Old 04-09-2015, 08:03 AM   #155
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
Firstly, great job on this project. Secondly, what front pipe and over pipe are you guys recommending to be mated with your kit? I already have your V2 cat-back that i would very much like to keep.
Thanks for any input!
-Carlos
Carlos_M is offline
Old 04-09-2015, 09:27 AM   #156
mrk1
Drives: Sterling BRZ Ltd
^^ pretty safe assumption they kept the factory flange location so any quality fitting exhaust parts should work.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline
The Following User Says Thank You to mrk1 For This Useful Post:
Carlos_M (04-09-2015)
Old 04-09-2015, 09:36 AM   #157
raven1231
That includes EBAY specials right?
raven1231 is offline
Old 04-09-2015, 09:57 AM   #158
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. Go with the 3" overpipe to be sure you have a fun time fitting it as well.
King Tut is offline
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Carlos_M (04-09-2015), raven1231 (04-09-2015), wparsons (07-17-2015)
Old 04-09-2015, 10:06 AM   #159
mrk1
eBay parts are why I was careful with my wording, who knows what those things are shaped for sometimes. Flanges look like they where located based of astrological clocks or something, nothing actually fitting the vehicle.
The Build Thread
mrk1 is offline
Old 04-09-2015, 10:15 AM   #160
Carlos_M
Carlos_M's Avatar
Wait, so the 4.5 inch direct fit eBay exhaust may not work?!?! What a waste of $47!!!
But back on track, thank you for the input! I just wasn't sure if they preferred one setup over another and was curious.
-Carlos
Carlos_M is offline
Old 04-09-2015, 10:40 AM   #161
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
-Carlos
You know your exhaust is quality when shipping costs more than the part $$
Top Tier Imports - Check out my build journal HERE
protpibe is offline
The Following 6 Users Say Thank You to protpibe For This Useful Post:
Carlos_M (04-09-2015), cdrazic93 (04-11-2015), Draco_PR23 (05-06-2015), Lonewolf (04-12-2015), LucidMomentum (04-09-2015), SkAsphalt (05-04-2015)
Old 04-11-2015, 07:20 PM   #162
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
How goes development guys?
cdrazic93 is offline
Old 04-21-2015, 05:57 PM   #163
FT86SF_tuner
Drives: FT86 turbo
Car has been fitted with 700cc injectors now but had to be packed up for a racing trip to COTA. When it gets back, we plan to get it back on the dyno with an electronic boost controller and do some higher boost tuning on 91.
E85 is in the plans as well but I don't know how soon we'll get to that.
The car did well at its last track event but had issues with oil blow-by. It has been fitted with an air oil separator and a check valve to combat that issue. More details should come on that and it sounds very likely that the kit will include this or make it an option.
I don't think any other kits comes with anything to deal with positive pressure from the manifold going into the crank case or with air/oil separation at all when a forced induction system is added onto these cars. Might not be an issue on the street, but for any kind of track use it seems like it must be included.
FT86SF_tuner is offline
The Following 3 Users Say Thank You to FT86SF_tuner For This Useful Post:
cdrazic93 (04-21-2015), FT-86 SpeedFactory (04-22-2015), Pen.suhl (06-22-2015)
Old 04-22-2015, 09:48 AM   #164
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Are you guys planning on including clamps for the evap lines as well? The check valve I've heard is a must when boosting. The lines have popped off on some running higher PSI (10+) when tracking.
2016 Camaro SS is offline
Old 04-22-2015, 10:54 AM   #165
FT86SF_tuner
Drives: FT86 turbo
We want this kit to be extremely complete so any clamps or check valves needed will be something that gets included. It is annoying how incomplete some kits out there seem to be. We intended to do a lot of real world testing/tuning with this kit to get things to be 100% perfect as if this car came with a turbo.
2016 Camaro SS (04-22-2015), chaoskaze (05-06-2015), raven1231 (05-06-2015)
Old 04-22-2015, 11:05 AM   #166
2016 Camaro SS
Drives: Fast
That's really awesome because I would plan on installing this right in my apartment complex covered parking spot. Most people said I was nuts for doing work on my car there, but now they all come up to me asking me to work on their cars after seeing all the work I've done and this is the first car I have ever done wrench work on myself.
Five Axis body kit, coilovers, LCA's, toe arms, header, headerback exhaust, radiator, intake, HID's, head lights, tail lights, third brake light all in my own labor. I'd be happy to check off "installed my own turbo kit with my own hands". Saves a tremendous amount of money and it is so rewarding knowing that you did the work. Plus you pick up some neat tools along the way for future use.
Keep up the good work.
Old 04-26-2015, 02:16 AM   #167
FRS Justin
Drives: 2013 Asphalt FRS
I got a look at this turbo kit first hand today in Austin. I must say Ft86 speedfactory has spent a lot of time engineering this kit. The routing is top notch, Tons of clearance in all areas. I didnt see any trimming what so ever on the car the pipes all have sufficiant clearance from what I saw. This kit will be perfect for the guy that wants 300 to 400 reliable hp. Excellent job guys...
FRS Justin is offline
Old 05-04-2015, 01:49 AM   #168
Struckbylitenin
Struckbylitenin's Avatar
Drives: 10 Series FR-S
I don't think they've answered whether there will be AT support. (fingers crossed)
Struckbylitenin is offline
PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 Events@Ptuning Tracking / Autocross / HPDE / Drifting 12 01-13-2014 10:22 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
FA20CLUB Turbo Kit 10 PSI Preliminary Testing FA20Club.com Forced Induction 161 07-27-2013 02:31 PM
N1 Concepts/Exotic Air - Turbo Development LSV8 Forced Induction 24 04-10-2013 09:48 PM
