Old 04-22-2015, 05:49 AM   #2479
Trettiosjuan
Drives: GT86
Originally Posted by kodyo View Post
Except it will run on a stock tune without issues. I ran mine for 4.5 months/7600 miles without a single CEL and factory tune.
No guarantee, took mine 6 months and 10k+ miles before it triggered on my tune (I wanted it to trigger at first just in case something else was wrong).
Trettiosjuan is offline
Old 04-22-2015, 11:58 AM   #2480
nunonuna
nunonuna's Avatar
Originally Posted by Trettiosjuan View Post
Are there any numbers on the flow rating of the original vs. this one?
I think fr86sf stated earlier that the cat they use on this header is not high flow cat. http://www.ft86club.com/forums/showp...postcount=2087
However this blog post confuses us. http://ft86speedfactory.com/blog/cat...nd-subaru-brz/
nunonuna is offline
Old 04-23-2015, 05:06 AM   #2481
Trettiosjuan
Drives: GT86
5 liter per what (time unit and pressure loss)? Care to comment @FT-86 SpeedFactory ?
Old 04-23-2015, 08:57 PM   #2482
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Just chiming in.
Running the FT86SF UEL Catted header, TRD Intake & TRD Catback exhaust on the OFT Stage 1. Periodically picking up P0420 CEL while cruising on highway, generally after a cold start and little warm up. Clear and move on. Eventually I plan to tweak the map to turn off P0420 permanently.
Seems like the price of modding a bit outside of the stock tolerances, ohh well.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline
The Following User Says Thank You to Re~Mix For This Useful Post:
JohnJuan (04-23-2015)
Old 04-24-2015, 03:13 AM   #2483
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Originally Posted by Re~Mix View Post
Just chiming in.
It's easy to turn off that code, just a chack mark away in ecutek.
Cartman is offline
The Following User Says Thank You to Cartman For This Useful Post:
kodyo (04-24-2015)
Old 04-26-2015, 05:15 PM   #2484
jonbonazza
With this header, a motiv OP, Invidia catted FP, and invidia N1 catback with stock intake, and dyno tuned by the best, here is what I managed:
http://www.ft86club.com/forums/showthread.php?t=83972
jonbonazza is offline
Old 04-30-2015, 10:12 PM   #2485
Chazzzy
Drives: TBD
So, Maybe this has been addressed, maybe it hasnt. But sifting through 113 pages of posts would take a long time.
I'm noticing that a lot of you guys are having improper flow codes, despite running this header with a Cat.
Has anyone tried running a O2 spacer? Thus pulling the o2 sensor slightly out of the stream, allowing it to see a little less air, and removing the code?
I currently have a catless downpipe on my vw GTI, and I'm running a o2 spacer, and no tune. and I've never had a cat code. So i'm curious if the same can ring true for this car.
Chazzzy is offline
Old 04-30-2015, 10:35 PM   #2486
chas3wba0
chas3wba0's Avatar
Drives: Yes
Appreciate the effort! But all you had to do was search the word "spacer" in this thread........ but to answer your questions: yes, it has been addressed and tuning out the code is alot easier
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
Old 05-01-2015, 08:24 PM   #2487
Chazzzy
Drives: TBD
The issue with Tuning out the code, is that it shows "forced readiness" on the ECU, which... at least in NY. Will cause you to Fail inspection.
Chazzzy is offline
The Following 2 Users Say Thank You to Chazzzy For This Useful Post:
DGM86 (05-09-2015), NissanGuy (05-02-2015)
Old 05-02-2015, 01:11 AM   #2488
chas3wba0
chas3wba0's Avatar
Drives: Yes
Guess we're just living in the new car nirvana where we don't have to worry about smog for another 4-6 years haha. Cross that bridge when we get to it
Old 05-09-2015, 10:54 PM   #2489
DGM86
Drives: 15 BRZ, 07 Tacoma TRD, 01 Miata SE
I don't think this is the case for those of use living in an OBDII-verified compliance state. As far as I know, throwing most codes will cause you to fail an inspection. I do not believe there is a way to suppress a CEL without, as Chazzzy pointed out, showing a forced readiness on the ECU.
If someone knows of a way, I would be very interested in hearing about it.
DGM86 is offline
Old 05-09-2015, 11:38 PM   #2490
DGM86
Why, hello there. Look at the many shiny things sent to me by the great god of heavenly exhaust notes:
Still waiting on the Invidia resonated front pipe. Gonna be interesting going from completely stock to a full header back exhaust overnight!
DGM86 is offline
The Following 3 Users Say Thank You to DGM86 For This Useful Post:
chas3wba0 (05-10-2015), nivek111070 (05-15-2015), Teseo (05-10-2015)
Old 05-10-2015, 08:09 AM   #2491
Teseo
Drives: frs
Nice start up, dont forget to take some sound clips
I would take the red candy if you dont mimd
Teseo is offline
The Following User Says Thank You to Teseo For This Useful Post:
DGM86 (05-10-2015)
Old 05-10-2015, 08:19 PM   #2492
DGM86
Already plan to. Got an external mic for my GoPro and a (cheap) decibel meter on the way from Amazon, so hopefully later this week i'll be able to throw together some videos of how it sounds.
As for the Laffy Taffy, those have long since disappeared... Sorry
DGM86 is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
