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-21-2012 12:31 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 07:46 PM
