Old 04-13-2015, 02:42 PM   #1
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
SPL LCA ver. 2 Adjustment Levels?
Recently picked up a set of SPL LCA's, unknowingly there are two different versions now available.
I was thinking I'd get the standard (3) holes for sway bar link with (3) holes for coils/strut, but instead I got what apparently is the version 2 with (6) holes for sway bar, and (6) holes for coils.
Anyone know the effects of mounting the sway bar link and coils in each of the different holes has on the car?
(Picture is not mine, taken from FT-86SpeedFactory)
Thanks,
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 04-24-2015, 08:18 PM   #2
ck-GT86
ck-GT86's Avatar
Anybody?
|| My Build Thread ||
Old 04-24-2015, 11:07 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Did you contact SPL directly?
The Following User Says Thank You to dem00n For This Useful Post:
Captain Snooze (04-25-2015)
Old 04-24-2015, 11:42 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
The further away the hole is from the pivot (chassis), the moment arm increases in length, which means motion ratio increases. It can be used as a fine tuning method.
Further from center of chassis the lower shock mount is, the stiffer the spring will seem. Having the lower shock mount closer to the pivot point will decrease the effect of the spring and damper.
You can think of it as holding a book with your arm fully extended outwards vs. holding a book closer to you. The further the load, the more torque (force) it requires.
For the sway bars, typically you want the rod end to be perpendicular to the control arm when the car is on the ground, so you can choose the hole accordingly. You can also use that as another fine tuning method to increase or decrease the effect of the sway bar.
I would imagine the lower set of holes are for lower ride height vehicles to allow the shock to retain as much travel and to not bind the sway bar links.
Tried simplifying concepts from freshman year of Mechanical Engineering. Let me know if you would like a more thorough explanation.
JDKane527 is offline   Reply With Quote
The Following 6 Users Say Thank You to JDKane527 For This Useful Post:
8R6 (04-25-2015), akahenry (04-27-2015), ck-GT86 (04-25-2015), CSG Mike (04-25-2015), Hyper4mance2k (04-26-2015), Racecomp Engineering (04-27-2015)
Old 04-25-2015, 05:12 PM   #5
ck-GT86
ck-GT86's Avatar
Thought I'd ask the forum first since there are so many members running SPL's. Good idea though, thanks.
. ck
|| My Build Thread ||
lca, lower control arm, spl, spl pro parts
TINT levels chjno86 Southern California 26 07-07-2013 01:16 AM
Trim levels Euro86Arab Scion FR-S / Toyota 86 GT86 General Forum 8 03-08-2013 10:57 PM
hid light levels jaiminsong Cosmetic Modification (Interior/Exterior/Lighting) 16 10-27-2012 08:44 PM
Radiation levels adam Scion FR-S / Toyota 86 GT86 General Forum 7 07-01-2012 02:32 PM
FR-S Trim levels... nate89 Scion FR-S / Toyota 86 GT86 General Forum 155 08-05-2010 01:51 AM
