Old 04-24-2015, 08:29 PM   #1
pszuvela
pszuvela's Avatar
Drives: 2013 BRZ Limited - Manual, WRB
OIL LEAK STILL PRESENT AFTER INSTALLING NAMELESS PERFORMANCE PLATE
Hey guys,
I've been battling this pesky leaky cam plate issue for over a year now. I've had it into the dealer 3 times only to have it leak on the way home from the dealer the last time! At that point I decided to buy the Nameless Performance Cylinder Head Cover/Oil Leak Delete Kit.
I removed the stock plate and cleaned the mating surfaces with a red brillo pad, which works great for removing RTV gasket material while being less chemically than a solvent and less abrasive than a putty knife. I had the car on my lift so I had a great view from underneath the car to make sure all the surfaces were clean. It still leaked. Nameless even sent out a second plate to see if the first one was the issue but it still leaks.
My question is this:
Has anyone had a similar experience trying to eliminate this leak and if you were able to stop it, how did you do it?
I've read up on this topic quite a bit over the last year and have read through most of the threads on this forum pertaining to it but I haven't seen anyone have the problem AFTER installing an aftermarket plate such as Nameless or Raceseng.
PLEASE HELP
- Pete
pszuvela is offline   Reply With Quote
Old 04-24-2015, 09:19 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Did you use gasket sealant when you put the plate back on? I left mine to dry for 24 hours before driving the car and it hasn't leaked since.
Old 04-24-2015, 09:30 PM   #3
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
http://www.ft86club.com/forums/showthread.php?t=84656
Get Raceseng's plate. No problems with mine. Tried the Nameless one was a waste of money, looked cool though...
00NissanNinja is offline   Reply With Quote
Old 04-25-2015, 07:13 PM   #4
ohmai18
ohmai18's Avatar
Drives: Subaru BRZ
Need aftermarket cam plate. The factory one is not good enough.
ohmai18 is offline   Reply With Quote
Old 04-26-2015, 02:31 AM   #5
pszuvela
pszuvela's Avatar
I haven't used rtv gasket yet but that's the next step. I plan to do that tomorrow. I was just surprised to see it leaking immediately after. I didn't think I'd need to supplement with rtv as they advertise it as guaranteed to not leak.
Old 04-26-2015, 02:38 AM   #6
JB86'd
JB86'd's Avatar
Drives: JAWS
You're not using RTV and are surprised it's leaking.
JB86'd is offline   Reply With Quote
Old 04-26-2015, 02:49 AM   #7
pszuvela
pszuvela's Avatar
Thanks for the link. Interesting to see others have the same problem. Did you have to use rtv with the Raceseng plate? Any leaks with it? I personally don't care what the piece looks like since its at the back of the motor. Functionality is most important to me.
Well I guess I'll see how rallysportdirect.com customer service handles my warranty request.
Old 04-26-2015, 05:00 AM   #8
cnk
I have the Raceseng plate and the instructions say to use sealant.
Old 04-26-2015, 05:29 AM   #9
FirestormFRS
You have to use some sort of formed in place gasket.
FirestormFRS is offline   Reply With Quote
Old 04-30-2015, 05:12 PM   #10
00NissanNinja
The Thread Lurker
Well Nameless did say it does not require RTV
Old 04-30-2015, 05:25 PM   #11
JB86'd
JB86'd's Avatar
Drives: JAWS
Oh that's strange, didn't realize that. The Raceseng one uses RTV and it fixed my leak. Obviously they're wrong or people are installing it wrong.
Old 04-30-2015, 05:49 PM   #12
00NissanNinja
The Thread Lurker
Yeah, I don't know if it would work even doing it the Raceseng method of RTV application. When I installed it I was thinking to myself "I really don't feel like this o-ring is being crushed at all." A minute or two of running and oil was pissing out of there. You know how with Raceseng the o ring contacts the face of cam hole? On the nameless it kinda sits inside the hole more so than around it on the face (which is more what I expected). You'd probably almost have to do it factory style with RTV all around it to make it work, unless I got a defective part. But it would seem I am not alone.
Anyways Raceseng FTW, zero issues for several months now.
Old 04-30-2015, 11:35 PM   #13
pszuvela
pszuvela's Avatar
Thanks for all the input folks. I am going to return the Nameless plate and I ordered the Raceseng plate yesterday. This should fix the leak. I'll post up when I finish.
Old 05-11-2015, 03:45 PM   #14
pszuvela
pszuvela's Avatar
UPDATE - I installed the Raceseng plate last week and so far have had zero drips. And Rallysportdirect.com is going to take care of me on the Nameless plate that didn't work. I continue to be impressed with their stellar customer service!
Cam Plate Leak Repair Extreme86 DIY (Do-It-Yourself) Guides 52 06-14-2020 11:13 AM
Nameless Performance Cam Plate 00NissanNinja Engine, Exhaust, Transmission 1 11-20-2014 08:19 PM
Is Raceseng cam plate really works? No Oil leak yet. skyloran Engine, Exhaust, Transmission 16 06-03-2014 03:04 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Groupbuys 63 10-18-2013 03:31 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Engine, Exhaust, Transmission 2 09-21-2013 07:47 PM
