Old 09-06-2013, 03:53 PM   #1
MrMista
Drives: 2013 BRZ, Satin White Pearl, MT
First oil change before track day?
Hello everyone,
Right now my car is sitting at around 3,200 miles. In October I will be going to my first track day and I will not have reached the 7,500 mile recommended change by then.
Would you guys suggest that I go ahead and change my oil before that track day? I'm not sure if it is a bad idea to stress the engine that hard on the first oil fill, or if it doesn't matter.
I plan on doing the change myself, would pretty much any fully synthetic oil be a good choice?
Thanks!
MrMista is offline   Reply With Quote
Old 09-06-2013, 04:09 PM   #2
frslee
Just drive it
Drives: 13' FR-S
I'm not an oil expert, but I'd just change it for the peace of mind. I used Mobil 1 0W-20 as I'm not really OCD about which oil I use. It was fine on the track!
frslee is offline   Reply With Quote
Old 09-06-2013, 04:19 PM   #3
MrMista
Oh one last thing. I assume that I'd also want to change the oil filter. The general consensus on that is to use the black (no the blue) Subaru oil filter?
Old 09-06-2013, 07:23 PM   #4
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Yes, use the black filter made by Toyo roki if you can.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 09-06-2013, 07:41 PM   #5
OrbitalEllipses
Drives: Attitude
If you don't change it the car will blow up spectacularly.
Old 09-06-2013, 07:43 PM   #6
zoomzoomers
zoomzoomers's Avatar
Drives: 2013 Subaru SWP BRZ Limited 6AT
There are some guys that say to keep that factory fill as long as you can, up to the recommended change interval. Something about mollys and dodads. Maybe just change out the filter and roll with the stock fill until the change interval?
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam.
zoomzoomers is offline   Reply With Quote
Old 09-06-2013, 07:52 PM   #7
leon78
leon78's Avatar
Drives: 13 Whiteout
Change it...Race it...Party on!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 09-06-2013, 11:27 PM   #8
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Any full synthetic would do well. I personally use Valvoline SynPower because theyre sold at a better price than the other 0w-20 (Mobil1/Pennzoil Platinum)
LeeMaster is offline   Reply With Quote
Old 09-06-2013, 11:47 PM   #9
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
If you can get some Pennzoil Ultra 0W-30, go with that.
Jidonsu is offline   Reply With Quote
Old 09-07-2013, 12:33 AM   #10
Dezoris
Dezoris's Avatar
Change and and use an oil with higher moly content, as it continues to cure/harden metals after break in.
I would not run the factory fill with all the contaminents on the track.
Old 09-07-2013, 10:21 AM   #11
fstlane
fstlane's Avatar
Drives: BRZ Limited
I personally would just replace the filter with a OEM black Roki filter and run the factory fill until around 5000 miles. The do a complete oil change using a full synthetic GF-5 0W-20 oil. I would recommend the high moly Mazda oil that sells for $7.00 per quart from your local Mazda dealership. It's awesome oil at a great price. Have fun!
fstlane is offline   Reply With Quote
Old 09-07-2013, 07:25 PM   #12
bluesubie
I would only change it if you know that you can get another 500-1,000 miles on the new oil prior to the track day. Otherwise, there's really no rush IMO. It takes time and heat for the ZDDP in the new oil to activate. Even on a car that is fully broken in, wear metals sometimes actually decrease the farther along you are into the oil change interval.
http://www.bobistheoilguy.com/forums...Number=1528239
You would need to do uoa's at 1k, 2k, 3k, etc. without changing the oil to see this happening. And I would go with a high moly oil like the Mazda oil above. It's in the factory fill, but the only oils that contain similar amounts to the factory fill and the Mazda oil are racing oils like Motul 300V and Red Line. The old school molybdenum disulfide, that is. Not the new tri-nuclear moly used in lower doses in some oils to achieve a similar friction modification effect as the MoS2 in the above oils.
I would really like to get smbrm's view on this, but haven't seen him post here in a while. Another option is to contact Idemitsu Lubricants of America since they're the ones that made the factory fill.
-Dennis
bluesubie is offline   Reply With Quote
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
Change oil before/after/both track day? THEmailman Tracking / Autocross / HPDE / Drifting 6 03-25-2013 02:08 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
