Old 04-27-2015, 06:30 PM   #1
Jake_86
Jake_86's Avatar
SuperTek Trans mount Questions. worth discomfort?
Just installed the TRD quick shifter, throws are super short but the slight notchiness from before now is somewhat harder.
installing some MTEC springs to fix that problem(feel free to give other opinions/solutions on this matter as well)
the dude i had picked those 2 parts from also had
supertek solid trans mount support http://www.ft86speedfactory.com/supe...port-1351.html
What i was wondering for the supertek mount support.....
Install instructions say that all the excess force will be delivered to the drive wheels at the price of comfort. says it can become pathway of vibration and cause the chassis to vibrate and the transmissions to whine at higher loads. says not recommended for street use. while i do drive my car hard, its also my DD. should i even bother installing? has anyone else installed and have comments? should i just installl and see how i like it, risking the need to uninstall? why am i asking so many questions? have you really read this far down? thank you. comments?
heres this dope 86 for showing up
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 04-27-2015, 07:03 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
I have that insert, the only thing I have noticed was a slightly audible gear whine if you are slow enough that the wind/tire noise doesn't drown it out.
Other than that, I've forgotten I had it installed until I read your post lol
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 04-27-2015, 07:09 PM   #3
Jake_86
Jake_86's Avatar
youre reffering to the Supertek support block correct? not the torque solutions insert
Old 04-27-2015, 07:11 PM   #4
Jake_86
Jake_86's Avatar
also
but no obvious chasiss vibrations?
Old 04-27-2015, 07:31 PM   #5
DJCarbine
Thupercharged
DJCarbine's Avatar
Correct, the Supertek support block.
I did not notice any chassis vibrations or shifter rattle
::edit
Also this is my DD, and the support block has been in for the past 17K miles
2013 FRS
Vortech V3 11psi
Old 04-27-2015, 07:38 PM   #6
ryoma
ryoma's Avatar
I believe that insert limits the front/back movement of the transmission. there is a thread about the perrin insert (which this looks like) compared to the whiteline bushing and the pros/cons of each. that would a good thread to check out. I'll see if I can find it
edit: here you go http://www.ft86club.com/forums/showthread.php?t=20926
The Following User Says Thank You to ryoma For This Useful Post:
Jake_86 (04-27-2015)
Old 04-27-2015, 07:42 PM   #7
Jake_86
Jake_86's Avatar
thanks! yeah i actuallly have a torque solutions bushing to install as well(same as whiteline basically)
but yes looks just ike the perrin one, so ill probably start researching that as well, thanks for the helP!
Old 04-28-2015, 03:53 PM   #8
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I took my mount out and filled it with window urathane. It's much stiffer now, never needs to be greased, and it didn't noticably increase noise or vibration. I've been using this stuff for years to make engine mounts, stiffen engine mounts, fix broken mounts, stiffen chasses, heck everything. Every seem in the rear my 2014 was filled with this stuff & it made the car way quieter. I had no rear deck rattle at all, even with 800 watts and a 10 in the trunk.
http://www.nicoclub.com/archives/make-your-own-motor-mounts-heres-how.html
http://poormanmods.wonderhowto.com/how-to/diy-polyurethane-engine-mount-0139034/
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
FS: Whiteline positive shift (trans mount) and subframe bushing kit twincamRob Transmission and Driveline 9 02-17-2014 01:17 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
Trans/Motor Mount question DanoFA20 Engine, Exhaust, Transmission 5 03-02-2013 03:16 PM
