Old 04-26-2015, 09:19 PM   #267
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
http://www.datazap.me/u/jonathanhwan...0&data=1-12-13
Can someone check this out? Not sure what I should be looking out for exactly. Logged some daily driving with a few pulls here and there. First time doing and using this! Very interesting and fun
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-26-2015, 09:50 PM   #268
steve99
Drives: FT86
looks reasnoble
bit if negitive flkc knock arround 4000. nothing too bad
you fuel trims look way negitive is this first tank of e85 ?
the residual petrol will cause negitive trims.
FRS Johnny (04-26-2015)
Old 04-26-2015, 11:17 PM   #269
FRS Johnny
FRS Johnny's Avatar
looks reasnoble
Yeah it is the first tank of e85. Trying to drive it around more to get a full fresh tank of e85. Will log again when I get another tank!
What are some things to look for for future reference? So I can keep an eye on things. Thanks for taking a look at the log. You are the e85/tune know it all on here
Old 04-27-2015, 01:16 AM   #270
steve99
Drives: FT86
I only know the very basic's mate :-)
Have a read of the links below on logging and maf scaling ect
Old 04-30-2015, 01:43 PM   #271
SamGam
Drives: '13 BRZ SWP 6MT
I'm looking to get headers on my car, does anyone know how much more hp/tq we could gain from a custom e85 map for headers vs the off the shelf stage 2 e85 map?
Just wondering if its worth the extra money for the custom map.
SamGam is offline   Reply With Quote
Old 04-30-2015, 05:24 PM   #272
steve99
Drives: FT86
Depends on many factors
But from what I have seen cutting through all the BS, mods being equal you might get maybe 5 hp if your lucky.
However you might smooth power delivery low midrange and get a bit better fuel economy with a custom tune. Probably only worth it if you are running non standard intake. You could do most of it yourself with a bit of reading.
http://www.ft86club.com/forums/showthread.php?t=53946
Old 05-10-2015, 06:29 PM   #273
nelsonzep
Drives: 2013 Scion FRS
E85
I have a question about this tune, how does it effect the current gauge for amount of fuel in the tank. Will i have to fill up at about 1/4 left or will it just drain faster than usual?
And also the mpg? will the ecu adjust the mpg or will it be incorrect or does the tune correct that as well?
nelsonzep is offline   Reply With Quote
Old 05-10-2015, 06:44 PM   #274
DC2R
Drives: 2014 Scion FR-S
Gauge will operate same.
The mpg meter will be off. Usually it reads about 2 mpg higher than reality but when you use ethanol it's way off. Though I recall some way to adjust the readout....
DC2R is offline   Reply With Quote
Old 05-10-2015, 06:46 PM   #275
steve99
Drives: FT86
Fuel gauge (ie fuel in tank) will read correctly as per normal
MPG readout will be aprox 30% off due to injector rescaling ie if it says 30mpg you actually getting about 21mpg
Old 05-10-2015, 06:59 PM   #276
nelsonzep
Alright thank you! is there any way to adjust the read out on mpg?
Old 05-10-2015, 07:18 PM   #277
steve99
Drives: FT86
its possible their are some tables in ECU to adjust this, but no one has bothered to test.
you economy will be aprox 25% worse on E85 than on petrol but the fuel is cheaper.
Old 05-10-2015, 11:42 PM   #278
kchar
Because Racecar
kchar's Avatar
Hey I'm running a v2.061 uel E85 and for some reason my rev limiter is set to 4600 but when I look at the tune in RomRaider its 7600. I've got crank tables, base timing B, and maf scaling changed. I can't figure out what's going on, any ideas?
kchar is offline   Reply With Quote
Old 05-10-2015, 11:48 PM   #279
steve99
Drives: FT86
Are you talking about Launch control limit ie when car stationary
or Flat foot shift limit when car moving and clutch depressed
of rpm limit when clutch engaged and over 10kmh
Old 05-10-2015, 11:51 PM   #280
kchar
Because Racecar
kchar's Avatar
I believe it's just the regular rev limiter because my LC delta is set to 2600 and i'm not reaching the 5k. My Flat foot is set to 0 so that shouldn't be on.
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 03:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 05:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 02:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 01:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 01:50 AM
