Old 05-23-2012, 03:33 AM   #85
blags
Drives: Toyota 86
Ravspec - Do Work release 18x9+30 in 5x100 or are they a special order?
blags is offline   Reply With Quote
Old 05-23-2012, 12:39 PM   #86
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by RavSpec View Post
Should be no poke in the front with 8.5 +47.
If staying with 8.0, don't necessary need spacer. But if u want flush, I say around 15mm to 20mm spacers should do the trick.
Is all your info - with bare wheels or with tires mounted? My concern for 8" (and even for 7.5") +48 wheels is that even 225-wide rubber, tires could rub on the spring under load.
Old 05-23-2012, 03:14 PM   #87
FT86Katsu
Drives: Mitsubishi Evolution 1 GSR
I wanna run 18x9s all around.. sounds like 18x9 +30 in the front with coils should be okay. Yeah?
FT86Katsu is offline   Reply With Quote
Old 05-23-2012, 06:39 PM   #88
Jdogg180
Jdogg180's Avatar
Drives: 2008 Fit Sport
This may have been mentioned earlier but don't forget about the additional clearance you will have with a healthy dose of camber via your favorite adjustable suspension goodies. Another thought would be flaring that front fender out a bit to make something like an 18x9 +35 to 30 fit with a 245 or 255 tire. Its very likely with coilovers you will gain a good amount of clearance inboard. It seems to me like 18x9 +35 all around with a 255/35 tire would be achievable, with a little work of course, and probably be a very effective Non-Staggered track setup.
Jdogg180 is offline   Reply With Quote
Old 05-24-2012, 04:50 PM   #89
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
Hrm so I saw the post about 18x8.5 +47, but would +44 make much of a change? I should easily clear suspension since you're moving the wheel more outward bound correct?
I'm still super new to the wheel dynamics and math involved, but it sounds like you'd gain 3mm of inside clearance. Would they still fit in the fenders in the front? I'm thinking at 225 40 tire on that, but not sure if it would rub on the suspension under load.
denkigrve is offline   Reply With Quote
Old 05-25-2012, 07:37 AM   #90
RavSpec
Drives: Rx7
Yup 18x8.5 +44 will sit better in the front.
RavSpec is offline   Reply With Quote
Old 05-25-2012, 07:39 AM   #91
RavSpec
Drives: Rx7
Nope, it's fine. Japan already tested 8.5 +47 with tires in the front.
Also 9.0 +38 with tires in the back will work as well.
Old 05-25-2012, 07:40 AM   #92
RavSpec
Drives: Rx7
Special order only
Old 05-25-2012, 08:55 AM   #93
blags
Drives: Toyota 86
All good, placed an order with you on nasioc
Old 05-28-2012, 04:02 PM   #94
CNC Autosports
Drives: 1988 BMW M3 and 2012 Scion FRS
18x8 et40 with 235/40R18
Here is a pic of our FR-S 18X8 et40 235/40R18 Dunlop. The front is perfect and the rear could use about a 10mm spacer. I have a set of Forgedstar F14 being made 19X8.5 et 45 and 19X9.5 et 42. Should be here in a few weeks
CNC Autosports is offline   Reply With Quote
The Following 3 Users Say Thank You to CNC Autosports For This Useful Post:
Fly Guy (05-28-2012), poormans_LFA (05-30-2012), Staticfrost (05-30-2012)
Old 05-28-2012, 04:09 PM   #95
denkigrve
Random Internet dad
denkigrve's Avatar
What suspension is the car on? Is that still stock ride height?
Old 05-28-2012, 04:24 PM   #96
CNC Autosports
Its 1.5 lower front and rear with a set of tein springs we had and modified.
Old 05-29-2012, 07:06 PM   #97
Staticfrost
Drives: Eight Six
Perfect cause the enkeis I was after is the same 18X8 et40. Now to start looking for some 10mm spacers for the rears.
Staticfrost is offline   Reply With Quote
Old 05-29-2012, 08:12 PM   #98
dnjshin0bi
dnjshin0bi's Avatar
Drives: 86 GTS (PW) Manual
is it just me or does 18's look abit too big for a car this size? i mean this car is similar size to an s2k..
dnjshin0bi is offline   Reply With Quote
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 124 08-01-2016 11:38 PM
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 12:39 PM
Wheel Directory: Work Emotion XD9 18x10.0 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 05-23-2015 12:54 AM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 01:26 AM
Wheel Directory: Work Emotion 11R 18x9.5 +30 autofashionfred Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 08-11-2012 02:39 AM
