Old 04-22-2015, 08:11 AM   #2633
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
A splitter did not function in our experience.
It sounds like you need an oil cooler, more than changing oil weights. Changing oil weights is a band-aid. The oil cooler is the real solution.
I was actually going to attempt to use a splitter this weekend. We'll see what happens and I'll report back.
-mike
AZP Installs is offline   Reply With Quote
Old 04-22-2015, 10:29 AM   #2634
ddeflyer
-mike
A physical splitter cable (ie one that doesn't have a CAN bus hub in it) will only stand a chance of working if one device is using CAN bus protocol and the other is using the OBDII protocol (so then they are using different pins). I don't know much about the P3, but the Solo DL can be configured to read the car as a generic OBDII device. The data rate and fields kind of suck, but you might give that a try if you really really want to use both. At the same time, if the P3 can be configured to run as a generic OBDII device then you might be able to use the Solo DL with the normal 86 configuration.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 04-22-2015, 01:07 PM   #2635
CSG Mike
CSG Mike's Avatar
However, in generic OBD2 mode, we don't get any of the data we find valuable.
CSG Mike is online now   Reply With Quote
Old 04-22-2015, 01:39 PM   #2636
ddeflyer
Exactly.
As I said: "The data rate and fields kind of suck"
Really, if you want gauges and such from the ECU while getting data logging, you are looking at a higher product line than the Solo DL (or trying out a CAN bus hub).
Old 04-22-2015, 01:44 PM   #2637
AZP Installs
Exactly.
Most likely I will yank the obdii connection on the P3 and just use the solo dl for on track in the Project BRZ. With the Spec86 we are going full MXL2 Dash.
Mike
Old 04-22-2015, 03:03 PM   #2638
CSG Mike
CSG Mike's Avatar
Mike
That's generally what happens in any car i sit in with a P3 gauge... the peaks feature is nice but the AIM is far more valuable.
I do wish the AIM had a screen like the V3 AP, which shows peaks and valleys, as well as current.
Old 04-22-2015, 07:42 PM   #2639
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
just picked up a set of enkei rpf1's. want to get some lugs for these wheels. can anyone suggest what is good and tested on track that i can pick up since i will be tracking beginning of next month and need to get them soon. I want to get the CSG lugs but they are all sold out so any suggestion would help please.
Also do you guys recommend using hub rings for racing or not? I was thinking of picking up aluminum hub rings for racing?
ExxelDistributions is offline   Reply With Quote
Old 04-22-2015, 07:47 PM   #2640
CSG Mike
CSG Mike's Avatar
Hubcentric rings reduce/eliminate stress on the lugs/studs if you impact your lugs on. You should never be impacting lugs on.
Do you have any alternate choices for lug nuts?
-Mike
Old 04-22-2015, 07:54 PM   #2641
ExxelDistributions
-Mike
I torque my lugs regardless of aftermarket wheels or not. But would it be better to run hub rings even if you torque the wheels down.
I was thinking of either EVS Tuning "Super Lap" Racing Lug Nuts, WedsSport Competition Lug Nuts, or Muteki SR35 Lug Nuts but from what I read they say Muteki is no good for track. Can you suggest something that would be good for racing and reliable.
Old 04-22-2015, 07:56 PM   #2642
CSG Mike
CSG Mike's Avatar
We're working on the third generation CSG Lugnut, but they won't be here for a while.
The WedsSport lugs are great, and we have them in stock. I've heard good things about the EVS lugs as well.
Old 04-22-2015, 08:48 PM   #2643
ExxelDistributions
If you were to compare the 2 which would work better?
Old 04-22-2015, 09:49 PM   #2644
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Question on DBA T3 rotors. Installed them a week ago and it's been fine, but I've noticed some pretty serious discoloration all of a sudden today. Might be surface rust, not sure yet. But man...it's pretty bad. I drive the car daily, and took it to work and back. Pulled the wheels off to start my JR Oil Cooler install and saw this. Seems odd. This is with the OEM pads, I keep the Carbotechs for track only. These babies were super bright and shiny yesterday.
Your thoughts?
I'll get better photos with my DSLR if necessary. Thanks!
Apex_BRZ is offline   Reply With Quote
Old 04-22-2015, 09:57 PM   #2645
CSG Mike
CSG Mike's Avatar
Your thoughts?
Looks like surface rust. Also looks like the pads are not perfectly mated to the rotor surface, since one is new and the other is not.
Just keep driving and they'll eventually mate themselves.
-Mike
Old 04-22-2015, 10:02 PM   #2646
Apex_BRZ
-Mike
I drove the car home, walked inside and changed clothes, and then took the wheels off. I've never seen surface rust develop so fast. The back rotors (OEM) are fine.
The pads not mated to the surface of the rotors yet accelerates surface rust? Sorry if this is pretty basic. Road america in a week and a half and in a scramble to get everything done in time.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
