Old 04-21-2015, 06:52 PM   #1
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Going with a 1jz
Recently blew the Fa20, just over 36k miles.. been debating on what to do with the car and came to conclusion I'll be doing a 1J with a R154 tranny, still haven't purchased the motor or anything for it just because I'd like to shop around and not jump into. more likely I'll be piecing it slowly. Gonna start this awesome project in the next week or two! The motor as it sits currently
PolishFrs13 is offline   Reply With Quote
The Following User Says Thank You to PolishFrs13 For This Useful Post:
flippy (04-22-2015)
Old 04-21-2015, 06:55 PM   #2
Pkush
Subbed
Pkush is offline   Reply With Quote
Old 04-21-2015, 07:09 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
that hole doesnt belong haha...
what happened?
Old 04-21-2015, 07:41 PM   #4
PolishFrs13
building life
haha it works fine!
well I'm not sure yet.. haven't taken a closer look to it. But I was turbo'd for 10k went back to stock and about tree weeks into being stock this happened cruising on the highway
Old 04-21-2015, 08:15 PM   #5
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
What turbo kit and what was your set up? How much boost/what gas etc...
KevinK121 is offline   Reply With Quote
The Following User Says Thank You to KevinK121 For This Useful Post:
raven1231 (04-21-2015)
Old 04-21-2015, 08:16 PM   #6
swarb
vvti or non-vvti? 1j is a a great choice!
Old 04-21-2015, 09:05 PM   #7
raven1231
This
Old 04-21-2015, 10:15 PM   #8
KevinK121
Miata traitor
KevinK121's Avatar
From ops show off thread
"Current mods
-Fullblown motorsports base kit with GT2871
-3in Turbo back FBM single exhaust
-FBM Radiator
-PWJDM engine dress up kit"
Still curious on what you were pushing and what fuel you used the majority of the time
raven1231 (04-22-2015)
Old 04-22-2015, 01:57 AM   #9
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
why bother with the 1J instead of a 2J?
JP is offline   Reply With Quote
The Following 2 Users Say Thank You to JP For This Useful Post:
Poodles (04-23-2015), Sportsguy83 (04-22-2015)
Old 04-22-2015, 04:22 AM   #10
SciOnDrifTtSlIdeR
Drifter
Send a message via MSN to SciOnDrifTtSlIdeR
I had a 1jz twin turbo in a car that weighed about 600lbs more then the FRS and even with the 1jz being stock the car was a rocket... one day my FRS is getting swapped
SciOnDrifTtSlIdeR is offline   Reply With Quote
Old 04-22-2015, 05:54 AM   #11
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
it has been many years, but I heard something about the 1jz head having better flow or compression or something, and you could swap it onto a 2jz block and make a 1.5jz. There is no punch line to that, I just thought I would throw it out there.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 04-22-2015, 07:05 AM   #12
JP
Backyard Fabricator
1.5J is a waste of effort, 2J head has been proven to flow better stock for stock. The reason people do 1.5J's is to retain their existing 1J loom, plenum, big single manifold etc.
I've built a heap of cars with the full range of JZ motors, my favourite of the lot is a vvti 2J with big single setup.
The Following 4 Users Say Thank You to JP For This Useful Post:
flippy (04-22-2015), FrX (04-23-2015), Sportsguy83 (04-22-2015), Target70 (04-22-2015)
Old 04-23-2015, 01:16 PM   #13
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
looks like you shot a rocker out. its a problem with stock valve springs and high rpm/power. usually doesn't cause any valve/internal damage though
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 04-23-2015, 01:50 PM   #14
Dipstik-sportech
Dipstik-sportech's Avatar
A third the price? Easier to find? Cheaper trans?
The Following 3 Users Say Thank You to Dipstik-sportech For This Useful Post:
Chrisgalactic (12-07-2015), D_Thissen (04-04-2017), MrFisty (03-22-2016)
