Old 04-22-2015, 02:20 PM   #15
Originally Posted by Streich94 View Post
So it's all about personal preference. Because there's different opinions for drop-ins and redoing it.
Yep! Most of the dynos show very modest increases and drop ins and whole systems are about the same. They actually did a pretty good job engineering the stock intake so it is pretty hard to get much more out of an aftermarket one.
Old 04-22-2015, 02:49 PM   #16
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I get jittery about my K&N drop in after looking at hard data. Does this leaned out AFR cause any damage/problems over the long haul?
V_86 is offline   Reply With Quote
Old 04-22-2015, 03:21 PM   #17
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
what about the perrin inlet tube?
DuMa is offline   Reply With Quote
Old 04-22-2015, 03:24 PM   #18
pinski
Stole my avy from zGrinch
pinski's Avatar
Drives: 2015 Audi S3
Most of the gains I saw were relatively equivalent between a cold air intake and a drop in + inlet tube. I went the latter route and got both for about $120. End result was a better sound, improved throttle response and maybe a smidge more oomph.
I wouldn't worry about it - the MAF is after the filter and will tell the ECU to adjust the mix accordingly. The cars that were dynoed right after dropping it in probably haven't had time to adjust yet. I wouldn't be concerned about this at all.
2015 Audi /S3 | Panther Black | DSG
Gone...2014 BRZ, 2010 Lexus IS F-Sport, 2006 Mazda MX5, 1997 Mustang GT
pinski is offline   Reply With Quote
The Following User Says Thank You to pinski For This Useful Post:
Tcoat (04-22-2015)
Old 04-22-2015, 03:34 PM   #19
I got the same from just a TRD drop in with the stock inlet tube. That stock tube is as ugly as sin though!
pinski (04-22-2015)
Old 04-22-2015, 03:36 PM   #20
pinski
pinski's Avatar
No doubt - the main reason I got the Perrin tube was to delete the stock tube and the sound generator. Cleaned up the engine bay quite a bit on that alone.
Tcoat (04-22-2015)
Old 04-23-2015, 04:34 PM   #21
pszuvela
pszuvela's Avatar
Drives: 2013 BRZ Limited - Manual, WRB
Originally Posted by gramicci101 View Post
GrimmSpeed air intake. They've done an incredible amount of testing and refining to make their product work well without affecting the AFR, which a lot of the others will do.
http://www.ft86club.com/forums/showthread.php?t=50492
http://www.ft86club.com/forums/showthread.php?t=78902
I agree. It provides a nice little increase in throttle response and a little kick but the best part is the sound is so much cleaner. And the engine bay looks much nicer too.
pszuvela is offline   Reply With Quote
Old 04-23-2015, 08:06 PM   #22
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
+1 for GrimmSpeed, getting it tuned (hopefully) sometime next month.
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 04-23-2015, 08:17 PM   #23
vividracing
vividracing's Avatar
I'll be that guy: stock airbox plus a drop-in filter.
+1. I have the OFH/OFT so I had to keep the airbox. But I did get the SuperTek intake tube and painted it to match the body color.
In the past I had the Injen intake system and hated it, it didn't look good and I honestly think the filter just doesn't do enough, and I'm inherently skeptical of all cone filters over stock. I just haven't seen real proof they filter out everything the stock filter does.
In my opnion with a new intake tube and getting rid of the side tank when you look to the left of the intake box, the stock intake box looks really good, and clean and simple.
I plan on having a drop in filter before my next change for a bit more gain.
-RyanG
vividracing is offline   Reply With Quote
Old 04-23-2015, 08:46 PM   #24
JS + BRZ
Drives: 2010 MS3
Who do you like more, dad or mom?
Old 04-24-2015, 11:11 AM   #25
Mishimoto
Drives: 2013 Subaru BRZ
im having a hard time figuring out which intake is better, or which one is worth the money. can i get some opinions?
Perrin Cold Air intake vs Mishimoto Cold Air Intake?
Thanks for considering our intake! As others have mentioned, there are numerous options available, all producing some pretty nice gains as well as improved intake sound.
We currently have one intake on the market, a cold-air system, and we are working on a second option which features an engine-bay mounted airbox.
We conducted a ton of testing on our first design, which is highlighted at the link below. We also discuss the R&D that went into creating this product, pretty neat stuff.
http://engineering.mishimoto.com/?cat=112
We made around 10whp/8wtq with this particular setup, some solid gains for an intake system on an NA vehicle.
Our second intake system is still in the works, but we are highlighting both development and testing in a similar fashion. Check it out!
http://engineering.mishimoto.com/?cat=260
Let me know if I can answer any questions about the intakes we have. Good luck with the modification of your BRZ!
-John
Mishimoto is offline   Reply With Quote
intake, subaru brz
'14 FR-S OEM Air Intake System w/ K&N Filter and Zeta Performance Intake Tube SoCalArgento Engine, Exhaust, Bolt-Ons 4 02-06-2015 10:40 PM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
