Old 04-21-2015, 12:04 AM   #1
Joshwahhhs
Joshwahhhs's Avatar
Drives: 2013 Asphalt FRS M/T
Resting your hand on the shifter
Do you guys usually rest your hand on the shifter? I heard the extra weight is bad for the transmission.
And if the weight is bad for the transmission, what about a weighted shift knob?
Joshwahhhs is offline   Reply With Quote
Old 04-21-2015, 12:08 AM   #2
Vroomin86
Drives: 2015 Fire
Haha I think about this everyday. Especially with my 500gram flossy shift knob. From what I've read our hand is worse because it completely creates a counter force on the natural movement of the shift linkage. The shift knob doesn't, just makes it a little harder which I am sure also affects it in a negative but not as bad.
Vroomin86 is offline   Reply With Quote
Old 04-21-2015, 12:26 AM   #3
Tromatic
Both of you need to provide links to this information.
Old 04-21-2015, 12:32 AM   #4
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Watch any pro driver. Hands on the wheel at all times, except to shift.
R3NIK is offline   Reply With Quote
The Following User Says Thank You to R3NIK For This Useful Post:
richardM (04-21-2015)
Old 04-21-2015, 12:35 AM   #5
Tromatic
Bet a dime it has nothing to do with the weight of his hand destroying his transmission.
The Following 15 Users Say Thank You to Tromatic For This Useful Post:
8R6 (04-21-2015), chas3wba0 (04-21-2015), Choco (04-21-2015), Error (04-21-2015), fika84 (04-21-2015), gramicci101 (04-21-2015), Jonsey (04-21-2015), mrunal91 (04-21-2015), PhantomX (04-21-2015), pinski (04-21-2015), Pkush (04-21-2015), richardM (04-21-2015), tato.valverde (04-21-2015), WhiteFRS69 (04-21-2015), Wilsonk227 (04-21-2015)
Old 04-21-2015, 01:11 AM   #6
smotonaga
smotonaga's Avatar
Drives: Subaru BRZ Series.Blue
Resting your hand on the shifter will cause the shift fork to make contact with the syncronizers (which spins) and will eventually cause wearing on the forks. If I remember correctly, a complaint will be the shifter popping out of gear. I rest my hand on top of the hand brake.
smotonaga is offline   Reply With Quote
The Following 4 Users Say Thank You to smotonaga For This Useful Post:
Braces (04-21-2015), DAEMANO (04-21-2015), fika84 (04-21-2015), Ultramaroon (04-21-2015)
Old 04-21-2015, 01:17 AM   #7
wheelhaus
wheelhaus's Avatar
Resting your hand on the shifter is not a problem by itself. A weighted shift knob is not an issue at all, there's not enough force to matter, but if you rest a 10lb arm on the shifter, it can cause the stick to deflect slightly from it's intended position.
Easy explanation:
Deflecting the stick potentially causes an internal part of the transmission shift mechanism to drag. Its like starting the shift motion, but only just holding it there. This is bad, don't do it. If you MUST rest your hand on the shifter, keep a light touch and make sure its not moving. Shifting and occasional stick movement isn't going to hurt anything, but constant drag can.
Technical explanation:
Inside the transmission, each pair of gears shares a shift fork (move the stick left to choose the 1-2 fork, stick center is the 3-4 fork, stick right is the 5-6 fork). Each shift fork kinda looks like the letter C and pushes a synchro fore or aft to engage one gear or the other. The C shaped portion rides in a groove around the synchro so the synchro can spin freely, but still be pushed into position as necessary. Once a gear is engaged, the shift fork is meant to simply rest in that position (held in place by the the synchro groove) until the driver forces it to disengage that gear.
Resting your hand on the shifter can cause the shift fork to drag against the groove in the synchro, causing abnormally high friction as the oil is scraped away. Eventually, this can gall/break the shift fork and prevent it from moving the synchro properly, which manifests itself as weird shift problems, grinding, popping out of gear, etc.
The Following 12 Users Say Thank You to wheelhaus For This Useful Post:
Bonburner (04-22-2015), Caspeed (04-21-2015), continuecrushing (04-21-2015), DAEMANO (04-21-2015), fika84 (04-21-2015), joe strummer (04-21-2015), Joshwahhhs (04-21-2015), mrunal91 (04-21-2015), srizzors25 (04-21-2015), SVTSHC (04-22-2015), Tcoat (04-21-2015), Ultramaroon (04-21-2015)
Old 04-21-2015, 01:22 AM   #8
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
Solution: get a automatic and rest your hand on that for days. Unless you have a column gear selector like me, then that's just a bit awkward.
"Why must everything that is broken be fixed?"
GhostRai is offline   Reply With Quote
The Following User Says Thank You to GhostRai For This Useful Post:
DGM33 (04-21-2015)
Old 04-21-2015, 01:27 AM   #9
Shift forks and hub sleeves. They are not designed to drag against each other indefinitely.
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
DAEMANO (04-21-2015), pinski (04-21-2015), stugray (04-21-2015), SVTSHC (04-22-2015), wheelhaus (04-21-2015)
Old 04-21-2015, 01:28 AM   #10
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
I don't buy into this, I've had friends rest their hand on their STi and Evos all the time and the car still runs fine.
But I'm assuming they're not putting a lot of pressure and weight on the shifter, they're just resting their hand on it. I also do the same as well my car still runs fine at 17K miles.
Alltezza is offline   Reply With Quote
Old 04-21-2015, 01:28 AM   #11
fatoni
the transmission is designed to deal with thousands of ft/lbs of torque and we worry that the weight of our hand is going to ruin it? dont do it because you should have your hands on the wheel.
Drive upgrades. Don't buy them.
Old 04-21-2015, 01:35 AM   #12
Vroomin86
Drives: 2015 Fire
A little contradicting if you ask me. The final answer is YES, there will be some sort of LONG term wear on your shift forks/synchros. Nothing you will probably ever notice until many miles have been registered on said gearbox. But FYI Most people arms do weigh about 10lbs
Old 04-21-2015, 01:37 AM   #13
It takes a long time. I destroyed a B-210 transmission in my early 20s. Learned my lesson the hard way after it started popping out of 4th. It's real. If you do it, quit.
Old 04-21-2015, 01:39 AM   #14
Tromatic
Damn, some of you have Cylon arms or what?
The Following User Says Thank You to Tromatic For This Useful Post:
Muaddib (04-21-2015)
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
Shifter springs/bushings/shifter performance Darnold Engine, Exhaust, Transmission 10 10-22-2014 11:49 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
