Drives: Gt86 1jz-gte
Gt86 1jz problems, help please
I'm new at this group guys i have a 2013 gt86
I fitted 1jz engine twin turbo the old engine. But i have problems: Rpm not working Cruise control not working ABS not working Please advice or help me if you can. |
#2 |
I wanna go fast
Drives: 2013 FR-S 6MT
did you shut it down and turn it on again?
| The Following User Says Thank You to 2much For This Useful Post: | raven1231 (04-27-2015) |
#3 |
Did all the sensors get put back in the right places and hooked up?
#4 |
Drives: Nissan Murano
Did you set it to wumbo?
| The Following 4 Users Say Thank You to airjonny For This Useful Post: |
#5 |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Rpm not working on the oem display/cluster?
If so, it won't work unless you're utilizing the frs crank sensor with a custom fabricated trigger for it to read from the jz crank. Even then chances are it'll be off from a true reading... Cruise control--- lol abs likely wont work until you have a "happy" crank signal
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#6 |
Willing to be they didn't hook up the factory ECU which has to be done. Bet they just used the 1j ECU to make it run but didn't realise you need to integrate the factory ECU to make all the other systems work.
#7 | |
From where can i get the fabricated triger ? |
#8 | |
They tried to conect the factory ecu with the 1jz ecu, they couldn't.. Thre is a way to do that? |
#9 |
#10 |
I'm pretty sure you have to or you need to run an aftermarket ECU like a Haltech elite. All the cars main systems run through the factory ECU, and if it isn't incorporated in some way nothing will work because it doesn't know it's running.
#11 |
Drives: 2014 GT86
Is there any way you could contact Ekanoo in Bahrain? I'm sure he has a lot of information that could probably help you solve these small issues. Other than that you've got a lot more work to do.
#12 |
APEXHNTR
Drives: 10 Series FR-S #1867
Sounds like you're in way over your head.
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#13 | ||
I knew they were different but wanted to see what the OP had to say about it. People need to do their research before they start the project not during or after. Was sort of mean but:
#14 |
This! try restarting it
| AT problems? | AJPG | Engine, Exhaust, Transmission | 8 | 03-08-2015 06:50 AM |
| DRL problems | kk808hi | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 09-27-2014 12:33 AM |
| ACT 6 Pug Problems, anyone have it like me? | kombatlion | Engine, Exhaust, Transmission | 12 | 08-06-2014 11:30 AM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) | RadOnc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-23-2012 08:42 AM |
