#2451 |
Good aero with quality suspension...done right...can really change the way you set-up and drive the car and be a big advantage. If you're new to the track and car set-up then IMO I would recommend keeping things simple. (not saying you are, I don't know you're history).
- Andy |
#2452 | ||
Drives: 2015 Series.Blue BRZ
Currently using 245/45/17 pilot super sports, going to upgrade brake fluid only for the may track day and see how it goes. Had some decent fade earlier this month. Quote:
My first post basically had my entire tracking history. 1 weekend at TWS, 1 weekend at MSR-H, and I'll be at MSR-H again may 16/17th. MSR-H being my hometown track.
#2453 | |
That Guy
Drives: 2013 asphalt FRS MT
#2454 |
Drives: 2017 BRZ
The rear subframe bolts were miserable. I got one after a minute if fiddling, the other took almost five minutes, finally got it after using a 2x2 to apply a little pressure in the right direction as I threaded the bolt. It kept pretending to be threaded then falling out.
Totally worth it. It was about 50F when I installed mine. No trouble other than those bolts. |
#2455 |
Drives: red brz
@Racecomp Engineering , I have my 900hp brz which mainly a street/drag straight line car,
what do you recommend for coilovers ? rates ? bushing ? diff support ? for better straight line traction and high speed stability ? thanx |
#2456 |
Drives: GT86
@Racecomp Engineering @CSG Mike
Seems my suspension is faulty and the vendor has offered to refund it so it looks like I'm in the market for something else. My use is 90% street and 10% track (sprints). My shortlist is:- KWV3 KW Clubsport AST 5100 Ohlins R&T HKS Hypermax IV GT HKS Hypermax IV SP Bilstein B16 The ohlins and the AST's are at the top of my budget and the HKS come in as the cheaper options. For my usage what would you recomend? I run the car in summer on Federal 595RS-R's. Thanks! |
#2457 | |
#2458 |
Drives: GT86
I'm doing six sprint days this year - probably six to eight next year. I have the whiteline rear upper camber bushes so wasn't going to get LCA's. The ohlins, ast's and hks options would have camber plates. The kw's I was going to use upper camber bolts with the 'ovaled' mounting hole they have. I hadn't really thought what I'd do with the Bilstein's.
#2459 | |
From your list, I'd go with the Ohlins if you prefer an easy to drive, but comfortable setup. I'd seriously urge you to consider spending a little bit more so that you can get a mid-range two way damper, rather than a high end one way damper. |
#2460 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#2461 |
Just the tip
@CSG Mike or @Racecomp Engineering I'm looking for your thoughts on brake upgrades. Feel free to look at my build thread again since it may have been a while. I'm around 250whp, running RE-11a 245r17. I track 4-6 times a year with around 4 autox a year. The rest is daily driving. I live in the Portland area so no salt is used on the roads. Would you recommend the AP Racing Sprint kit with a set of pads for racing and a set of pads for street use or some other setup? A guy that was running the Sprint kit at the track when I was there says it's a night and day difference from stock (not sure if stock for him was with or without track pads on his stock rotors/calipers).
My last track day my car did double duty (2 people shared my car on track taking turns), and my rotors were pretty tore up. The pads Carbotek AX-6 front and rear were great until near the end of the day when the front pads and very noticeably uneven wear with more wear at one end of the pad vs the other. The rotors (stock) also seems warped as the breaks felt like they were pulsing even afterwards on the drive home with normal constant street driving pressure. I swapped the rotors with an extra stock set and the breaks were fine again after also swapping pad onto the stock street pads. Also eventually thinking about getting a set of racing slicks and another set of cheap wheels, since I can't afford the amazingly light TSW that you guys have on your site.
Past (sold): Click here to see previous cars and bikes ![]() Last edited by stockysnail; 04-27-2015 at 04:16 PM. |
#2462 |
Drives: GT86
#2463 |
Drives: GT86 Cosworth
Decon - we dont have a huge choice of good 2 ways coilover at reasonable prices.
The Ohlins DFV can be had for £2066 which is a bargin (US readers we brits have 20% tax added ~ $2650 before tax) We have the Tein SRC at around £3200 but they come with 10kg front, 12kg rear rates and even though the damper is excellent, it will be firm on the street. A more affordable alternative is the Tein Monosports (which I am still waiting on CSGs input vs Ohlins) which has 8kg front and 9kg rear rates, but the damper is not as good as the SRC and only one way adjustable. These sell at about £1500 which is a bit close to the ohlins really. Again I'd love to hear CSGs opinion of these vs Ohlins as the price is close in the UK. |
#2464 |
I guess the main point about the Monosport vs the ohlins is the 8kg front and 9kg rear spring are more track focused with less understeer than the "safer" and softer Ohlins.
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
