Old 04-25-2015, 11:16 PM   #10557
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
WHAT DID YOU DO TO YOUR FRS TODAY?
Finally got my new HID kit installed and did some adjusting. Still need to adjust the height but the cut off is amazing for these not being retro fitted. Good job spyder! [
Old 04-26-2015, 08:31 AM   #10558
roddy
roddy's Avatar
Drives: '13 Ultramarine
Changed rotors (OEM Subaru) and brake pads (TRD). Adjusted parking brake.
Old 04-26-2015, 09:07 AM   #10559
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Originally Posted by roddy View Post
I'm usually a 5 or 6 spoke kind of guy, but those look great. The color suits the car very well. Nice.
Thanks, I looked at the RPF1s side by side wjth the OZs they both weigh 15.8lbs. I felt that black was too dark against the yellow and the silver was too pale. Also the OZs have a built in hub-centric adaptor that snaps into the wheel and they come with the center cap so that closed the deal. My main focus was getting the lightest wheel I could afford. 18s would probably look better but 17s are lighter and should perform better.
They are actually more charcoal than the pics.
Caspeed is offline   Reply With Quote
Old 04-26-2015, 02:09 PM   #10560
Did some quick aero work for even moar hp. Butt dyno approves.
Old 04-26-2015, 04:09 PM   #10561
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You need to start a thread about it, bro.
Inform the masses with your superior knowledge.
Old 04-26-2015, 04:23 PM   #10562
There are only a couple people on here who could handle the math.
Old 04-26-2015, 05:12 PM   #10563
D_Thissen
D_Thissen's Avatar
Looks like you will get about 15% better cooling. Can you confirm that?
Old 04-26-2015, 05:20 PM   #10564
Jake_86
Jake_86's Avatar
installed TRD quick shifter. alot shorter throws but they are a lil tougher, i think its supposed to smooth out over a few weeks to a month if i remember from past forums
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 04-26-2015, 05:21 PM   #10565
I didn't take a baseline but it sounds about right.
Old 04-26-2015, 06:45 PM   #10566
I would say about 15.628% since the bend actually diverts airflow down as well as not block the rad. Would probably feel a huge difference in the weight distribution if he changed those steel plate bolts to plastic.
Old 04-26-2015, 08:12 PM   #10567
In addition, one could achieve additional weight savings and air flow to the radiator, by drilling holes in that solid plastic panel on either side of the license plate ....
Old 04-26-2015, 08:16 PM   #10568
Of course! I can immediately feel the difference in over steer as I make my 10mph turns in busy traffic.
Old 04-26-2015, 08:22 PM   #10569
REAV3R
Former Boost Junkie
REAV3R's Avatar
Drives: Ultramarine FR-S
10 MPH!!!! Oh you naughty boy...
"Asking the front wheels of a car to do their normal job of steering while handling more than 170hp is like asking a man to wire a plug while juggling... penguins... while making love... to a beautiful woman while on fire, on stage... in front of the Queen. It's all going to go wrong." ~ J.Clarkson
REAV3R is offline   Reply With Quote
Old 04-26-2015, 08:28 PM   #10570
Obviously a typo and I meant 100. I can certainly tell the difference.
